Homemade C64/C128 power supply
 General  Comments Off on Homemade C64/C128 power supply
Oct 072011
I recently won a Commodore 128 on eBay. It had no power supply and was therefore “untested”. In eBay terms this means its broken.
I know I shouldn’t have tried but in my haste I attempted to use my C64 supply. This resulted in one dead C64 power supply.
As the original C64 supply is pretty poor and a C128 supply is impossible to find for a decent price I thought I would build my own.
For a total cost of around £35 I bought a 5v power supply and a 9VAC transformer. Both of these are massively overspecced compared to the original and they will both fit into the case of my old “lightweight” Amiga power supply case.
I used the old Amiga lead as the connector for the C128 and reused the C64 lead from my newly burnt out supply to give me 2 separate outputs and it is capable of running both at the same time with room to spare.
 Posted by at 6:56 pm
Commodore 128 repair log #1
 Computer Repair Logs, Repair Logs  Comments Off on Commodore 128 repair log #1
Oct 072011
Got a C128 off ebay for a decent price. Came with no power supply and sold as untested. This usually means its knackered and after building a power supply I can confirm it was indeed knackered.
First job, the visual inspection.
The C128 doesnt follow a standard IC orientation but the silkscreen is clearly marked.
Found one of the CIA chips in the wrong way.
I replaced this and carried on.
There was a bit of jumper wire running from JP7 to the Char ROM. From the schematics it looks like this is to set the char set between 128 and 64 mode.
I think this 128 was being used solely as a C64, what a waste. Fixed this to stock configuration.
Probing the Z80 there was no activity. Found the Z80 had no clock signal. Traced the clock from the VIC chip to a 74LS07 @ U60. All inputs were present but the outputs were missing. Replaced this to return the clocks.
Still no activity on the data bus.
Pulled the Z80 and tested, it was faulty. Replaced this.
Switched on and was greeted with a screen of garbage but the green border was now present. This can be a dead CIA so I swapped ICs U1 and U4 and the 128 booted straight into MONITOR mode and kept displaying DSAVE.
This can also be a symptom of a bad CIA so I fitted a known working one and it booted up to the 128 basic screen but the cursor was moving around on its own and some of the keys didn’t work. Looks like the other CIA is knackered too. Fitted another known good CIA and the 128 is fully working.
 Posted by at 6:51 pm
Century Video System PAL dump
 PAL Updates  Comments Off on Century Video System PAL dump
Oct 042011
Dumped the unprotected PAL10L8 on my CVS motherboard. The board is not working but since the chip was unprotected im assuming its OK.
 Posted by at 5:07 pm
Commodore 64 ‘breadbin’ repair log #4
 Computer Repair Logs, Repair Logs  Comments Off on Commodore 64 ‘breadbin’ repair log #4
Sep 282011
This is the last of RCMs C64s that was in need of repair.
I spent many hours on this one.
First issue was the screen was just black. I originally went down a completely wrong route with this as my logic probe was showing missing signals the MC4044 however looking at these pins with the scope showed they were indeed there just at a level the probe didnt like.
Turned out that the previous owner had got the Kernel ROM and the Char ROM switched! Switching these back brought up a screen full of coloured garbage.
With my homemade test cart inserted I eventually was pointed to a potential problem with RAM U9. Knowing how inaccurate this test cart can be I wasnt totally convinced but I pulled it anyway and it was indeed faulty.
I replaced this and everything came back normal minus a cursor. I switched the 2 CIA chips and the cursor returned. Fitted a new CIA and ran the tests again. Everything now passes except for the SID chip but I already knew this was dead.
Im glad this one is fixed, I put a lot of time into it.
 Posted by at 5:38 pm
Volfied & Crude Buster PALs
 PAL Updates  Comments Off on Volfied & Crude Buster PALs
Sep 172011
Andreas has sent some more dumps, this time from Volfied IC’s 63, 64 and 65.
These are in PAL format and will required converting if to be used on a GAL
I also dumped some Crude Buster PALs I had.
These were taken from a non working board and TC-4 and TC-5 (registered) were both protected.
Although the board was non working I am making an assumption these will work. Please let me know if they dont.
 Posted by at 5:25 pm
