Exzisus repair log
 PCB Repair Logs  Comments Off on Exzisus repair log
Nov 212015
I bought this pretty rare Exzisus PCB as faulty from our member Corrado:
Exzisus_PCB_
For the uninitiated it’s horizontal scrolling shooter arcade game released by Taito Corporation in 1987.There are two PCB version, one not JAMMA with separate RGB outputs for background and sprites, the other with a single video outputs and is JAMMA compliant.The one I got was the latter.
Once powered the board up I immediately noticed two issues : all sprites were horizontal lines shifted and repeated on each half of screen :
sprite_issue
and  sound was missing at all (although I could hear some noises sign that amplifier was  good).Studying a bit the hardware, I could figure out how sprites were drawed.The four sprite EPROMS are addressed by a custom, marked ‘TC0010VC’ (there is another one for the backgrounds) while the data were written on two 6116 RAMs which were addressed by the same custom but not directly but through two 74LS273 latches and four 74ALS169 counters:
sprites_circuitry
Probing the latter with my logic comparator I got troubles on the outputs of three of them so, although false readings are quite common for this kind of device I decided to remove them.Tested in my BK560A they all failed:
74LS169_testing
Once replaced these counters, the sprites were correctly restored:
sprites_restored
So I could focus on the sound lack.Connecting an external amplifier to the analog output of the YM3012 DAC I could hear all the sound as well as on the input of the near TL074CN OP-AMP but nothing on its output :
pre-amp_section
This was confimed also on my analog scope (good input on the left, no output on the right):
TL074CN_compare
Fitted a new TL074CN @J21 restored full sound.End of job.
 Posted by at 9:47 pm
Thunder Hoop PAL dumps added
 PAL Updates  Comments Off on Thunder Hoop PAL dumps added
Nov 202015
Today I’ve dumped the PALs from an original Thunder Hoop PCB (a weird and funny platform game by Gaelco).Devices were four unsecured GALs (two GAL16V8A and two GAL20V8A) so I could read them in a normal programmer and successfully test dumps back on board.
 Posted by at 9:02 pm
Point Blank repair log
 PCB Repair Logs  Comments Off on Point Blank repair log
Nov 182015
I bought this faulty Point Blank PCB for cheap on Ebay:
Point_Blank_PCB
Seller said it had graphical corruption and was missing a primary color and sound.When I powered it up I actually had sound but the other two issues were there:
issues
The missing color was the green, tracing the pin 12 solderside back from JAMMA connector I found the culprit : one of the three SMD transistor ( each of which drives a color output) was missing:
missing_green_transistor_
Green was so restored :
green_fixed
but graphical troubles were still there.Inspecting the board I found that some pins of the custom C355 were smashed:
C355_closeup
This custom handles the motion objects (sprites) and my issue concerned this part of graphics.Having a spare Namco NB-1 board I opted for a replacement of this ASIC :
C355_reworking_
After some work and pads rebuilding, I ended up with this result:
C355_replaced
In this way graphics were completely restored but sprites had jailbairs:
sprites_jailbairs
Pressing down the board fixed the issue temporarily, inspecting again the board revealed a liften pin on a TC51832 (62256 compatible)RAM @12R:
TC51832@12R_lifted_pin
Resoldered the pin and board 100% fixed.
 Posted by at 10:30 am
Terra Force (bootleg) PAL dumps added
 PAL Updates  Comments Off on Terra Force (bootleg) PAL dumps added
Nov 162015
Today I dumped the PALs from a bootleg of Terra Force.Original devices were two unsecured PAL16R4 whose dumps I successfully converted (using PALtoGAL utility) and tested into GAL16V8 targeting devices
 Posted by at 11:05 pm
Nov 122015
Not a real repair but just a quick “dirty” fix for this Konami Teenage Mutant Hero Turtles PCB :
TMHT_PCB
All was fine but  the music played at the start of a game (when turtles jump from palace) was missing :
A usual I started my troubleshooting with a visual inspection and I found soon the culprit.One of the two 640KHz ceramic resonator was missing:
RSCN0784
I took it from a dead donor board :
RSCN0790
and once fitted the missing music was restored.End of (small…) job.
 Posted by at 9:07 pm
