Silkworm repair log #2 and schematics
 PCB Repair Logs, Repair Logs  Comments Off on Silkworm repair log #2 and schematics
Apr 162024
Board is a bit dusty but very clean nonetheless. Some very specific chips are rusty, probably due to some rodent fluid. Tracks are invisible and located in the core of this 4-layer board making the inner tracks very fragile when pulling a chip out.
Game starts when powering the board with full sound and some graphics. The title screen has a white background instead of black as it should be. A similar white background appears during attract mode:
Cross-testing the board with a good one points the fault to the bottom board (graphics board). On this board I started probing the 8 EPROMs filled with the background graphics data. Some pins are quite corroded, so I decided to dump them to check their contents against MAME data:
As a result, EPROMs 10 and 14 are dead. I burnt two replacement EPROMs and that brought the background back:
Background is back but the sprites are blinking, they are misplaced and have bad colors. Sprites are generated by the custom chip Mitsubishi M60002-0118P and displayed through twenty 4164 DRAMs. These are known for having a high failure rate. I will focus my investigations in this area:
Probing the D-OUT pins of these DRAMs (pin 14), 8 DRAMs out of 20 shows an output signal stuck low or even floating when the game has to display sprites:
I pulled these 8 D-RAMs:
All of them were confirmed bad out of circuit.
I fit 8 brand-new replacement DRAMs. Some sprite glitches are still visible – two other DRAMs have just gone bad. I took those out and replaced them. Now the sprites and backgrounds appeared to be rendering properly. However, the sprites motion is still jerky.
Rygar shares the same hardware as Silkworm and has schematics available. In the schematics, we can see that two 6116 SRAMs handles foreground and background graphics and a third one is dedicated to sprite positioning (SP/POSITION.RAM as per the schematics). This is the area I will inspect.
Inspection of the SRAM chip at location 6L doesn’t show anything abnormal. While probing around the area, I came across a signal stuck high on a 74LS193 binary counter (BORROW output) located at 7K. I double-checked it with my logic comparator:
Red light indicated a bad output – I pulled the suspect:
Confirmed bad out of circuit:
Replacing this chip fixes the jerkiness. Game is perfectly playable. Sound and controls tested OK.
Summary :
  • 11 DRAMs (SAMSUNG),
  • 2 EPROMs,
  • 1 74LS193 (TEXAS INSTRUMENTS)
Some months after this repair, I found the proper original Silkworm schematics, scanned it and upload to my GitHub here:
https://github.com/DocteurPCB/schematics/blob/main/Silkworm%20%5Bschematics%5D.pdf
New Section – Arcade PCB Encyclopedia
 General  Comments Off on New Section – Arcade PCB Encyclopedia
Apr 132024
I’m introducing a new section of JAMMArcade.net that I believe will be very useful for arcade repair technicians – the Arcade PCB Encyclopedia.
I have long admired the Console 5 Wiki as a comprehensive source of information for video game consoles. A typical console page will have a capacitor list, describe common faults, and collect manufacturer white papers. The JAMMArcade.net Arcade PCB Encyclopedia will attempt to accomplish the same thing for arcade boards.
My goal is to eventually document the following information in one page each for most arcade boards:
  • High quality photos of the boards – both originals and bootlegs
  • Notable ICs and their function
  • Capacitor list
  • Common faults and solutions to those faults
  • Protection mechanisms
  • Schematics and Datasheets
  • Links to other reference resources on the Internet
Given the number of arcade games produced, it may take several years to assemble these resources for every game, but I want to at least start with the most popular and most documented ones.
The Encyclopedia launches today with information on three boards and I will try to write up 1 – 2 more each week – each one takes a while to research!
I highly value credit for the original researchers and strive for proper attribution. Please contact me if you notice any mistakes in the Encyclopedia entries and I welcome other contributors as well.
Sega System 16B
 Encyclopedia  Comments Off on Sega System 16B
Apr 132024
Last Updated: 4/17/2024
Article Credit: ShootTheCore, Furrtech, cpsystem3,Eduardo Cruz, ExodusEmulator, Caius, Frank_fjs, twistedsymphony, Jotego
Main Board
The Sega System 16B main board contains all the processing logic to run the game. The Sega part number for it is 171-5347.
Note that these boards are NOT JAMMA pinout and need an adapter to be properly connected to a JAMMA harness.
Depending on the protection scheme used for the particular game, the Main CPU may utilize encryption, the Sound CPU may utilize encryption, and an MCU may or may not be present – see Protection Measures below for more details.
Notable ICs
ICFunctionLocation
Hitachi FD1094 CPU (encrypted)
Signetics SCN68000C8N64 68000 CPU (unencrypted)
10.0 Mhz Main CPUC9
NEC MC-8123B CPU (encrypted)
Zilog Z8040004PSC Z80 CPU (unencrypted)
4.0 Mhz Audio CPUD15
Yamaha YM2151FM AudioD12
Yamaha YM3012Audio DAC for the YM2151D18
NEC D7759CAudio Speech SynthD16
Sega 315-5195Memory MappingD4
Sega 315-5196Sprite GenerationI4
Sega 315-5197Tilemap GenerationI18
Intel i8751MCU (Copy Protection)B2
ROM Board (credit: ExodusEmulator)
There are four variants of the ROM board used with System 16B:
  • 171-3538: ROMs only. Support for 32K/64K ROMs
  • 171-5521: Banking register added to the middle. Support for 512K/1M/2M ROMs
  • 171-5704: Jumper pins added to control banking. 512K/1M ROMs
  • 171-5797: Adds Sega 315-5250 68000/Z80 mapping interface and an additional banking register. 512K/1M ROMs
Source: ExodusEmulator
Daughter Boards (credit: ExodusEmulator)
There are two daughter boards used with some System 16B games for additional control IO:
  • 171-5437 / 834-6180: Trackball input
  • 834-6523: 4 Player input
Board Variants
The Sega System 16B board was identical between regions for the full lifecycle of the hardware. However, it was heavily bootlegged and thus there is a wide variety of cloned boards. Compared to the original games, cloned boards may have differences in graphics, sound, gameplay and speed. The bootlegs look dramatically different from the Sega originals and are easy to distinguish from the real thing.
Common Issues and Quirks
System16B boards are NOT JAMMA pinout and need an adapter to be properly connected to a JAMMA harness.
System16B boards draw more power than average, so adjust your arcade PSU accordingly when swapping one into your cabinet or SuperGun.
It is common for the battery in the Main CPU or Sound CPU to die if they are encrypted, causing the game to either not boot or not have sound respectively. See “Copy Protection” below for details and resolution.
It is common for the TL084 OpAmp located at D19 to fail, resulting in faint or garbled audio output. Replacement parts are easy to source.
Capacitor List (credit: Frank_fjs)
LocationCapacitanceVoltagePart No.
C2470 uF16 VECA-1CM471B
C3470 uF16 VECA-1CM471B
C4470 uF16 VECA-1CM471B
C61 uF50 VECA-2VM010B
C71 uF50 VECA-2VM010B
C81 uF50 VECA-2VM010B
C91 uF50 VECA-2VM010B
C10470 uF16 VECA-1CM471B
C16470 uF16 VECA-1CM471B
C1110 uF16 VECA-1CM100B
C1210 uF16 VECA-1CM100B
C13220 uF16 V647-URS1C221MPD1TA
C14100 uF16 VECA-1CM101B
C15100 uF16 VECA-1CM101B
C1947 uF16 VECA-1CM470B
C622.2 uF50 VECA-2AM2R2B
C632.2 uF50 VECA-2AM2R2B
C212.2 uF50 VECA-2AM2R2B
C222.2 uF50 VECA-2AM2R2B
C34220 uF16 V647-URS1C221MPD1TA
C350.1 F5.5 V80-FYD0H104ZF or 80-FG0H104ZF
ROM Details (credit: MAME)
Due to the variety of ROM boards used across the System16B games, consult the MAME Driver for game-specific ROM assignments.
When replacing a mask ROM with an EPROM, consult this reference chart by twistedsymphony:
Protection Mechanisms
Sega implemented four different protection mechanisms to prevent arcade operators from swapping one System 16B game to another by installing a new set of ROM chips. Games may implement one or more of these protection mechanisms:
  • 68000 Main CPU Encryption
  • Z80 Sound CPU Encryption
  • Intel i875 Memory Control Unit
  • ROM Board variants
Main CPU Encryption (credit: Eduardo Cruz)
Some games encrypt the 68000 code executed by the Main CPU. Those games use a Hitachi FD1094 CPU, which is a Motorolla 68000 clone with a RAM-based decryption key that matches up with the encryption key used on Main CPU ROMs. If the battery that maintains the RAM storing the decryption key dies then the key is lost and the main CPU will crash at boot – the game will sit at a black screen at boot (“suicide”).
If the battery hasn’t died yet, it can be replaced while maintaining the onboard decryption key if power is maintained to the supply pins with a bench PSU while the old battery is desoldered and a new battery is soldered in.
If the battery has died, you have two options:
Source: Eduardo Cruz
Similar to the Main CPU, some games utilize an NEC MC-8123B CPU with an onboard decryption key maintained by battery-backed RAM, paired with encrypted Sound CPU code in the ROMs. If the battery inside the CPU dies, the decryption key is lost, the Sound CPU will crash at boot, and the game won’t have sound.
Solutions are identical to an encrypted Main CPU – if the battery hasn’t died yet, it can be replaced by removing the cover, powering the battery leads from a bench PSU, and soldering in a fresh battery. If the battery has died, swap the NEC CPU out for a standard 4.0 Mhz Z80 CPU, swap the Sound CPU ROMs out for decrypted equivalent EPROMs, and the game’s sound should then function again.
Intel i875 Memory Control Unit (MCU) Protection
Some games utilized an Intel i875 MCU (or clone) that sits between the CPUs and specifically encrypted ROMs that “scrambles” the memory addressing such that a game won’t function without a matching ROM set and MCU.
Decrypted ROM sets for every System 16B game are available so that the MCU socket can be left empty on the board, and the encrypted mask ROMs can be swapped with decrypted EPROMs to get a fully-functional game.
ROM Board Variants
As mentioned above, Sega utilized four different ROM board variants with the System 16B hardware across the game library. Assuming that no other protection mechanisms were in place, an arcade operator still wouldn’t be able to change one System 16B game over to another one by swapping ROMs unless the same ROM board was used with both games.
MAME documents the ROM board and configuration settings (if applicable) on the ROM board for each game.
Schematics & Datasheets
Original Sega schematics are available for System 16B, but there seem to be discrepancies between them and the real hardware.
Sega System 16B Schematics
Charles MacDonald wrote up extensive documentation on System 16B’s operations.
Charles MacDonald System 16B Hardware Notes
Jotego authored an FPGA core for System 16B and created a set of schematics for the 315-5195 custom IC in the process.
Jotego 315-5195 Schematics (Link)
Jotego 315-5195 Schematics (PDF)
Additional Resources
MAME Sega System 16B Driverhttps://github.com/mamedev/mame/blob/master/src/mame/sega/segas16b.cpp
Eduardo Cruz: Deconstructing Sega’s System 16 Securityhttps://arcadehacker.blogspot.com/2019/10/deconstructing-sega-system16-security-part1.html
https://arcadehacker.blogspot.com/2020/04/deconstructing-segas-system-16-security-part2.html
Eduardo Cruz: Sega System 16 / 18 / 24 / X Security Programming Guidehttp://arcadehacker.blogspot.com/2018/12/sega-system16-security-programming-guide.html
https://github.com/ArcadeHacker/ArcadeHacker_Sega_Hitachi
Exodus Emulatorhttp://techdocs.exodusemulator.com/Arcade/SegaSystem16/index.html
SOLID-orange – Twistedsymphony’s Projectshttp://solid-orange.com/
Jotego System 16B FPGA Corehttps://github.com/jotego/jtcores/tree/master/cores/s16b
Cave CV1000
 Encyclopedia  Comments Off on Cave CV1000
Apr 132024
Last Updated: 8/25/2025
Article Credit: ShootTheCore, rtw, buffi, Arcade Otaku Wiki, Alamone, System11, DragonMinded, Mike J Moffat
Overview
The Cave CV1000 PCB has three major revisions: Early CV1000B, Later CV1000-B and CV1000-D.
  • Early CV1000-B
    • Gold plated JAMMA connector
    • 9 Pin connection header mounted on the right side with some boards.
      It is unused with the released games but theoretically could have been used to link two boards together via serial communication since the connector is identical to the serial connector on PC motherboards.
    • P2 connection pin header in the center of the board populated.
  • Later CV1000-B
    • Tin plated JAMMA connector
    • 9 Pin connection header and P2 connection header unpopulated.
  • CV1000-D
    • Tin plated JAMMA Connector
    • Battery for the real-time clock removed
    • SDRAM doubled from 64Mb to 128Mb
The battery in the upper-right corner of the CV1000-B PCB is used to maintain a real-time clock in later games such as Ibara and Pink Sweets. Ibara also displays a clock in one level of the game that matches the board’s clock setting. High scores and game settings are stored in the RTC’s EPROM.
CV1000-D removed the battery – high scores and game settings are stored in NAND instead of EPROM with games running on that hardware.
Notable ICs
ICFunctionSilkscreen Label
Hitachi SH3Main CPUU5
Yamaha YMZ770AudioU22
Altera Cyclone EP1C12F324C8Graphics RenderingU8
Altera CA011CPLD used for address decoding of the U2 flash, YMZ770 audio and RTC 9701.U13
RTC 9701 (CV1000-B)Real-Time Clock with embedded EPROM for saving board settings and high scoresU10
AD8061Color amplifier for the Red, Green and Blue outputU14, U15, U16
Board Variants
Reproductions of both CV1000-B and CV1000-D boards from Chinese sellers began surfacing in early 2024. These reproduction boards can be distinguished from Cave originals with the following characteristics:
  • The JAMMA connector is gold plated. Although early CV1000-B boards (Mushihimesama) also had gold plating on the JAMMA connector, all original CV1000-D boards had tin plating.
  • Via “pinholes” are not visible on the back of the reproduced board.
  • A Cave serial number sticker is not present.
  • Some of the reproduction boards do not have the P4 header in the center of the board populated.
At this time, it is believed that the reproduction boards run the games identically to the Cave original hardware. The major IC parts (CPU, Graphics FPGA, Audio, etc) are the same. The build quality seems to be inconsistent though – many of the repro boards have already needed repairs even though at the time of this writing they are less than one year old.
Board Re-initialization (credit: MAME)
Some games (such as Mushihimesama and Espgaluda II) do not have a high score reset function. Any CV1000 can be reinitialized to the factory default high score and board settings with the following procedure:
  • During boot, hold P1 Right+A+B+C and P2 Left+A+B+C until the startup checks are complete.
CV1000 boards draw less power than your average PCB. Be sure to adjust your arcade PSU down when swapping in one of these boards so you don’t inadvertently over-volt the board!
Leaking Large Capacitor
The large capacitor labeled C109 in the upper-left corner that filters power for the sound amplifier often leaks. The part is rated for 2200 uF at 25 V.
Part number MAL216099606E3 has the same dimensions as the original part, while UCX1E222MNS1GS has the same footprint, but a lower height and a more supportive base. Source: System11
Color Amplifier Degradation (credit: System11)
The Red, Green and Blue color amplifiers located at U14, U15 and U16 respectively can degrade over many hours of use, resulting in a pale or incorrectly tinted display. Replacing the AD8061ARTZ color amplifier ICs (datasheet) with fresh parts should resolve the issue. Also note that the Service Menu has a brightness adjustment setting that may need to be changed afterwards.
Missing Red and Blue Colors (credit: rtw and System11)
Switch 4 of DIP Switch block S2 will disable the Red and Green output if it is switched On. If your board has this issue, try flipping that switch Off and On a few times to clean any gunk out of the switch. If that doesn’t help, use a multimeter to check continuity across the switch – if the meter shows continuity across the switch even when it’s disabled then replace the switch block.
VSync Deterioration (credit: TK86079)
The LX240A chip located at U11 handles the VSync signal for the board. On some boards, the chip fails, causing it to get burning hot to the touch, and the game to lose VSync. Sometimes it takes a while (20 minutes from power on) to occur.
The replacement part is Texas Instruments SN74LVT240APW or SN74LVT240APWR with the TSSOP-PW packaging.
Flash Deterioration (credit: Buffi)
The flash chip at U2 is known to suffer from data corruption, causing glitching in the graphics. The chip model is Samsung K9F1G08U0. The CV1000 does a manufacturer check at startup to make sure the flash chip is a K9F1G08U0, and will reboot if it is not. Buffi worked out a way to remove these checks, allowing the U2 flash chip to be replaced with an equivalent from another manufacturer.
https://github.com/buffis/cv1k_research/tree/main/U2_Replacement
Alamone worked out a way to fix graphics issues from deteriorating flash by comparing CV1000 U2 dumps and generating relocated NAND blocks:
https://github.com/alamone/u2_compare
Stuck Control Inputs
CV1000 uses three sets of twin resistor banks and individual 130nF ceramic capacitors as ESD protection between each player control input and the signal pins 176-208 on the SH3 CPU. If a resistor array becomes damaged then a control input may be “stuck” – always on or always off. It’s also possible for an ESD charge to make it through the ESD protection and fry the input line on SH3 CPU – the only resolution then is to replace the entire CPU. You can check the game’s reading of the control inputs in the Service Menu.
  • Resistor Array with 101 marking – replacement part number: 742C163101JP
  • Resistor Array with 103 marking – replacement part number: 742C163103JP
CPU Stuck in a Boot Loop – Nothing on Screen (credit: Mike J Moffat)
If the CPU is stuck in a boot loop, the LED at L6 will pulse every second to a darker color. Ensure that the 32.768 Khz crystal resonator (it’s not an oscillator) located at X2 is intact and functioning. Measurements for the part are 4.9mm X 1.8mm .
Source: https://gamerepair.info/hardware/37_cave_cv1000
Board Does Not Boot at All (credit: Buffi)
If the EPM7032AE CPLD at location U13 fails then the board will not start up. Buffi has devised a replacement bitstream that can be programmed onto a replacement CPLD to revive the board.
https://www.arcade-projects.com/threads/u13-replacement-for-cave-cv-1000-pcb-repair.17007/
https://github.com/buffis/cv1k_research/tree/main/U13_Research
Game resources are stored on flash chips located at U2, U4, U23 and U24. The U2 and U4 chips can be accessed by the on-board JTAG connector, but U23 and U24 are not on the JTAG bus and can only be rewritten if the chips are physically desoldered and removed from the board.
The U2 flash is a Samsung K9F1G08U0. The games check the flash ID at boot and if it doesn’t match the expected flash model then the game reboots.
Capacitor List
LocationCapacitanceVoltageTypePart No.
C1092200 uF25 VRadialMAL216099606E3
C121100 uF6.3 VRadial
C11439 uF16 VRadial
C12239 uF16 VRadial
C11339 uF16 VRadial
C131100 uF6.3 VRadial
C132100 uF6.3 VRadial
C13339 uF16 VRadial
C139100 uF6.3 VRadial
C140100 uF6.3 VRadial
C14139 uF16 VRadial
C951000 uF16 VRadial
C102100 uF6.3 VRadial
C103100 uF6.3 VRadial
C143100 uF6.3 VRadial
ROM Details (credit: rtw World of Arcades)
MX 29LV160BB (Early boards)
Spansion S29JL03SH70TF102 (Later boards)
Main CPU Code, FPGA bitstream sourceU4
Samsung K9F1G08U0MGraphics AssetsU2
MBM 29DL321 (CV-1000B)
MT 46V16M16 (CV-1000D)
Sound AssetsU23
Sound AssetsU24
Source: rtw World of Arcades
Original Cave schematics are unavailable for CV1000.
Buffi collected datasheets on the components used in CV1000.
MAME CV1000 Driverhttps://github.com/mamedev/mame/blob/master/src/mame/cave/cv1k.cpp
Buffi CV1000 Researchhttps://github.com/buffis/cv1k_research
Buffi CV1000 Blitter Researchhttps://buffis.com/research/cv1000-blitter-research/
Buffi CV1000 Replacing U2 with another NAND Flashhttps://github.com/buffis/cv1k_research/tree/main/U2_Replacement
Buffi CV1000 U13 Reverse Engineering and construction of a compatible bitstreamhttps://github.com/buffis/cv1k_research/tree/main/U13_Research
Buffi Espgaluda 2 Repair of Bad U2 NAND Using JTAGhttps://www.arcade-projects.com/threads/espgaluda-2-cv1000-repair-of-bad-u2-nand-using-jtag.19108/
Buffi Research into CV1000 Blitter performance and behaviorhttps://buffis.com/research/cv1000-blitter-research/
Buffi CV1000 CPU Slowdown investigatedhttps://buffis.com/research/cv1000-cpu-slowdown-investigated/
Buffi More CV1000 Researchhttps://buffis.com/research/more-cv1000-research-now-featuring-clipping/
rtw World of Arcadeshttp://www.world-of-arcades.net/Cave/Hardware_SH3/Hardware.htm
System 11 Blog: Cave CV1000 Color ProblemsOffline – Archived on 12/11/2023
Arcade Otaku: Cave CV1000https://wiki.arcadeotaku.com/w/CAVE_CV1000
Gamerepair.infohttps://gamerepair.info/hardware/37_cave_cv1000
Nicole Express: A Last Gasp of 2Dhttps://nicole.express/2022/games-made-in-a-cave.html
Cave CV1000 PCB Serial Number Codes Explainedhttps://cave-stg.com/forum/index.php?topic=1754.0
Irem M92
 Encyclopedia  Comments Off on Irem M92
Apr 132024
Last Updated: 2/12/2025
Article Credit: ShootTheCore, wickerwaka, ekorz, System11, Apocalypse
Main Board
The Main Board is largely identical across all Irem M92 games – the model is M92-A-B.
Early boards have less Object RAM (16K) installed at locations IC43 & IC44 than later boards (64K) – selectable by jumper J2 – but all M92 games are confirmed to function correctly with the 16K board. Thus, the difference in RAM was likely determined by parts cost at the time of manufacture.
Notable ICs
ICFunctionSilkscreen LabelLocation
NEC D71036L V33Main CPUH8
Nanao GA20Sound FX SamplesIC32 GA20B6
Nanao GA21SRAM DMA and Address Generation for GA22IC42 GA21M7
Nanao GA22Graphics RenderingIC63 GA22M10
YM2151FM Sound ChipIC33C6
YM3014Sound D/A ConverterIC208 YM3014C5
Secondary Board
The Secondary Board layout varies across the M92 games.
The Sound CPU resides on the secondary board and utilizes an encryption mechanism – see “Copy Protection” below.
GameBoard ModelNotes
Blade Master / Cross BladesM92-B-A
M92-D-A
Dream Soccer 94M92-B-G
GunForceM92-B-AGame may not boot if the Sound CPU isn’t operational.
GunForce II / GeoStormM92-B-G
HookM92-D-A
In The Hunt / Kaitei DaisensouM92-B-B
M92-E-B
Lethal Thunder / Thunder BlasterM92-C-B
Major Title 2 / The Irem Skins GameM92-B-FOnly M92 game to utilize an EPROM for saving scores.
Mystic Riders / Gun HokiM92-B-B
Ninja Baseball Bat Man / Yakyuu Kakutou League-ManM92-B-G
M92-F-A
M92-Z-B
M92-Z-C
Perfect Soldiers / Superior SoldiersM92-B-GGame will have graphic glitches if the Sound CPU isn’t operational.
R-Type LeoM92-B-B
M92-C-N
Undercover CopsM92-E-B
Fire BarrelM107-B-AGame will freeze at the ROM/RAM test screen if the Sound CPU isn’t operational.
Notable ICs
Nanao 08J27261A1 V35Sound CPUIC10
Nanao GA23ROM Addressing (Assumed)IC23 08J27504A1
Board Variants
M92 boards manufactured for the Korean region have several noticeable differences from boards manufactured for other territories:
  • The green silkscreen is a lighter shade of green.
  • The JAMMA connector does not have a key notch.
  • SRAM ICs on M92 boards for other regions are manufactured by NEC whereas on the Korean boards they are manufactured by Hyundai and Goldstar.
  • The amplifier heatsink is physically smaller, and is colored silver rather than black.
  • One or both boards may be missing markings for the board type on the silkscreen.
  • A metal serial number tag is not present in the upper-right corner of the A Board.
There are also single-board bootlegs of several M92 games. They are much more compact physically than original M92 boards and thus are easily distinguished. Compared to the original games, bootlegs often omit animation frames, shorten the music tracks and gameplay slows down more frequently.
  • The factory-installed capacitors are colored green or brown. The ELNA brand brown-colored capacitors are notorious for leaking and should be replaced ASAP.
  • Video output is darker than average with this hardware.
The Nanao 08J27261A1 V35 Sound CPU on the B Board enforces a security scheme where each game’s sound CPU code is encrypted in ROM and then decrypted by a key specific to the model of CPU. Thus, if the game ROMs are swapped to another game without decrypting the sound CPU code of the new game and re-encrypting the code to match the encryption scheme of the old game, the sound CPU will crash and the game won’t have sound.
Changing jumpers J1 and J6 adjacent to the Sound CPU from “S” to “N” disables the decryption mechanism and allows the CPU to run decrypted Sound CPU code directly.
Capacitor List (credit: System11)
Main Board
C2011 uF50 VECA-2EM010
C202470 uF25 VECA-1EM471
C203220 uF10 VECA-1AM221B
C20422 uF25 VECA-1EM220I
C209100 uF25 VECA-1EM101
C2101 uF50 VECA-2EM010
C21347 uF16 VECA-1CM470I
C2151 uF50 VECA-2EM010
C2161 uF50 VECA-2EM010
C2171 uF50 VECA-2EM010
C2181 uF50 VECA-2EM010
C2191 uF50 VECA-2EM010
C236100 uF25 VECA-1EM101
Resistor List (credit: fuzzbuddy)
  • R201 – 1KOhm
  • R203 – 100KOhm
  • R205 – 4.7KOhm
  • R208 – 4.7KOhm
  • R209 – 2.7KOhm
  • R211 – 10KOhm
  • R213 – 10KOhm
ROM Details (credit: MAME Source, ekorz)
LabelLocationEPROM Part No.Function
H0B Board27C020 (256kb)Main CPU
L0B Board27C020 (256kb)Main CPU
H1B Board27C020 (256kb)Main CPU
L1B Board27C020 (256kb)Main CPU
SH0B Board27C512 (64kb)Sound CPU
SL0B Board27C512 (64kb)Sound CPU
C0B Board27C040 (512kb)Background Tiles
C1B Board27C040 (512kb)Background Tiles
C2B Board27C040 (512kb)Background Tiles
C3B Board27C040 (512kb)Background Tiles
000B Board27C080 (1024kb)Sprites
010B Board27C080 (1024kb)Sprites
020B Board27C080 (1024kb)Sprites
030B Board27C080 (1024kb)Sprites
DAB Board27C040 (512kb)Audio Samples
Schematics (credit: wickerwaka)
Original Irem schematics are unavailable for M92.
wickerwaka developed a MiSTer FPGA core for the Irem M92 platform, and generated the following schematics (Source):
MAME M92 Driver Source Codehttps://github.com/libretro/mame2016-libretro/blob/master/src/mame/drivers/m92.cpp
wickerwaka MiSTer FPGA Sourcehttps://github.com/wickerwaka/Arcade-IremM92_MiSTer/tree/main
System 11 Blog – Irem Games and Leaking CapacitorsWebsite is offline – PDF Archived on August 2017
