Parodius DA! repair log #1
 PCB Repair Logs  Comments Off on Parodius DA! repair log #1
May 212017
Received this faulty Parodius DA! PCB for a repair:
The fault concerned the graphics, there were jailbars all over the screen :
Clearly the tilemap generation circuitry was involved, this is made of two 4Mbit MASK ROMs and two ASICs that work in parallel : the ‘052019’ generates the address lines and the ‘051962’ receives the data from the MASK ROMs and process them :
The MASK ROMs check reported the two devices @K13 and K19 (containin tiles data) as bad:
The MASK ROMs @K19 was already removed and socketed.I dumped the device and my programmer warned about a poor contact of pin 13 (data line D0)
Replacing it with a 27C400 produced very little improvements, the test still reported the two bad MASK ROMs.This meant the main CPU could not reach the two devices (thru the ‘052019’ ASIC) so I went to do a continuity check.All the address lines should be daisy-chained between the two 4Mbit MASK ROM and the ASIC but I found some broken/bad contacts from the one @K19, whoever replaced the device managed to break some connections.Here the solderside overview:
Here are some close-up  (taken with a microscope) of the invoved pins (pin 1-5-13)
I restored the connections but still got jailbars:
Chcking the data bus of the tiles MASK ROMs I found a bad via which should have tied pin 29 (data line D19) 0f the device @K19 to the near ‘051962’ ASIC (which processes the tilemap data)
Patching it restored completely the graphics.Job done.
 Posted by at 11:22 am
Hi-Lo ALL-LAB base unit PAL dumps added
 PAL Updates  Comments Off on Hi-Lo ALL-LAB base unit PAL dumps added
May 132017
I recently bought myself a Hi-Lo ALL-11 programmer. This unit uses the original ALL-LAB base unit to connect to the outside world and also as a power supply.
Inside there are four PALCE16V8 chip. Three of them are already dumped and are out in the wild HERE
The one at U9 is registered and there cannot be recreated using our usual methods. I suspect this is also why it hasn’t been dumped before.
As the device is a PALCE there is a good chance I could reset the security fuse using my Runfei programmer. This was successful and I was able to read out the fusemap without any issues.
The registered part looks like a 4 bit binary counter and the equations show that too so I am going to mark this as ‘Assumed Working’ for now. I haven’t tested as I really wanted to get the programmer back together for some playing around with.
All the ALL-LAB PAL’s are now dumped and a copy has also been sent to the site above for inclusion.
 Posted by at 2:48 pm
Bells & Whistles PAL dump added
 PAL Updates  Comments Off on Bells & Whistles PAL dump added
May 122017
In the past days I dumped the only PAL from a Bells & Whistles PCB (export version of Detana! Twin Bee by Konami).Original device was a secured PAL20L10 which I reversed and tested successfully  into a GAL22V10.
 Posted by at 6:25 pm
May 092017
This is a very short update which covers the replacement of the VLM5030 Speech Synthesizer chip which Konami used in various games.
https://www.system16.com/hardware.php?id=556
Today my eBay order of 5 x VLM5030 Speech Synthesizer chips arrived in the mail. I only needed one but who knows when the other 4 will come in handy for future repairs.
Removed the old IC. It’s probably not clear from the picture but this IC got very hot at some point. The marks left aren’t as obvious as what I discovered under the 2149s at A19 and B19, I might need to look at those later.
I didn’t have any 40 pin sockets available but I was really itching to try this out so I soldered the chip in anyway.
Cycling through the sounds and playing them in diagnostic mode verified the fix for this. I also ran the game to verify this as well.
Vimana repair log
 PCB Repair Logs, Repair Logs  Comments Off on Vimana repair log
May 062017
Got this pcb from a friend for a repair.
At first it showed a OBJECT RAM ERROR which was fixed by reflowing the custom BCU-2 which had some lifted pins.
At this point the game showed all the sprites with black pixels
After some trials,  I could locate the circuit which draws the sprites.
There are 4x srams 6116,  by piggybacking  sram @12C ( marked in white on the below pic) the sprites were shown perfectly.
After exchanging it, I got another issue
From the above picture it is difficult to see, but on the upper half of the screen, the alternate lines of the sprites were displaced on the bottom side.
I was really puzzled and I was sure that something else got broken in the meanwhile.
After some days of blindly checking other parts of the circuits, I decided to probe the address pins of the very same sram I exhanged.
A10 and A9 were tied to ground on all 4 srams of the sprite circuit, while only A8 was floating on the sram @12C
The address pins were connected to some 74LS157 and all were working correctly.
That meant the trace A8 was somewhat broken underneath.
Fortunately I had another Vimana from which I noted to which 74ls157 output A8 was connected.
After fixing the connection, the games was 100% fixed
