CP System 1.5 (Dash) – Cadillacs and Dinosaurs
 General  Comments Off on CP System 1.5 (Dash) – Cadillacs and Dinosaurs
Feb 162011
Got my first CPS Dash game today.
Its Cadillacs and Dinosaurs and has been modded so as not to suicide.
It looked like a conversion as the label is not the proper one and there is a genuine Slam Masters sticker underneath it (which I have removed and scanned) but inside all of the MASKROMs are genuine Capcom Cadillacs ones so looks like the case might be a donor.
The CPS Dash games are middle ground from the CPS1 and CPS2 boards. They have a case, it has a built in fan, Q-Sound is used and there is separate line out audio.
The boards are similar to that of CPS1 but the A board has been stripped of its audio section and this is now located on a new B board which has the Q-Sound chips and in this case, a suicide battery that when it dies it takes the sounds with it.
The C board on this is what has all the game ROM’s on it and the small D board is what is the C board on the CPS1 games. This D board also had a suicide battery on it. Phew!
No suicide mod
CPS2 volume fix
 PCB Repair Logs, Repair Logs  Comments Off on CPS2 volume fix
Feb 122011
I have been looking for a fault on a CPS2 A board today. There was no volume coming out to the JAMMA connector but there was from the line out connectors (Stereo Q sound).
I couldn’t really find anything wrong as I had proved the on board amp was working.
I entered the test menu and it reported the volume was up full so I started to turn it down, when I got half way down the volume bar disappeared and the volume reported being set at 0. When I started to turn the volume up again the sound was back and it works perfectly.
Not sure what this was all about but its certainly something to keep in mind before I start poking around with a similar fault again.
CPS2 A board repair log
 PCB Repair Logs, Repair Logs  Comments Off on CPS2 A board repair log
Feb 052011
Very small repair.
I have finished making up plugs for various kick harnesses which makes it nice and easy to swap out games. I started playing my Street Fighter Zero 2 game and the sound was far too loud, when I tried to enter the test mode I found that none of the buttons on the A board worked.
I opened the case and found that the buttons had seen better days.
The buttons are normal SMD push buttons. The Capcom ones have a fifth leg which is just grounding the case of the push button and the ones I have as replacement one have 3 but since the buttons are activated via plastic switches I’m not too bothered.
Id already replaced the TEST button when I took this picture.
Changed all 3 and tested the board. The volume can now be set to a normal level.
Bubble Bobble PCB
 General  Comments Off on Bubble Bobble PCB
Feb 022011
Got a bootleg version of Bubble Bobble (Bobble Bobble) today. All is fine but the Red and Green signals were switched around. Its not a massive problem at all and anything is possible with all the different bootleg boards that were produced for this game.
As it is all working now I wont look into this but its worth mentioning.
Here is the pinout for this 56pin bootleg version. The same as the one floating on the net but with Red and Green switched
 Posted by at 4:57 pm
Teenage Mutant Ninja Turtles – Turtles in Time repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Teenage Mutant Ninja Turtles – Turtles in Time repair log #1
Feb 012011
Got this TMNT2 board today cheap because it had a fault of slight graphics corruption.
The intro sequence was a bit of a mess and was very responsive moved.
I ran the built in MASKROM tests and 3K and 3L came us a BAD.
As one of the ROMs was socketed I removed it tried to dump it, I got a positive match from ROMIdent. As a little test I powered the board up without the ROM in and ran the test again, this time 3K showed up as BAD (it was removed) but 3L showed as GOOD.
I then corrupted the same ROM file in MAME and ran the MAME version, I had managed to reproduce my fault.
After much probing and head scratching I found that the enable line of ROM 3K must have a break in it under the solder mask of the PCB and was quite intermittent. This line is “active low” and when it goes open circuit (or dead) the chip enables and corrupts the data being sent as both 3K and 3L are sending their data together.
I traced the line back to its source which was pin 8 of a 74ALS04 at location 18F. I have ran a link from here to pin 12 of the ROM and the board now plays perfectly and passes all tests.
