Bought 2 boards off ebay the other day, one was Super Street Fighter 2 The New Challengers and the other was this 1944 The Loop Masters.
Both were sold as being faulty.
When I fired this up it gave a solid blue screen.
This is a classic sign that the board has suicided so to make sure I opened it up and inserted my CPS2 test eprom (available from CPS2SHOCK site) into ROM slot number 3.
It loaded up confirming that the board had suicided.
The strange thing was that the battery was still giving out 3.6v but as this was one of two board with the same indicated fault I assume the previous owner had done something silly.
Only the EPROM in slot 3 requires replacing to phoenix this game so with that done and the battery removed I fired it up again.
I would have liked to keep it original but there is nothing I can do about that now.
Kryoflux device
I’m a big supporter of the preservation of old software and hardware and have been following the development of the Kryoflux device for quite some time. For anyone that is not aware of the Kryoflux device:
KryoFlux is an advanced software-programmable FDC (Floppy Disk Controller) system that runs on small and cheap ARM7-based devices and connects to a host PC over the ubiquitous USB connector. It reads (and in the future, will write) flux transitions from floppy disks at a very fine resolution. KryoFlux can read data with no regard for what disk format or copy protection a disk may contain, and it can also read disks originally written with different (and even varying) bit cell widths and drive speeds, with a normal fixed-speed drive.
Last week they finally released the first batch of devices for order and ordered one 5 minutes later.
It came today and its a very neat piece of hardware.
Ive not used this on anything exciting just yet, only a PC floppy disk. Im off to R3PLAY in Blackpool tomorrow so wont have much time to experiment but I shall post more info when Ive learnt how to use it properly.
Dragonball Z 2 Super Battle repair log
Had this board for nearly a year now but the game is so bad I’ve never bothered repairing it until now.
The board itself is pretty clean but the sprites had jailbars through them.
This is quite often a sign of dodgy ROM’s. Several of the MASKROM’s were socketed so I dumped them and checked them against MAME, they all checked out fine. The MASKROM’s are read as 27C160 EPROM’s.
After a little bit of probing, prodding and pulling I believed the fault to be down to the MASKROM at the top right of the board. After inspecting the board under the magnifier I located about a dozen cracked/dry joints. Went over all the solder points on the sockets with the soldering iron, replaced the ROM’s and fired it up. All the graphics were fine and no amount of board flexing could bring the fault back.
Neo Geo Hyper 64 Rev B DIP switches
There is a bank of DIP switches on the motherboard which are not labelled up on the silkscreen and that are not the ones that switch between MVS and JAMMA. I am unable to find a manual that is in english for the Rev 2 boards so after a bit of asking about I have been reliably informed that the manual states these do absolutely nothing and are not used at all.
Lethal Enforcers ‘Justifier’ gun repair log
The Lethal Enforcers guns arrived today.
On testing I found that the RED gun aiming was off a little to the right and the BLUE gun didn’t register a shot on screen but it did register when the trigger was pressed.
I fixed the RED gun simply by removing and cleaning the lens.
When I opened the blue gun a few bits dropped out, the photo transistor and the spring that pushes the trigger back out.
The photo transistor had simply been dislodged.
I cleaned up the solder holes and resoldered the part back onto the small PCB.
I decided to give this lens a clean too as it had a big greasy fingerprint right on the middle of it.
The hardest part of this repair was getting the bloody spring back in place and to keep it there for long enought to put the gun back together. After a lot of bad noise I managed it. Ive taken a couple of pictures just in case anyone else needs to know how the spring actually goes back in.
I retested the guns and the RED one works perfectly but the BLUE one doesn’t register shots fired around the edges. This is usually a common problem with older monitors as their brightness fades over time and the guns fail to register the screen flash. I know this shouldn’t be a problem with mine but I also know that components degrade over time too. I removed the bezel glass from my cab as it is slightly tinted and the BLUE gun now works perfectly. I will probably order a new photo transistor at some point, or possibly a new glass bezel!
