Cave CV1000
 Encyclopedia  Comments Off on Cave CV1000
Apr 132024
Last Updated: 8/25/2025
Article Credit: ShootTheCore, rtw, buffi, Arcade Otaku Wiki, Alamone, System11, DragonMinded, Mike J Moffat
Overview
The Cave CV1000 PCB has three major revisions: Early CV1000B, Later CV1000-B and CV1000-D.
  • Early CV1000-B
    • Gold plated JAMMA connector
    • 9 Pin connection header mounted on the right side with some boards.
      It is unused with the released games but theoretically could have been used to link two boards together via serial communication since the connector is identical to the serial connector on PC motherboards.
    • P2 connection pin header in the center of the board populated.
  • Later CV1000-B
    • Tin plated JAMMA connector
    • 9 Pin connection header and P2 connection header unpopulated.
  • CV1000-D
    • Tin plated JAMMA Connector
    • Battery for the real-time clock removed
    • SDRAM doubled from 64Mb to 128Mb
The battery in the upper-right corner of the CV1000-B PCB is used to maintain a real-time clock in later games such as Ibara and Pink Sweets. Ibara also displays a clock in one level of the game that matches the board’s clock setting. High scores and game settings are stored in the RTC’s EPROM.
CV1000-D removed the battery – high scores and game settings are stored in NAND instead of EPROM with games running on that hardware.
Notable ICs
ICFunctionSilkscreen Label
Hitachi SH3Main CPUU5
Yamaha YMZ770AudioU22
Altera Cyclone EP1C12F324C8Graphics RenderingU8
Altera CA011CPLD used for address decoding of the U2 flash, YMZ770 audio and RTC 9701.U13
RTC 9701 (CV1000-B)Real-Time Clock with embedded EPROM for saving board settings and high scoresU10
AD8061Color amplifier for the Red, Green and Blue outputU14, U15, U16
Board Variants
Reproductions of both CV1000-B and CV1000-D boards from Chinese sellers began surfacing in early 2024. These reproduction boards can be distinguished from Cave originals with the following characteristics:
  • The JAMMA connector is gold plated. Although early CV1000-B boards (Mushihimesama) also had gold plating on the JAMMA connector, all original CV1000-D boards had tin plating.
  • Via “pinholes” are not visible on the back of the reproduced board.
  • A Cave serial number sticker is not present.
  • Some of the reproduction boards do not have the P4 header in the center of the board populated.
At this time, it is believed that the reproduction boards run the games identically to the Cave original hardware. The major IC parts (CPU, Graphics FPGA, Audio, etc) are the same. The build quality seems to be inconsistent though – many of the repro boards have already needed repairs even though at the time of this writing they are less than one year old.
Board Re-initialization (credit: MAME)
Some games (such as Mushihimesama and Espgaluda II) do not have a high score reset function. Any CV1000 can be reinitialized to the factory default high score and board settings with the following procedure:
  • During boot, hold P1 Right+A+B+C and P2 Left+A+B+C until the startup checks are complete.
Common Issues and Quirks
CV1000 boards draw less power than your average PCB. Be sure to adjust your arcade PSU down when swapping in one of these boards so you don’t inadvertently over-volt the board!
Leaking Large Capacitor
The large capacitor labeled C109 in the upper-left corner that filters power for the sound amplifier often leaks. The part is rated for 2200 uF at 25 V.
Part number MAL216099606E3 has the same dimensions as the original part, while UCX1E222MNS1GS has the same footprint, but a lower height and a more supportive base. Source: System11
Color Amplifier Degradation (credit: System11)
The Red, Green and Blue color amplifiers located at U14, U15 and U16 respectively can degrade over many hours of use, resulting in a pale or incorrectly tinted display. Replacing the AD8061ARTZ color amplifier ICs (datasheet) with fresh parts should resolve the issue. Also note that the Service Menu has a brightness adjustment setting that may need to be changed afterwards.
Missing Red and Blue Colors (credit: rtw and System11)
Switch 4 of DIP Switch block S2 will disable the Red and Green output if it is switched On. If your board has this issue, try flipping that switch Off and On a few times to clean any gunk out of the switch. If that doesn’t help, use a multimeter to check continuity across the switch – if the meter shows continuity across the switch even when it’s disabled then replace the switch block.
VSync Deterioration (credit: TK86079)
The LX240A chip located at U11 handles the VSync signal for the board. On some boards, the chip fails, causing it to get burning hot to the touch, and the game to lose VSync. Sometimes it takes a while (20 minutes from power on) to occur.
The replacement part is Texas Instruments SN74LVT240APW or SN74LVT240APWR with the TSSOP-PW packaging.
Flash Deterioration (credit: Buffi)
The flash chip at U2 is known to suffer from data corruption, causing glitching in the graphics. The chip model is Samsung K9F1G08U0. The CV1000 does a manufacturer check at startup to make sure the flash chip is a K9F1G08U0, and will reboot if it is not. Buffi worked out a way to remove these checks, allowing the U2 flash chip to be replaced with an equivalent from another manufacturer.
https://github.com/buffis/cv1k_research/tree/main/U2_Replacement
Alamone worked out a way to fix graphics issues from deteriorating flash by comparing CV1000 U2 dumps and generating relocated NAND blocks:
https://github.com/alamone/u2_compare
Stuck Control Inputs
CV1000 uses three sets of twin resistor banks and individual 130nF ceramic capacitors as ESD protection between each player control input and the signal pins 176-208 on the SH3 CPU. If a resistor array becomes damaged then a control input may be “stuck” – always on or always off. It’s also possible for an ESD charge to make it through the ESD protection and fry the input line on SH3 CPU – the only resolution then is to replace the entire CPU. You can check the game’s reading of the control inputs in the Service Menu.
  • Resistor Array with 101 marking – replacement part number: 742C163101JP
  • Resistor Array with 103 marking – replacement part number: 742C163103JP
CPU Stuck in a Boot Loop – Nothing on Screen (credit: Mike J Moffat)
If the CPU is stuck in a boot loop, the LED at L6 will pulse every second to a darker color. Ensure that the 32.768 Khz crystal resonator (it’s not an oscillator) located at X2 is intact and functioning. Measurements for the part are 4.9mm X 1.8mm .
Source: https://gamerepair.info/hardware/37_cave_cv1000
Board Does Not Boot at All (credit: Buffi)
If the EPM7032AE CPLD at location U13 fails then the board will not start up. Buffi has devised a replacement bitstream that can be programmed onto a replacement CPLD to revive the board.
https://www.arcade-projects.com/threads/u13-replacement-for-cave-cv-1000-pcb-repair.17007/
https://github.com/buffis/cv1k_research/tree/main/U13_Research
Protection Mechanisms
Game resources are stored on flash chips located at U2, U4, U23 and U24. The U2 and U4 chips can be accessed by the on-board JTAG connector, but U23 and U24 are not on the JTAG bus and can only be rewritten if the chips are physically desoldered and removed from the board.
The U2 flash is a Samsung K9F1G08U0. The games check the flash ID at boot and if it doesn’t match the expected flash model then the game reboots.
Capacitor List
LocationCapacitanceVoltageTypePart No.
C1092200 uF25 VRadialMAL216099606E3
C121100 uF6.3 VRadial
C11439 uF16 VRadial
C12239 uF16 VRadial
C11339 uF16 VRadial
C131100 uF6.3 VRadial
C132100 uF6.3 VRadial
C13339 uF16 VRadial
C139100 uF6.3 VRadial
C140100 uF6.3 VRadial
C14139 uF16 VRadial
C951000 uF16 VRadial
C102100 uF6.3 VRadial
C103100 uF6.3 VRadial
C143100 uF6.3 VRadial
ROM Details (credit: rtw World of Arcades)
MX 29LV160BB (Early boards)
Spansion S29JL03SH70TF102 (Later boards)
Main CPU Code, FPGA bitstream sourceU4
Samsung K9F1G08U0MGraphics AssetsU2
MBM 29DL321 (CV-1000B)
MT 46V16M16 (CV-1000D)
Sound AssetsU23
Sound AssetsU24
Source: rtw World of Arcades
Schematics & Datasheets
Original Cave schematics are unavailable for CV1000.
Buffi collected datasheets on the components used in CV1000.
Additional Resources
MAME CV1000 Driverhttps://github.com/mamedev/mame/blob/master/src/mame/cave/cv1k.cpp
Buffi CV1000 Researchhttps://github.com/buffis/cv1k_research
Buffi CV1000 Blitter Researchhttps://buffis.com/research/cv1000-blitter-research/
Buffi CV1000 Replacing U2 with another NAND Flashhttps://github.com/buffis/cv1k_research/tree/main/U2_Replacement
Buffi CV1000 U13 Reverse Engineering and construction of a compatible bitstreamhttps://github.com/buffis/cv1k_research/tree/main/U13_Research
Buffi Espgaluda 2 Repair of Bad U2 NAND Using JTAGhttps://www.arcade-projects.com/threads/espgaluda-2-cv1000-repair-of-bad-u2-nand-using-jtag.19108/
Buffi Research into CV1000 Blitter performance and behaviorhttps://buffis.com/research/cv1000-blitter-research/
Buffi CV1000 CPU Slowdown investigatedhttps://buffis.com/research/cv1000-cpu-slowdown-investigated/
Buffi More CV1000 Researchhttps://buffis.com/research/more-cv1000-research-now-featuring-clipping/
rtw World of Arcadeshttp://www.world-of-arcades.net/Cave/Hardware_SH3/Hardware.htm
System 11 Blog: Cave CV1000 Color ProblemsOffline – Archived on 12/11/2023
Arcade Otaku: Cave CV1000https://wiki.arcadeotaku.com/w/CAVE_CV1000
Gamerepair.infohttps://gamerepair.info/hardware/37_cave_cv1000
Nicole Express: A Last Gasp of 2Dhttps://nicole.express/2022/games-made-in-a-cave.html
Cave CV1000 PCB Serial Number Codes Explainedhttps://cave-stg.com/forum/index.php?topic=1754.0
Irem M92
 Encyclopedia  Comments Off on Irem M92
Apr 132024
Last Updated: 2/12/2025
Article Credit: ShootTheCore, wickerwaka, ekorz, System11, Apocalypse
Main Board
The Main Board is largely identical across all Irem M92 games – the model is M92-A-B.
Early boards have less Object RAM (16K) installed at locations IC43 & IC44 than later boards (64K) – selectable by jumper J2 – but all M92 games are confirmed to function correctly with the 16K board. Thus, the difference in RAM was likely determined by parts cost at the time of manufacture.
Notable ICs
ICFunctionSilkscreen LabelLocation
NEC D71036L V33Main CPUH8
Nanao GA20Sound FX SamplesIC32 GA20B6
Nanao GA21SRAM DMA and Address Generation for GA22IC42 GA21M7
Nanao GA22Graphics RenderingIC63 GA22M10
YM2151FM Sound ChipIC33C6
YM3014Sound D/A ConverterIC208 YM3014C5
Secondary Board
The Secondary Board layout varies across the M92 games.
The Sound CPU resides on the secondary board and utilizes an encryption mechanism – see “Copy Protection” below.
GameBoard ModelNotes
Blade Master / Cross BladesM92-B-A
M92-D-A
Dream Soccer 94M92-B-G
GunForceM92-B-AGame may not boot if the Sound CPU isn’t operational.
GunForce II / GeoStormM92-B-G
HookM92-D-A
In The Hunt / Kaitei DaisensouM92-B-B
M92-E-B
Lethal Thunder / Thunder BlasterM92-C-B
Major Title 2 / The Irem Skins GameM92-B-FOnly M92 game to utilize an EPROM for saving scores.
Mystic Riders / Gun HokiM92-B-B
Ninja Baseball Bat Man / Yakyuu Kakutou League-ManM92-B-G
M92-F-A
M92-Z-B
M92-Z-C
Perfect Soldiers / Superior SoldiersM92-B-GGame will have graphic glitches if the Sound CPU isn’t operational.
R-Type LeoM92-B-B
M92-C-N
Undercover CopsM92-E-B
Fire BarrelM107-B-AGame will freeze at the ROM/RAM test screen if the Sound CPU isn’t operational.
Notable ICs
Nanao 08J27261A1 V35Sound CPUIC10
Nanao GA23ROM Addressing (Assumed)IC23 08J27504A1
Board Variants
M92 boards manufactured for the Korean region have several noticeable differences from boards manufactured for other territories:
  • The green silkscreen is a lighter shade of green.
  • The JAMMA connector does not have a key notch.
  • SRAM ICs on M92 boards for other regions are manufactured by NEC whereas on the Korean boards they are manufactured by Hyundai and Goldstar.
  • The amplifier heatsink is physically smaller, and is colored silver rather than black.
  • One or both boards may be missing markings for the board type on the silkscreen.
  • A metal serial number tag is not present in the upper-right corner of the A Board.
There are also single-board bootlegs of several M92 games. They are much more compact physically than original M92 boards and thus are easily distinguished. Compared to the original games, bootlegs often omit animation frames, shorten the music tracks and gameplay slows down more frequently.
  • The factory-installed capacitors are colored green or brown. The ELNA brand brown-colored capacitors are notorious for leaking and should be replaced ASAP.
  • Video output is darker than average with this hardware.
The Nanao 08J27261A1 V35 Sound CPU on the B Board enforces a security scheme where each game’s sound CPU code is encrypted in ROM and then decrypted by a key specific to the model of CPU. Thus, if the game ROMs are swapped to another game without decrypting the sound CPU code of the new game and re-encrypting the code to match the encryption scheme of the old game, the sound CPU will crash and the game won’t have sound.
Changing jumpers J1 and J6 adjacent to the Sound CPU from “S” to “N” disables the decryption mechanism and allows the CPU to run decrypted Sound CPU code directly.
Capacitor List (credit: System11)
Main Board
LocationCapacitanceVoltagePart No.
C2011 uF50 VECA-2EM010
C202470 uF25 VECA-1EM471
C203220 uF10 VECA-1AM221B
C20422 uF25 VECA-1EM220I
C209100 uF25 VECA-1EM101
C2101 uF50 VECA-2EM010
C21347 uF16 VECA-1CM470I
C2151 uF50 VECA-2EM010
C2161 uF50 VECA-2EM010
C2171 uF50 VECA-2EM010
C2181 uF50 VECA-2EM010
C2191 uF50 VECA-2EM010
C236100 uF25 VECA-1EM101
Resistor List (credit: fuzzbuddy)
  • R201 – 1KOhm
  • R203 – 100KOhm
  • R205 – 4.7KOhm
  • R208 – 4.7KOhm
  • R209 – 2.7KOhm
  • R211 – 10KOhm
  • R213 – 10KOhm
ROM Details (credit: MAME Source, ekorz)
LabelLocationEPROM Part No.Function
H0B Board27C020 (256kb)Main CPU
L0B Board27C020 (256kb)Main CPU
H1B Board27C020 (256kb)Main CPU
L1B Board27C020 (256kb)Main CPU
SH0B Board27C512 (64kb)Sound CPU
SL0B Board27C512 (64kb)Sound CPU
C0B Board27C040 (512kb)Background Tiles
C1B Board27C040 (512kb)Background Tiles
C2B Board27C040 (512kb)Background Tiles
C3B Board27C040 (512kb)Background Tiles
000B Board27C080 (1024kb)Sprites
010B Board27C080 (1024kb)Sprites
020B Board27C080 (1024kb)Sprites
030B Board27C080 (1024kb)Sprites
DAB Board27C040 (512kb)Audio Samples
Schematics (credit: wickerwaka)
Original Irem schematics are unavailable for M92.
wickerwaka developed a MiSTer FPGA core for the Irem M92 platform, and generated the following schematics (Source):
MAME M92 Driver Source Codehttps://github.com/libretro/mame2016-libretro/blob/master/src/mame/drivers/m92.cpp
wickerwaka MiSTer FPGA Sourcehttps://github.com/wickerwaka/Arcade-IremM92_MiSTer/tree/main
System 11 Blog – Irem Games and Leaking CapacitorsWebsite is offline – PDF Archived on August 2017
Under New Management
 General  Comments Off on Under New Management
Apr 092024
Hi everyone – I’m pleased to announce that JAMMArcade will no longer be shutting down in August as previously posted.
I’ve worked with Porchy to transfer the site over to long-term, sustainable web hosting, and I will also be taking over the reigns as “editor-in-chief” of JAMMArcade going forward. Porchy will continue to host and manage the PLD Archive, and I strongly encourage all of you to visit that page and donate to support the hosting of that site – it’s a valuable resource!
Who am I? My online handle is ShootTheCore, and I’m a lifelong video game enthusiast who first learned how to diagnose and repair arcade boards by reading the logs here on JAMMArcade. I’ve been active in both arcade and console repairs for some time, and even started documenting my own repairs last year at https://www.shootthecore.tech . I’ll be migrating those repair logs over to this site gradually over the next few weeks.
In a nutshell, here is what to know about JAMMArcade.net going forward:
  • This website will continue to operate for the foreseeable future.
  • All of the prior content and downloadable files have carried over.
  • The login accounts that prior contributors used when writing for the site are still active.
  • If you’re interested in contributing fresh content to JAMMArcade.net, please contact me here.
  • If you find any broken links, please let me know.
Thank you for visiting JAMMArcade.net!
[4/9/2024 UPDATE – Site No Longer Closing]
 General  Comments Off on [4/9/2024 UPDATE – Site No Longer Closing]
Apr 032024
After many years of arcade repairs, the time has finally come to hang up my soldering iron and move on. Its probably obvious that my interest in arcade repairs has dwindled over the last few years and with this site still taking up a lot of my space and file count, I think its time to close it down.
It will remain up until August which is when the hosting is paid up to. After this time the site will disappear so if there is anything on here that you want to keep, please make a copy of it before August.
The money saved from this will allow me to keep the PLD Archive Wiki up and running at a reasonable cost for a hobbyist.
Its been a great ride and I’ve loved most of my time in this hobby but the time has come to move on. Thank you to everyone that has ever supported me and this site and I wish you all the very best for the future.
Stay safe
Jon
 Posted by at 8:06 am
