Jul 172015
Im currently working on a Time Pilot PCB and tested out Shoestrings diagnostic ROM.
This board is the Atari version which wasnt supported at the time but has now been updated.
I also ran into a problem where nothing appeared on the screen. Working together we eventually found the issue.
The original game code makes a write of 01 to address $c308. Using the Fluke 9010 I found that this write actually initialises the screen output.
MAME doesnt have any support for this so when testing the ROM in MAME it works fine. The test ROM has been updated with this now too and should work fine.
This highlights the need to test things on REAL hardware.
Thanks to Shoestring for making the diagnostic ROM and for putting up with all my questions.
 Posted by at 5:04 pm
Block Hole repair log
 PCB Repair Logs, Repair Logs  Comments Off on Block Hole repair log
Jul 142015
Got this Konami Block Hole (export version of Quarth) from my friend ‘mastercello’ :
Block_Hole_PCB
Board was marked with “sprite issue” and indeed it’s what I got once fired it up:
sprites_issue
Some sprites (like main ship, see the above picture) were garbled and totally wrong.There are eight 27256 EPROMs containing all the sprites so I went to probe them with a logic probe and I found that the common address line A10 (PIN21) of four of them was not prperly toggling compared to the healthy lines A9 and A8 for example.This was confirmed also by my logic analyzer:
A10_address_lines_analysing
I was able to trace this faulty address line back to the sprites generator ASIC marked ‘051960’:
051960_ASIC
So my suspects was that this ASIC would address the four sprite ROMS wrongly due its weakened address line.To confirm this I lifted the involved pin:
051960_lifted_pin
and its behaviour was the same as before when connected to sprite ROMs (on the left the an healthy address line, on the right the faulty A10)  :
address_lines_comparing
At this point, I was pretty sure the ASIC ‘051960’ was faulty in this address line so I played the card of replacing it:
051960_replacing__
And I was right, this restored graphics completely.Board 100% fixed.
fixed
 Posted by at 10:16 pm
Jul 112015
JAMMArcade.net is 5 years old!
I never would have thought 5 years ago that this blog would still be going today let alone be the project that it turned into.
Here is a brief history of the how this whole thing started.
It originally started out as a way for me to document my journey into building a home arcade and maybe provide other new starters with some basic information.
The arcade collecting part never lasted too long as the repair bug hit me and I ended up preferring repairing boards over actually playing them. This is where my obsession with PAL’s also started.
I found it really annoying that an otherwise good PCB had to be scrapped because one little 20 pin IC was dead and the code contained within it was lost. On my search for elusive JED files I found a small ZIP file with a few dumps in it and I also found a few more on Macro’s website. The later is where I read about a device called the Boardmaster 4000 which was apparently able to dump PAL chips.
I eventually found a Boardmaster on eBay (back when a bargain could be found) and that’s when I started dumping PAL’s. I dumped pretty much everything I had and around the same time started the Archive on this website. Pretty soon I started to think “what if the Boardmaster breaks down?”
The Boardmaster program was heavily based on the work of Charles MacDonald who had built a standalone device.
I had soon built his PAL dumper hardware and was ready to stop using the BM4K for dumping.
Shortly after I started adding PAL dumps I started getting people send their own private collection of JED files and the list started growing. Caius was one such donator and was sending them on a regular basis. It made sense to me to ask him to join my crusade so he did and now we have an excellent repository for PAL dumps, something which we are both very proud of.
I cant recall the exact date but it seems quite a while ago now that Runik joined the site.
After trying unsuccessfully to get the decrypted code for his Golden Axe game via the usual channels, he took it upon himself to learn how to decrypt the games. Not long after that he managed it and I guess there is little else to tell of that story.
More recently a few more people expressed an interest in contributing to the website and I’m very happy with it. There is a ton of information on it and having multiple people posting repair logs really does show how different people approach problems and faults. While its rare that a repair log will be the exact same fault a different person may have, it can at least give others ideas on how to start doing repairs of their own.
I’d like to make a special mention about Shoestring’s excellent self test ROM’s for Konami games and also his Konami-1 assembler.
That’s about all there is to say. I hope we are still going in another 5 years.
Thanks to all the people who contribute to the site and everyone that visits.
Special thanks goes to Charles MacDonald who without I would have never been able to start dumping PAL’s and is often the source of help when I’m trying to make sense of things.
Also a massive thanks to Muddymusic who has hosted this site for the last 12 months when my old provider, Servage.net, decided they couldn’t be bothered to deal with issues on their own servers.
So what’s in store for the future?
No idea really. Hopefully most things will carry on the way it has been.
I do a lot less repairing these days and focus more on the electronics side of things (arcade/retro related).
I recently made a homebrew cartridge for the GameKing handheld system in order to test the dumps myself and Team Europe have made.
I also teamed up with cmonkey not too long ago to make a mod for Outrun which saw the two new tracks found in the newly released 3DS version make their way into the original arcade version. cmonkey did the software side of things and I handled the new bankswitching that was required and also made the ROM adapter for it.
Other ongoing projects I have are a completely over the top supergun and I am also working on a couple of cabs too.
Hopefully the rest of the team continue to contribute and expand the site further.
 Posted by at 8:00 am
Raiden DX repair log
 PCB Repair Logs, Repair Logs  Comments Off on Raiden DX repair log
Jul 102015
Another board from my friend ‘mastercello’ and another quick fix.
We have on the bench a Raiden DX (Seibu Kaihatsu) PCB in  good shape:
Raiden DX_PCB
Board booted but colors were wrong and sprites colored blocks:
issue
This Seibu hardware doesn’t use many components since most of logic has been condensed in some custom ASICs which have mostly graphics functions so I focused on them.Like I usually did I probed the tightness of each pin with a small needle and found some lifted pins of the one stamped  ‘SEI252 SB05-106’ (QFP208 package).
SEI252
A simple reflow did the trick and fixed graphics completely.
fixed
 Posted by at 10:47 pm
SEGA and Taito PAL dumps update
 PAL Updates  Comments Off on SEGA and Taito PAL dumps update
Jul 102015
Some PAL dumps update today.Porchy succesfully reversed into GAL16V8 format a dump (made by be some time ago) from a PLS153 device labeled ‘315-5244’ which, as far as we know, is present on Sega System16A hardware (Shinobi and Passing Shot for sure) and should be identical to the ‘315-5150″ one from Fantasy Zone (always on System16A).’Spectroman’ succesfully tested this dump on his Fantasy Zone PCB.
Andreas sent in an archive containing all the PLDs from a Taito Midnight Landing PCB (a flight simulator).All PLDs were unprotected PAL16L8 and PAL20L8 (except one PAL16L8 @IC54 which secured so was not dumped) and came from a not working board.So, we will mark them as untested.Drop us a line if you have any chance to test them.
Thanks to all for their precious contributions.
 Posted by at 3:14 pm
