On the motherboard of the System 16B there is a couple of PLDs.
315-5213 is a PAL16R6, mine is locked and im not going to attempt to reverse it
315-5214 is a CK2605 chip which I have dumped and converted it to fit in a GAL16V8 device. I have confirmed this is working.
My friend Runik is currently in the process of creating decrypted ROMs for SEGA games that use the FD1094 custom CPU.
If you are able to test them on real hardware then please give feedback.
To use simply (re)program the relevant eproms with the ones downloaded and replace the custom CPU block with a normal 68000 CPU.
ABI Boardmaster 4000 PAL dump
There is a PAL located at U9 and marked as DEC402 (on my board) inside the BM4000 unit.
I have dumped and tested this PAL.
Without the PAL fitted I got no boot up and an almost yellow looking screen with some lines through it
There has been a bit of work done recently with the bootleg version(s) of Bubble Bobble (Bobble Bobble).
The story can be found over on the Arcade Otaku forums, https://forum.arcadeotaku.com/viewtopic.php?f=26&t=5154
Basically the joaoljr has added the code found in the MCU of the original pcb into the ROMs of the bootleg and it has resulted in what is almost, if not completely perfect Bubble Bobble. Title screen and all is restored.
I did take a picture but it can out horrible so I wont add it but it does work.
Thanks to joaoljr for doing this patch.
I’ve been chatting with Charles MacDonald recently about all things PAL related and have been experimenting with using the ABI to dump combinational PAL’s with 24 pins.
After a fair amount of learning and a lot of trial and error I now have a semi decent way of recreating 24 pin PAL chips.
So, here is my first offering. The last undumped PAL chip from Rainbow Islands.
It is used for some address decoding and lives in a PAL20L8 chip. Its ID is B22-07.
That now makes a full set of PAL’s for Rainbow Islands.
I’ve created this to be programmed to a GAL22V10 device but I can recompile it for a GAL20V8 device if required.
If you try this out please give any feedback you may have.
Thanks to Charles MacDonald for all the help and inspiration you have given me over the last couple of weeks. You have the patience of a saint!
