Tutorial: CRT Color Calibration for Video Games
 General, Guides, Technical Info  Comments Off on Tutorial: CRT Color Calibration for Video Games
Apr 242024
Last Updated: 4/24/2024
This tutorial is a straightforward procedure for using a colorimeter to calibrate an arcade cab or consumer CRT. Using a colorimeter is perfect for people that want their displays calibrated to a high standard with no “eyeballing it” or guesswork involved.
Display color calibration in a nutshell is precisely matching the contrast, brightness and colors of a video display against a reference standard such that (A) the calibrated display looks the same as other calibrated displays and (B) subtle details in video games aren’t missed due to either color washout (white point too high) or black crush (black point too low).
Up front, here’s some vocabulary words that this tutorial uses:
  • White Point: The measurement of the brightest white your monitor can display.
  • Black Point: The measurement of the darkest shadow your monitor can display.
  • Contrast: Adjusts the White Point of the RGB color guns equally.
  • Brightness: Adjusts the Black Point of the RGB color guns equally.
  • Gain or Drive: Individually adjusts the White Point of each Red, Blue and Green color gun.
  • Cutoff or Bias: Individually adjusts the Black Point of each Red, Blue and Green color gun.
  • Color Temperature: Expressed in kelvins, color temperature is a parameter comparing the color of a light source (ie your display or a light bulb) against an real-world reference light source (ie the sun). Lower color temperatures (< 3000 K) are considered “warm” (red or yellowish) while higher color temperatures (> 5000 K) are considered “cold” (blueish).
    • The abbreviation for 6500 kelvin color temperature is D65 while the abbreviation for 9300 kelvin is D93.
Note that display color calibration is a VERY deep rabbit hole with a lot of information, detail and nuance. This guide is intended for enthusiasts that just want a procedure they can quickly step through to make their displays look nice. There’s much more you can do in addition to what I’ve written up here if you want to be very precise with your display’s calibration.
If you want to delve deeper into the world of color calibration, consider these resources and articles:
This tutorial steps you through a white point balance procedure for your display, but does not cover adjustment of the RGB primary and secondaries since adjustments to those are very specific to each CRT model. Geometry adjustment is also not covered here.
Necessary Calibration Components
  • Laptop or desktop Windows computer to run the Colorimeter
  • Colorimeter to accurately read color measurements off the display
  • Pattern Generator to push accurate calibration images to the display
  • Calibration Software that reads the values from the Colorimeter and displays them to you in a readable format
What I Use
  • X-Rite I1 Display Pro colorimeter – it’s around $30 – $100 used from Ebay.
  • MiSTer FPGA with MiSTercade add-on running HCFR core Pattern Generator and SNES 240P Test Suite – MiSTer HCFR Pattern Generator Download Link
    • Other good choices for a Pattern Generator are:
    • 240P Test Suite running on a game console
    • PGenerator running on a Raspberry Pi
      • PGenerator is a great pattern generation option since it supports 15 khz output for CRTs and the laptop you’re using to read measurements can control it automatically, but it is tricky to setup for the first time. There is an excellent YouTube tutorial by StickFreaks available here: https://youtu.be/D6z0wS5oRoE
    • DVD player running the FreeCalRec601 disc
    • HCFR – the same program that interfaces with the colorimeter – if the display you’re calibrating supports an output resolution that your HCFR PC supports.
  • HCFR calibration software
If applicable, use a color generator that matches what will be connected to your display the most often – ie, if you’ll be running a MISTer FPGA in an arcade cab, use a MiSTer as your color generator.
White Point Reference Selection
One decision you should make before you start is the white point standard you want your display calibrated against.
For retro video games, there are two target white point standards to consider:
  • D65 is considered the standard that US CRTs were calibrated for in the 80s-90s. It is a “warmer” white point and thus the display will have stronger red output.
  • D93 is considered the standard that Japanese televisions were calibrated for in the 80s-90s. Is is a “cooler” white point and thus the display will have a stronger blue output.
  • Choosing one or the other is a personal preference.
    Personally, I go with D65 for displays with US tubes (ie Zenith, RCA, Magnavox) and D93 for Japanese tubes (Sony, Toshiba, Panasonic, JVC, Hitachi)
  • There’s a thorough writeup on D65 vs D93 here: https://www.retrorgb.com/colour-malarkey.html
Procedure
These instructions assume you’re using HCFR as your colorimeter interface software on your Windows laptop.
One-time only software setup
1) Download and install the free HCFR software from here:
https://sourceforge.net/projects/hcfr/files/
2) Launch HCFR.
3) Click on the Advanced menu and choose Preferences.
4) Click on the References tab. Set the settings as follows:
D65 White PointD93 White PointAdvanced Tab
6) Click OK to close the Preferences window.
Technical Note: the values entered for the Red, Green and Blue references in HCFR correspond to the SMPTE-C phospher specification. https://en.wikipedia.org/wiki/NTSC#Colorimetry and HCFR Calibration – Custom Coordinates
Calibrating a display
IMPORTANT NOTE ABOUT TERMINOLOGY
CRT manufacturers often confuse the labeling for Contrast, Brightness, Drive and Cutoff.
“Contrast” is the term for adjusting the White Point level.
“Brightness” and “Black Level” are two interchangeable terms for the Black Point adjustment. I use “Brightness” in this guide, but yours may be labeled “Black Level”.
“Drive” and “Gain” are two interchangeable names for the upper-end Red, Green and Blue color gun adjustments. I use “Drive” in this guide, but yours might be labeled Gain.
“Cutoff” and “Bias” are two interchangeable names for the low-end Red, Green and Blue color gun adjustments. I use “Cutoff” in this guide, but yours may be labeled Bias.
CRT and colorimeter setup
1) Connect your test pattern generator to the display.
2) Power on the display. Display a 100% solid white test pattern.
In the 240P Test Suite, go to “Test Patterns” -> “White Screen”.
3) Wipe down the monitor glass with glass cleaner. Place the colorimeter directly on the glass in the center of the screen. Place a book or something heavy on top of the cable to stop it from sliding or falling off the screen.
4) Wait one hour with the screen on all-white to let the CRT and chassis warm up.
5) Connect the colorimeter to your laptop running HCRF with the USB cable. Launch HCRF.
6) Click on the “File” menu and choose “New”.
7) On the Generator Selection screen, choose:
  • DVD manual: if you’re using a pattern generator that can’t be controlled from the laptop, such as MiSTer HCRF core, 240P Test Suite or a DVD Player.
  • Automatic: if the laptop is the pattern generator and thus connected to the cab display as a secondary monitor.
    • PGenerator will also be detected and used by HCFR when Automatic is selected.
8) Select your model of Colorimeter from the sensor list, select “Do not use a meter correction file” and click Finish.
9) Your meter might now ask what kind of display you’re calibrating – choose “CRT” or “Refresh Display”. Also, Reading Type should be set to “Display”. Click the Calibrate Meter button. Some meters will then ask you to display a white image of 80% IRE or higher. You’re already displaying a 100% IRE all-white screen, so just click OK to finish the calibration.
10) In the main HCFR window that appears, click on the Green Triangle button in the menu bar to start taking readings.
Adjustments – Ideally, you’ll want to do this with the room as dark as possible.
Flyback Screen Dial – Initial Approximate Calibration
Source: https://emphatic.se/?p=710
Archived Copy: PDF
NOTE: If you don’t have straight-forward access to your CRT’s flyback, set each Drive, Cutoff, Contrast, and Brightness setting to the center position and move on to the next section.
1) Set the CRT controls as follows:
  • Each RGB Drive: All the way down.
  • Each RGB Cutoff: Center position.
  • Contrast: Center position.
  • Brightness: Center position.
2) Display a white grid pattern.
In the 240P Test Suite, go to “Test Patterns” -> “Grid”.
3) Turn the Screen dial on the flyback down (counter-clockwise) until the display is completely dark and pitch black. You want to go just past the last trace of the grid.
4) Turn each RGB Cutoff up until you see the black space around the white grid turn into the color you’re adjusting. Then turn it down until the black is perfectly black again.
5) Turn each RGB Drive up until the grid is really white without bleeding out / turning blurry.
Now the CRT is broadly dialed in, we can fine tune the adjustment using the colorimeter.
Contrast and Brightness – Precise Calibration Part 1
Source 1: https://consolemods.org/wiki/CRT:CRT_Color_Calibration_Guide
Source 2: http://www.curtpalme.com/forum/viewtopic.php?t=10457
Archive: PDF
1) Display a 100% IRE test pattern.
In the MiSTer HCFR core, choose “REC601 D65” or “REC601 D93” from the menu depending on which white point standard you’re using. Up and Down on the controller will cycle the IRE level up or down in 10% increments.
In the 240P Test Suite, back out and go to “Test Patterns” -> “100 IRE”. Depending on the console, some control buttons will adjust the IRE level up or down in 10% increments.
2) Click on the 100 Column in HCRF. If the colorimeter isn’t currently taking readings, click on the green Triangle button in the upper-middle of the toolbar.
The “Y” measurement tells you how bright your screen is. Typically, you want it at 100 nits. If you plan to always run your display in a dark setting, you may want to go down to either 95 or 90.
Adjust the SubContrast dial (if you have one; Contrast otherwise) until the Y readout hits your target.
  • If your chassis doesn’t have any Contrast adjustment dials or if you can’t get the Contrast to go high enough to hit your target, try adjusting the Red, Green and Blue Drive/Gain pots evenly upward.
3) Click on the 20 Column in HCRF. Change your pattern generator to display a 20% IRE test pattern.
4) Your target now for the Y value is 0.3% of the reading at IRE 100.
So if 100 nits is your IRE 100 target, 3.0 is what you want Y to read at IRE 20.
HCRF also calculates the target value for you – look at “Y Target”.
Adjust the SubBrightness dial (if you have one; Brightness otherwise) until the Y readout hits your target.
If you can’t go low or high enough try adjusting the Red, Green and Blue Cutoff pots evenly.
  • Note that aged chassis components and tubes may have trouble hitting these high and/or low targets. In that case, just get as close as you can.
5) When you change Brightness, it affects Contrast and vice-versa, so repeat Steps 2-4 until the Brightness and Contrast are balanced against each other with the appropriate Y target for each.
Drive and Cutoffs – Precise Calibration Part 2
1) Click on the 80 Column in HCRF. Change your pattern generator to display a 80% IRE test pattern.
2) Look at the gauges in the lower-left corner of HCFR. The Red, Green and Blue gauges show your levels relative to the target, while the yellow gauge shows your Delta E (deviation) away from the target. As the RGB gauges get close to 100%, the Delta E gauge will drop. Your goal is to get Delta E as close to zero as possible.
Adjust the Blue and Red Drive pots until the gauges are as close to 100% as possible and Delta E is as close to 0 as possible. Adjust Blue first before Red.
Adjusting Green will scew both the Red and Blue levels, so you shouldn’t touch the Green pot unless you can’t get Red or Blue to adjust far enough to reach your targets. You’ll notice as you adjust the Red and Blue levels closer to 100%, the Green will be pulled there as well.
4) Adjust the Blue and Red Cutoff pots until the gauges are as close to 100% as possible. Adjust the Blue first before Red.
Adjusting Green will scew the Red and Blue levels, so you shouldn’t touch the Green pot unless you can’t get Red or Blue to adjust far enough to reach your targets. You’ll notice as you adjust the Red and Blue levels closer to 100%, the Green will be pulled there as well.
5) When you change the Drive pots, the Cutoff target shifts and vice-versa, so repeat Steps 1 – 4, going back and forth between 20 and 80 IRE and adjusting Cutoff and Drive respectively until both of them are as close to 100.0% RGB and 0.0 Delta E readings as possible on the gauges.
Now, the display is pretty well dialed in at this point, but if you’re extra picky, repeat the Part 1 – Contrast and Brightness steps one more time, because adjusting the Drive and Cutoffs will have shifted those values a little bit. If you do end up readjusting Contrast and Brightness, you’ll also have to readjust the Drive and Cutoffs again afterward as well, but none of them will need very much readjustment.
Verifying the White Balance Calibration
If you’d like to check your cab CRT now and see how the White Balance calibration holds up across the gamma range, do the following:
1) In HCFR, click the Green Triangle to stop taking constant readings.
2) Click the Measures menu and choose “Gray scale”, and click Yes at the prompt.
3) The software will prompt you to “set 0% grey level”. Set an IRE 0% test pattern on your generator.
In 240P Test Suite, use the L and R buttons on the controller to set IRE to 0, and click OK.
4) After a moment, the software will now prompt to “set 10% grey level”. Set an IRE 10% test pattern on your generator.
In 240P Test Suite, use the L and R buttons to set IRE to 10, and click OK. Repeat all the way up through the 10 incrementing IRE levels.
5) When the measurement is complete, look at the DeltaE row. Recall that DeltaE measures your variance from the perfect white balance target. If all ten cells are green (Delta E < 2.0) then you’re in good shape – your white balance is approximately on-par with a professional CRT. If some or all of the cells are yellow (Delta E between 2.0 and 3.0) then you’re approximately on par with a consumer CRT. If some or all of the cells are red (Delta E > 3.0) then you’re off target – either the calibration is wrong, your chassis PCB needs servicing, or the color guns in your tube are worn out.
Also, with Gray Scale selected from the drop-down in the upper-left corner, make a note of your Average Gamma and your Contrast Ratio. Ideally, you want an Average Gamma of 2.2 and an Average Contrast Ratio of at least 1000 : 1, but your results will vary based on tube and chassis age, specs, etc.
This post-calibration result of a Panasonic Tau consumer CRT shows some drift at the 90 and 100 IRE levels.
Note that calibration drifts as the tube and caps age – you may want to “tune up” your calibration every couple of years.
Post-Calibration Examples
Seibu Kaihatsu SPI
 Encyclopedia  Comments Off on Seibu Kaihatsu SPI
Apr 182024
Last Updated: 4/18/2024
Article Credit: ShootTheCore, Ikotsu, rtw, Trap15, ekorz, twistedsymphony, channelmaniac
The Seibu Kaihatsu SPI platform was offered in two configurations:
  • Two Board – Main Board and cartridge ROM Board
    • Region locked: Main Board must match country of cartridge ROM Board. This protection can be bypassed – see “Protection Mechanisms” below.
    • Optional Stereo audio.
  • Single Board
    • Only runs the one game that was loaded onto it at the factory.
    • Offered with two different audio setups- Yamaha YM-271-F or dual OKI MSM6295
    • Mono audio only.
This article will address the two configurations separately.
Two-Board Configuration: Main Board
The SPI main board contains all the processing logic to run the game. It was released with two revisions, both of which can run the same ROM game cartridges. The marking on the board for each revision is:
  • (C)1995 SXX2C-MAIN V2.0
  • (C)1998 SXX2D-MAIN V2.1
Stereo sound output is available on the two-board SPI configuration through the CN1 connection header. Everten sells a nice add-on board that adapts the CN1 header to standard RCA stereo audio ports.
https://shewfly.com/products/seibu-kaihatsu-spi-stereo-board-by-everten
https://www.candycabclub.com/product/everten_spi
The video and audio quality is said to be better with the SXX2C-MAIN V2.0 revision.
Source: https://shmups.system11.org/viewtopic.php?t=43308
The SPI system has onboard flash memory used for both region lockout and to store part of the game. The V2.0 board restricts write access to the flash memory by a jumper labeled JP072. The V2.1 board does not have any flash write access restriction jumper.
When swapping game cartridges, you will need to change the jumper (V2.0 only), install the new cart, power on, wait for the game to write to the flash memory (the message “NOW UPDATING. PLEASE WAIT A MOMENT.” will be displayed), power down and flip the jumper back (V2.0 only). Even after flashing, the ROM cartridge must stay attached for the game to operate.
Notable ICs
ICFunctionPCB Label
AM386DX/DXL-25 – OR –
Intel NG80386DX25
25.0 Mhz Main CPUU0169
Zilog Z84C0008PEC7.15909 Mhz Audio CPUU1122
Yamaha YM271-FAudio Processor and Flash AccessU1020
Yamaha YAC513-MAudio DACU1068
Intel E28F008SA – OR –
Sharp LH28F008
8 MBit FlashROMU1053, U1054
SEI400Graphics RenderingU048
SEI600Graphics RenderingU0154
Two Board Configuration – ROM Cartridge Board
Cartridge boards include DIP socket EPROMs, SMD mask ROMs, SRAM and a custom decryption IC – see Protection Mechanisms below. It is not possible to reliably convert one SPI game cart to another at this time, although it is possible to upgrade the same game to a different version (ie Viper Phase One to Viper Phase One NV).
ROM Board model numbers
  • SXX2C ROM SUB
  • SXX2C ROM SUB2
  • SXX2C ROM SUB4
  • SXX2C ROM SUB8
  • SXX2C ROM SUB10
Common Issues and Quirks
CHECKSUM ERROR or HARDWARE ERROR (credit: rtw & Trap15 and channelmaniac)
The two-board SPI platform stores part of the game inside onboard flash storage. The flash storage is also initialized from the factory with a country code. If the country code stored in the first byte of u1053 flash on the mainboard does not match the country code stored in the last byte of the PRG0 EPROM on the ROM cart then you will see the message CHECKSUM ERROR XXXX or HARDWARE ERROR XXXX during the flash process where XX is a two or four digit error code.
It is possible to desolder the u1053 flash chip from the main board to reprogram it with a new code. A list of the country codes is in the opening comments of the MAME driver.
Alternatively, Trap15 developed a software solution named SPI Revive that can rewrite the country code on the mainboard by swapping the PRG0 EPROM on a Raiden Fighters or Raiden Fighters 2 cart. If SPI Revive is unable to change the country code then the u1053 flash chip should be replaced.
SPI Revive: https://bitbucket.org/trap15/spi_revive/src/master/
Source: https://shmups.system11.org/viewtopic.php?t=62636
There have also been cases where the flash chips are holding the correct country code data but the board isn’t reading that data correctly. The Yamaha YM271-F sound chip controls access to the flash storage, so check the connections and traces on it.
Reflowing the solder on all of the large SMD ICs is recommended for HARDWARE ERROR and CHECKSUM ERROR messages if the earlier methods of writing the country code do not resolve the problem.
Credit: ChannelManiac
Boot Failure or Vertical Lines (jailbars) through graphics (credit: twistedsymphony)
It is common for the large SMD ICs to have pins separate from the PCB due to board flexing.
If an SPI board fails to boot at all on a known-good ROM cartridge, try reflowing the solder on each SMD IC, starting with the 386 Main CPU – it seems particularly susceptible to this issue.
If an SPI board has vertical lines running through the graphics, reflow the solder on the two SEI400 and SEI600 graphics rendering ICs.
Single Board Variants
In some regions, Seibu Kaihatsu released some of their games on cost-reduced, all-in-one single boards. These boards are “locked” to the game they ship with, do not have stereo output available, and in some cases use lower-quality dual OKI MSM6295 ICs for audio instead of the Yamaha YM271-F IC that the two-board SPI platform utilized.
  • SYS386I -Raiden Fighters 2 Operation Hell Dive 2000 (AMD 386 CPU and dual OKI MSM6295 Audio)
  • SYS386F – E-Jan Sakurasou (Intel 386 CPU and Yamaha Audio)
  • SYS386H – Raiden Fighters Jet 2000 (AMD 386 CPU and dual OKI MSM6295 Audio)
  • SXX2F – E-Jan Sakurasou (Intel 386 CPU and Yamaha Audio)
  • SXX2G – Raiden Fighters Jet (AMD 386 CPU and Yamaha Audio)
The SPI hardware and games was never bootlegged or cloned by another company.
Daughterboards
The SPI platform only utilized one daughterboard – the SXX2C Mahjong adapter used with E-Jan Sakurasou.
Capacitor List – V2.0 and V2.1 (credit: ekorz)
LocationCapacitanceVoltageDiameter (mm)
C123470 uF26 V10
C051470 uF16 V10
C01210 uF16 V5
C091110 uF16 V5
C092110 uF16 V5
C092610 uF16 V5
C12710 uF16 V5
C121610 uF16 V5
C12110 uF16 V5
C096100 uF25 V6.3
C129100 uF16 V6.3
C1210100 uF16 V6.3
C1214100 uF16 V6.3
C122100 uF16 V6.3
C1215100 uF16 V6.3
C124100 uF16 V6.3
C1217100 uF16 V6.3
C125100 uF16 V6.3
C1219100 uF16 V6.3
Film / Ceramic Resistors – Optional
LocationCapacitanceLead spacing (mm)
C0920182K5
C0923182K5
C0927392K5
C008392K5
C0924222K5
C0913222K5
ROM Details (credit: MAME, twistedsymphony)
Due to the variety of ROM boards used across the SPI games, consult the MAME Driver for game-specific ROM assignments.
The DIP EPROMs can be replaced with a 27C040 EPROM. Replacement of a faulty SMD Mask ROM with an SMD flash might be possible depending on which mask ROM it is.
Sprite data is encrypted differently for each game and paired to a specific sprite data decryption IC on the cartridge board. This proved to be an effective deterrent against cartridge game conversions and bootlegging.
Schematics & Datasheets
Schematics for the SPI hardware are not available.
Additional Resources
MAME SPI Driverhttps://github.com/mamedev/mame/blob/master/src/mame/seibu/seibuspi.cpp
Trap15: SPI Revivehttps://bitbucket.org/trap15/spi_revive/src/master/
Ikotsu: Raiden Fighter Jet – Seibu SPIhttp://ikotsu.blogspot.com/2010/01/raiden-fighter-jet-seibu-spi-jet.html
Everten SPI Stereo Boardhttps://shewfly.com/products/seibu-kaihatsu-spi-stereo-board-by-everten
World of Arcades: Changing SPI region codeshttp://www.world-of-arcades.net/seibu_spi/
Silkworm repair log #2 and schematics
 PCB Repair Logs, Repair Logs  Comments Off on Silkworm repair log #2 and schematics
Apr 162024
Board is a bit dusty but very clean nonetheless. Some very specific chips are rusty, probably due to some rodent fluid. Tracks are invisible and located in the core of this 4-layer board making the inner tracks very fragile when pulling a chip out.
Game starts when powering the board with full sound and some graphics. The title screen has a white background instead of black as it should be. A similar white background appears during attract mode:
Cross-testing the board with a good one points the fault to the bottom board (graphics board). On this board I started probing the 8 EPROMs filled with the background graphics data. Some pins are quite corroded, so I decided to dump them to check their contents against MAME data:
As a result, EPROMs 10 and 14 are dead. I burnt two replacement EPROMs and that brought the background back:
Background is back but the sprites are blinking, they are misplaced and have bad colors. Sprites are generated by the custom chip Mitsubishi M60002-0118P and displayed through twenty 4164 DRAMs. These are known for having a high failure rate. I will focus my investigations in this area:
Probing the D-OUT pins of these DRAMs (pin 14), 8 DRAMs out of 20 shows an output signal stuck low or even floating when the game has to display sprites:
I pulled these 8 D-RAMs:
All of them were confirmed bad out of circuit.
I fit 8 brand-new replacement DRAMs. Some sprite glitches are still visible – two other DRAMs have just gone bad. I took those out and replaced them. Now the sprites and backgrounds appeared to be rendering properly. However, the sprites motion is still jerky.
Rygar shares the same hardware as Silkworm and has schematics available. In the schematics, we can see that two 6116 SRAMs handles foreground and background graphics and a third one is dedicated to sprite positioning (SP/POSITION.RAM as per the schematics). This is the area I will inspect.
Inspection of the SRAM chip at location 6L doesn’t show anything abnormal. While probing around the area, I came across a signal stuck high on a 74LS193 binary counter (BORROW output) located at 7K. I double-checked it with my logic comparator:
Red light indicated a bad output – I pulled the suspect:
Confirmed bad out of circuit:
Replacing this chip fixes the jerkiness. Game is perfectly playable. Sound and controls tested OK.
Summary :
  • 11 DRAMs (SAMSUNG),
  • 2 EPROMs,
  • 1 74LS193 (TEXAS INSTRUMENTS)
Some months after this repair, I found the proper original Silkworm schematics, scanned it and upload to my GitHub here:
https://github.com/DocteurPCB/schematics/blob/main/Silkworm%20%5Bschematics%5D.pdf
New Section – Arcade PCB Encyclopedia
 General  Comments Off on New Section – Arcade PCB Encyclopedia
Apr 132024
I’m introducing a new section of JAMMArcade.net that I believe will be very useful for arcade repair technicians – the Arcade PCB Encyclopedia.
I have long admired the Console 5 Wiki as a comprehensive source of information for video game consoles. A typical console page will have a capacitor list, describe common faults, and collect manufacturer white papers. The JAMMArcade.net Arcade PCB Encyclopedia will attempt to accomplish the same thing for arcade boards.
My goal is to eventually document the following information in one page each for most arcade boards:
  • High quality photos of the boards – both originals and bootlegs
  • Notable ICs and their function
  • Capacitor list
  • Common faults and solutions to those faults
  • Protection mechanisms
  • Schematics and Datasheets
  • Links to other reference resources on the Internet
Given the number of arcade games produced, it may take several years to assemble these resources for every game, but I want to at least start with the most popular and most documented ones.
The Encyclopedia launches today with information on three boards and I will try to write up 1 – 2 more each week – each one takes a while to research!
I highly value credit for the original researchers and strive for proper attribution. Please contact me if you notice any mistakes in the Encyclopedia entries and I welcome other contributors as well.
Sega System 16B
 Encyclopedia  Comments Off on Sega System 16B
Apr 132024
Last Updated: 4/17/2024
Article Credit: ShootTheCore, Furrtech, cpsystem3,Eduardo Cruz, ExodusEmulator, Caius, Frank_fjs, twistedsymphony, Jotego
Main Board
The Sega System 16B main board contains all the processing logic to run the game. The Sega part number for it is 171-5347.
Note that these boards are NOT JAMMA pinout and need an adapter to be properly connected to a JAMMA harness.
Depending on the protection scheme used for the particular game, the Main CPU may utilize encryption, the Sound CPU may utilize encryption, and an MCU may or may not be present – see Protection Measures below for more details.
Notable ICs
ICFunctionLocation
Hitachi FD1094 CPU (encrypted)
Signetics SCN68000C8N64 68000 CPU (unencrypted)
10.0 Mhz Main CPUC9
NEC MC-8123B CPU (encrypted)
Zilog Z8040004PSC Z80 CPU (unencrypted)
4.0 Mhz Audio CPUD15
Yamaha YM2151FM AudioD12
Yamaha YM3012Audio DAC for the YM2151D18
NEC D7759CAudio Speech SynthD16
Sega 315-5195Memory MappingD4
Sega 315-5196Sprite GenerationI4
Sega 315-5197Tilemap GenerationI18
Intel i8751MCU (Copy Protection)B2
ROM Board (credit: ExodusEmulator)
There are four variants of the ROM board used with System 16B:
  • 171-3538: ROMs only. Support for 32K/64K ROMs
  • 171-5521: Banking register added to the middle. Support for 512K/1M/2M ROMs
  • 171-5704: Jumper pins added to control banking. 512K/1M ROMs
  • 171-5797: Adds Sega 315-5250 68000/Z80 mapping interface and an additional banking register. 512K/1M ROMs
Source: ExodusEmulator
Daughter Boards (credit: ExodusEmulator)
There are two daughter boards used with some System 16B games for additional control IO:
  • 171-5437 / 834-6180: Trackball input
  • 834-6523: 4 Player input
Board Variants
The Sega System 16B board was identical between regions for the full lifecycle of the hardware. However, it was heavily bootlegged and thus there is a wide variety of cloned boards. Compared to the original games, cloned boards may have differences in graphics, sound, gameplay and speed. The bootlegs look dramatically different from the Sega originals and are easy to distinguish from the real thing.
System16B boards are NOT JAMMA pinout and need an adapter to be properly connected to a JAMMA harness.
System16B boards draw more power than average, so adjust your arcade PSU accordingly when swapping one into your cabinet or SuperGun.
It is common for the battery in the Main CPU or Sound CPU to die if they are encrypted, causing the game to either not boot or not have sound respectively. See “Copy Protection” below for details and resolution.
It is common for the TL084 OpAmp located at D19 to fail, resulting in faint or garbled audio output. Replacement parts are easy to source.
Capacitor List (credit: Frank_fjs)
LocationCapacitanceVoltagePart No.
C2470 uF16 VECA-1CM471B
C3470 uF16 VECA-1CM471B
C4470 uF16 VECA-1CM471B
C61 uF50 VECA-2VM010B
C71 uF50 VECA-2VM010B
C81 uF50 VECA-2VM010B
C91 uF50 VECA-2VM010B
C10470 uF16 VECA-1CM471B
C16470 uF16 VECA-1CM471B
C1110 uF16 VECA-1CM100B
C1210 uF16 VECA-1CM100B
C13220 uF16 V647-URS1C221MPD1TA
C14100 uF16 VECA-1CM101B
C15100 uF16 VECA-1CM101B
C1947 uF16 VECA-1CM470B
C622.2 uF50 VECA-2AM2R2B
C632.2 uF50 VECA-2AM2R2B
C212.2 uF50 VECA-2AM2R2B
C222.2 uF50 VECA-2AM2R2B
C34220 uF16 V647-URS1C221MPD1TA
C350.1 F5.5 V80-FYD0H104ZF or 80-FG0H104ZF
ROM Details (credit: MAME)
Due to the variety of ROM boards used across the System16B games, consult the MAME Driver for game-specific ROM assignments.
When replacing a mask ROM with an EPROM, consult this reference chart by twistedsymphony:
Sega implemented four different protection mechanisms to prevent arcade operators from swapping one System 16B game to another by installing a new set of ROM chips. Games may implement one or more of these protection mechanisms:
  • 68000 Main CPU Encryption
  • Z80 Sound CPU Encryption
  • Intel i875 Memory Control Unit
  • ROM Board variants
Main CPU Encryption (credit: Eduardo Cruz)
Some games encrypt the 68000 code executed by the Main CPU. Those games use a Hitachi FD1094 CPU, which is a Motorolla 68000 clone with a RAM-based decryption key that matches up with the encryption key used on Main CPU ROMs. If the battery that maintains the RAM storing the decryption key dies then the key is lost and the main CPU will crash at boot – the game will sit at a black screen at boot (“suicide”).
If the battery hasn’t died yet, it can be replaced while maintaining the onboard decryption key if power is maintained to the supply pins with a bench PSU while the old battery is desoldered and a new battery is soldered in.
If the battery has died, you have two options:
Source: Eduardo Cruz
Similar to the Main CPU, some games utilize an NEC MC-8123B CPU with an onboard decryption key maintained by battery-backed RAM, paired with encrypted Sound CPU code in the ROMs. If the battery inside the CPU dies, the decryption key is lost, the Sound CPU will crash at boot, and the game won’t have sound.
Solutions are identical to an encrypted Main CPU – if the battery hasn’t died yet, it can be replaced by removing the cover, powering the battery leads from a bench PSU, and soldering in a fresh battery. If the battery has died, swap the NEC CPU out for a standard 4.0 Mhz Z80 CPU, swap the Sound CPU ROMs out for decrypted equivalent EPROMs, and the game’s sound should then function again.
Intel i875 Memory Control Unit (MCU) Protection
Some games utilized an Intel i875 MCU (or clone) that sits between the CPUs and specifically encrypted ROMs that “scrambles” the memory addressing such that a game won’t function without a matching ROM set and MCU.
Decrypted ROM sets for every System 16B game are available so that the MCU socket can be left empty on the board, and the encrypted mask ROMs can be swapped with decrypted EPROMs to get a fully-functional game.
ROM Board Variants
As mentioned above, Sega utilized four different ROM board variants with the System 16B hardware across the game library. Assuming that no other protection mechanisms were in place, an arcade operator still wouldn’t be able to change one System 16B game over to another one by swapping ROMs unless the same ROM board was used with both games.
MAME documents the ROM board and configuration settings (if applicable) on the ROM board for each game.
Original Sega schematics are available for System 16B, but there seem to be discrepancies between them and the real hardware.
Sega System 16B Schematics
Charles MacDonald wrote up extensive documentation on System 16B’s operations.
Charles MacDonald System 16B Hardware Notes
Jotego authored an FPGA core for System 16B and created a set of schematics for the 315-5195 custom IC in the process.
Jotego 315-5195 Schematics (Link)
Jotego 315-5195 Schematics (PDF)
MAME Sega System 16B Driverhttps://github.com/mamedev/mame/blob/master/src/mame/sega/segas16b.cpp
Eduardo Cruz: Deconstructing Sega’s System 16 Securityhttps://arcadehacker.blogspot.com/2019/10/deconstructing-sega-system16-security-part1.html
https://arcadehacker.blogspot.com/2020/04/deconstructing-segas-system-16-security-part2.html
Eduardo Cruz: Sega System 16 / 18 / 24 / X Security Programming Guidehttp://arcadehacker.blogspot.com/2018/12/sega-system16-security-programming-guide.html
https://github.com/ArcadeHacker/ArcadeHacker_Sega_Hitachi
Exodus Emulatorhttp://techdocs.exodusemulator.com/Arcade/SegaSystem16/index.html
SOLID-orange – Twistedsymphony’s Projectshttp://solid-orange.com/
Jotego System 16B FPGA Corehttps://github.com/jotego/jtcores/tree/master/cores/s16b
