BINman (formerly Byteman) program
 Downloads  Comments Off on BINman (formerly Byteman) program
Jul 262012
Some long term readers may recall some time ago I made a program called Byteman.
It was a simple program written in VB.NET and it allowed the user to quickly and easily interleave, deinterleave and byte swap binary files.
I use this program a lot and was starting to get a little frustrated with its bugs so I finally recovered the source code from my laptop and gave it some much needed attention.
Anyway, its done and its more useable than before. Ive also removed the silly online update checking routine as it could get slow.
Ive done my best to remove any major bugs but I don’t doubt there will be some left in there.
DOWNLOAD BINMAN
You will need .NET Framework V4.0 to run it
 Posted by at 6:15 pm
Progear “decrypted bootleg” fix
 Mods  Comments Off on Progear “decrypted bootleg” fix
Jul 252012
There was a forum post on the J+ forums today asking why his Progear fails the ROM checks in the test menu.
This reminded me that I had made a little fix for this a while ago so thought Id write it up.
NOTE: No modified ROM’s will be available for download on my site but instructions to help DIY are here
The ROM tests fail on this version of the game because it looks like this version was once the Phoenix edition but has been hacked a little to remove the Phoenix screen at boot up. Since Razoola already fixed the checksum value in his releases, the modification changed the end result slightly which make the test fail.
So, basically I started off looking at disassembly of the code.
The code that checks the ROM’s is at location $395c
The checksum loads the first HEX value into a register then sequentially adds the rest of the HEX values into it. The final result will be the ROM checksum.
It looks like Razoola also modified the code to incorporate a more thorough test routine. The original started its checksum after the point where the expected checksum value is stored where as Raz’s code checks the whole thing.
This left me with a couple of ways to modify the code. I could either revert back to starting the checks after the stored value or I could add some filler values in an unused section of ROM in order to modify the final value.
I chose the first method for no particular reason.
The start address of the checksum is defined at address $3962 and original reads LEA ($1, A0), A0
This loads address $1 into register A0 as the starting address.
I changed this to read LEA $FFF, A0
Now the game will pass its tests on ROM 0. The same process was used to fix the ROM 1 issue too.
 Posted by at 7:16 pm
Spectrum +2a composite mod
 Mods  Comments Off on Spectrum +2a composite mod
Jul 152012
Having recently obtained my +2a and suffering the poor quality that RF gives, coupled with the pleas of my good friend Mr Stiggy to somehow get a composite output I set about making this simple yet extremely effective circuit.
The TEA2000 chip actually gives a composite output on pin 6 which is nice. I also think that this signal goes right into the RF modulator but I couldn’t get any picture to appear from that so this circuit is no more than a small amplifier of that composite signal.
My veroboard design is sloppy and rough with no coordination of wire colours what so ever but it works very well and im happy with it for now.
The audio present on the same signal line causes quite a bit of distortion in the picture. To remove that just remove capacitor C24.
I then went on to cut the board down and also removed the RF modulator altogether to end up with this
Im going to order a PCB mounted socket and fix the board in place somehow and this will be fully usable. Audio output is now provided by the audio jack to the right next to where the old RF output was.
 Posted by at 12:09 pm
Jul 142012
This came up on eBay the other day and thought I may as well have a go at repairing it.
According to the listing it failed its startup tests and the picture showed this too however when I got it, it passed all startup tests no problem.
So, here is what I was getting at first boot up
Picture is upside down and garbage on the screen during game. There is also no music but SFX are present.
I removed and reattached the ribbon cables and that gave me this
The video board on this has been messed with before with some pretty bad soldering and not so great wire links added.
There are a couple of points here that are completely trashed, luckily though these are not used so I can ignore them. I removed the links and remade them which brought the screen the right way round again and fixed some colour issues.
There is now clearly a problem with the sprites, every other line is missing. I recalled that my friend Elgen had the very same issue on his bootleg board so asked him what lines he patched. He sent me some pictures but unfortunately it wasn’t my issue. It did however point me to the correct part of the board.
At location IC84 is a TMM2018 RAM. I noticed when my hand was near this chip, some of the missing lines on screen would appear. Checking the outputs from this RAM revealed some weak signals.
These outputs fed into the 2 chips that Elgen had pointed out to me so that confirmed what I was seeing.
I removed the RAM and replaced it with a 6116 I had which then gave me this
All graphics problems sorted. Now onto the music problem.
Going from previous experience I knew where to look.
The YM2151 is responsible for our nice FM sounds. I could see the inputs pulsing away but the outputs at pins 19,20 and 21 were all stuck high. Replacing this gave me that oh so familiar music.
Job done
 Posted by at 12:32 pm
Spectrum divIDE repair log #2
 Computer Repair Logs, Repair Logs  Comments Off on Spectrum divIDE repair log #2
Jul 092012
Another divIDE repair today.
Very simple, with the device connected I got this
As Ive found with all of the divIDE boards that Ive repaired the EEPROM was blank. A re-flash sorted this problem out.
There is apparently a reason why this keeps happening and has got something to do with the way the Spectrum regulates power at startup.
 Posted by at 4:38 pm
