CPS1 Ken Sei Mogura
 General  Comments Off on CPS1 Ken Sei Mogura
Jun 012014
Here is something a lot of people wouldn’t even know existed and those of us that did had given up hope of one being found. As luck would have it though, DrGlitch on the Jamma+ forum located not one but two of these machines here in the UK.
Even better he loaned me the boards to dump and they are currently in the capable hands of Haze who is working on getting this thing running.
Kensei0
Here you can see the usual CPS1 PCB stack.
Kensei1
Whats not normal is that this stack is only used as a video board and the rest is controlled by this
Kensei2
kensai3
We also got the manuals for this thing too.
Its an excellent find and cannot thank DrGlitch enough for loaning me the boards so we can get them dumped.
CPS1 Ken Sei Mogura PAL dump added
 PAL Updates  Comments Off on CPS1 Ken Sei Mogura PAL dump added
Jun 012014
Added the PAL dump from this rare beast. It is marked KNM10B.
Thanks go to DrGlitch from the J+ forum for sending me this board.
 Posted by at 12:37 pm
Pin Toggle “Shield”
 Arduino  Comments Off on Pin Toggle “Shield”
May 312014
The pin toggle PCB I made finally came and im quite pleased with it. I had to make a couple of changes in software to accommodate an error I made but that’s the beauty of having full control via software.
It works well but I wish I had added a reset switch on top and also wish I had given access to a couple of the other IO pins across the top because right now I have to add a link you switch between 20/24 pin devices.
Maybe ill make a revision 2 sometime but I have no real need to do so.
 Posted by at 9:37 pm
Taito F3 cartridge & Juno First bootleg PALs added
 PAL Updates  Comments Off on Taito F3 cartridge & Juno First bootleg PALs added
May 252014
I loaned a couple of cartridges from muddymusic recently.
The F3 carts have a few different PAL chips in them and I have dumped and tested all present in the carts I have. All the chips were unlocked.
I already had a couple of F3 PAL dumps from Twin Cobra 2 thanks to Kevin Eshbach. I have also changed his PAL dumps from game specific to general “Taito F3 cartridge”.
MM also sent me a load of Juno First boards to look at. The original boards use a custom 6809 CPU that uses encrypted opcodes. The bootleg boards use a regular 6809 CPU but have 2 PAL chips to implement the encryption.
There is also a PAL10L8 chip present on the original board (marking are scratched off but is present on schematics), I havent tested yet but I think this will be compatible with the one from the bootleg.
None of the Juno First PALs are tested as the board sets all have issues.
Thanks to muddymusic for lending me his stuff.
 Posted by at 2:56 pm
Dumping Gameking cartridges
 Arduino  Comments Off on Dumping Gameking cartridges
May 182014
Got my hands on a Gameking with 13 games recently.
The Gameking is a bad handheld device from the East and all the games are a ripoff of something already released.
This little project represents the first attempt at I made at dumping a ROM using the Arduino.
It’s also the first time I used the 74HC4040 to generate the addresses. I used these binary counters because they offer 12 outputs and it only uses 2 outputs from the Arduino. They are also tolerant of both 3.3v and 5v so interfacing with different voltage chips is a lot easier.
On with the dumping.
There is a guy called Brian Provinciano that once had a website that contained a lot of nice information about the Gameking. Fortunately it can still be found here
So armed with the pinout this should be easy right? Nope. The physical cartridge pinout is a 2×30 pin affair and I could not find one. Nothing left to do but desolder the original cartridge connector from the Gameking unit itself.
So now I have everything I need. Time to hook this thing up and test it out.
I had each byte spit out to the serial port and then used my makerom.exe program to create a binary file the log file.
The end result looks pretty decent. I can see the header of the file.
I can also see all the game graphics using Brian’s editing tool available from the link above.
Unfortunately that’s as far as I can go with it for now as there are no emulators available. There is one for the NDS but its worthless in terms on usage.
This was a great project that was pretty easy to build.
