Have just finished dumping the other 2 PAL chips from a CPS2 B board.
They are:
BGSB1 and
BGSB2
Both have been tested on my Japan X-Men Children of the Atom board
The BGSB3 PALs (F and G) are already available for download.
As I continue to test out the PAL dumping, I’ll put the confirmed working ones up for download.
Here is PAL B04-12 PAL from a Taito Rastan board.
I have tested this and seems to work fine.
Using the program that can be found here, I have successfully managed to dump a protected combinational PAL chip. The chip was one from a Street Fighter 2 C board and although it is already in the MAME set I wanted to test it againt something I knew was working.
To get this working a terminal emulator program is needed to capture the serial data. I used the free PuTTY program.
Once you have captured all the data and converted it using the PD.EXE program found in the link above, you can use WinCUPL to output a .JED file that can be used to create a functional GAL.
All credits goes to Charles MacDonald and Macro.
Been looking for one of these for a little while now and finally managed to get my hands on one.
While this is by no means an essential bit of test equipment, it is a massive time saver when it comes to troubleshooting TTL as it can test in-circuit.
Programs can also be written for it using the built in BASIC language and is very simple to use.
Before This got here I started looking for info on the net and to my surprise I found very little. All I found was the programmers manual and the last software revision.
As mine came with the operators manual I have scanned it in and put it up on here.
The software revision in mine was v3.00. The ones I found online were v3.10 and the changelog showed this was most likely the last revision and had several TTL test fixes so I updated mine. The files are burned on to 2 x 27c020 EPROMs. There is also a third file that is a dump of the LCD software. My version (v1.02) was the same as the one in the file.
The time and date are stored in a Timekeeper RAM in which the battery has died on mine. There is a replacement alternative but taking a look inside I dont think ill bother. It doesnt really gain me anything and cant be bothered removing the board and performing surgery.
Another little problem is the built in cooling fan. It really really loud. According to the specs of the fan, it runs at about 31dB. I have now ordered a quiet fan that runs at 16dB.
Other than that, this thing is amazing and in really good condition too.
Number 3 of the 5 I brought back from RCM.
This one ended up being a bit of a pain.
Black screen at power up. Removed PLA but didn’t have an original spare I could swap out so it was time to use the CPLD based replacements I have.
Now the 64 boots up but sometimes gave garbage on the screen and sometimes gave the normal boot screen but with 6336 bytes of RAM.
My initial thinking was a RAM fault so went round all the RAMs and doing a thorough soak test on them but it yielded absolutely nothing.
I plugged in my diagnostic cart and it would flag up a different RAM as being at fault each time. This suggested that the 74LS257 data selector for these RAMs was shot. I removed U13 first and it failed its tests. I replaced this with one from another C64 I had and all is well with this one too.
As Ive been using a couple of these 64’s as donors I now find myself unable to do anything with the remaining 2. Ive got some RAM chips coming but will have to keep an eye out for some VIC replacements.
