ABI Chipmaster Compact Pro
 General  Comments Off on ABI Chipmaster Compact Pro
Jan 022011
Ive been using this device for a while now but never really mentioned it.
Its a very useful device used for testing digital IC’s up to 40 pin for correct logical functioning. Any discrepancy results in a FAIL result and the fault information is displayed. It can execute various test loops including repeated test until pass, repeated test until fail and permanent loop test, the device can also search for unknown devices providing they are functional.
There is an RS232 port on the device which allows software to communicate with the Chipmaster and upload new software or create new truth tables of your own.
The device can test:
54/74 CMOS and TTL IC’s
RAMs
Interface/peripheral/microprocessor and LSI IC’s
Bring able to test logic, RAM and Z80s if a massive help to me when troubleshooting arcade PCB’s.
The Chipmaster is an excellent bit of hardware but it does have a couple of annoying traits.
Firstly, the screen has a slow refresh and results in ghosting when it scrolls the fail information making it very hard to read properly.
Second, the CompactLink software to upgrade the device does not come with it and is not free. In fact it costs a few hundred pounds which I think is ridiculous considering the cost of the unit if you were to buy it from normal vendors.
I know the software also allows the user to create their own libraries but I believe it should be capable to apply the software updates from ABI for nothing.
There is a JTAG connector inside which I have been tempted to test out but I really see no point at this time.
 Posted by at 10:03 pm
Cabal repair log
 PCB Repair Logs, Repair Logs  Comments Off on Cabal repair log
Dec 292010
Got a Cabal game. It looks like a bootleg but is pretty good quality. The ROM’s match that of the joystick version which is good because it means I can test it properly.
As it turned out, the joystick controls were completely erratic and all over the place. I took the top board off to give me access to the traces from the edge connector.
There is a small daughter board present which is silkscreened with “Joystic Sub”. I removed this and found the likely cause of the problem, several of the pins had broken off.
I cut the pins out that were broken and replaced them as required. Pins 13 and 14 were not connected to anything so I didn’t bother replacing them.
Fired the game up and the controls are working again. Pretty addictive game too.
SNES switchless modchip
 Mods  Comments Off on SNES switchless modchip
Dec 242010
I stumbled across a forum post a while back detailing a switchless mod for the SNES.
A forum member Ikari_01 has reverse engineered the CIC lockout chip and created his own and it is stunning.
I followed these diagrams and burned the latest .HEX from Ikari_01 to a PIC16F630.
The mod works very well so far, am waiting for a few more games to get here and a dual LED.
Ive got some different games coming and will update this post when I’ve finished testing.
UPDATE: I’ve finished testing this mod using 3 of the cheapest games that eBay had to offer, one from each region.
Ive also now hacked away a little at the casing of the SNES so US cartridges will fit in too. Its VERY rough but functional.
 Posted by at 5:07 pm
Wonder Boy 3 Monster Lair bootleg
 General  Comments Off on Wonder Boy 3 Monster Lair bootleg
Dec 232010
I got a bootleg version of Monster Lair which is a massive 2 board set, very badly put together and didn’t play all too well. I had no interest in fixing this game up but after harvesting all the 27C512 ROM’s I found a small daughter board in between the 2 main boards that held the 68k CPU and also an Intel D8749H MCU. I desoldered the MCU and attempted to read its contents, the chip was not bit locked and I got a dump. I also started to read all of the ROM’s. There was 16 in total simply labeled from 1 to 16, unfortunately number 1 was completely dead and couldn’t get a read at all, I did manage to dump all the others though and 3 of them were not recognised in MAME, the rest were matched to Set 1 in MAME.
I did think about submitting this to MAME but without it being complete im not sure if its worth it.
UPDATE: Ive also dumped the PAL20L8 from the same daughterboard.
If anyone wants these files let me know
 Posted by at 11:30 am
Installing a ROM higher than v1.3 in an Amiga 500
 Guides, Mods  Comments Off on Installing a ROM higher than v1.3 in an Amiga 500
Dec 172010
I fixed up an Amiga 500 (not plus) today and wanted to install a newer ROM. I burned v2.04 and v3.1 onto 27C400 EPROMs and installed. I was greeted with a red crash screen which usually means there is a problem with the ROM code/chip.
On a Revision 5 motherboard (which is what Ive got) pin 1 of the ROM is not connected but pin 1 on a 27C400 is address line 17 and should connect to address line 18 of the 68k CPU, which is pin 31 of the ROM socket. Also the ROM needs to be set to WORD mode. The selector pin for this is pin 31 on the 27C400.
To make this all work we need to lift out pin 31 of the 27C400 and solder a link between this pin and pin 21, this gives us a permanent HIGH which sets it to WORD mode.
Finally, solder a jumper from pin 1 of the EPROM to pin 31 of the socket.
This should now boot up without problem
 Posted by at 3:23 pm
