Dec 272015
I had on the bench this Aliens PCB:
Aliens_PCB
Board had sever sprites issue:
sprites_issue
I performed a MASK ROM check which reported two bad 4Mbit devices @K2 and @K8:
MASK_ROM_check
I was able to exactly reproduce the issue by using two dummy ROM files in MAME:
0001
So, without further delay, I went to remove these devices and install two 40 pin sockets for the 27C400 EPROM replacements:
sprites_MASK_ROM_rework
With these replacements fitted sprites were perfect but I noticed that sound samples (like voices of main character or enemies) were missing:
Sound samples are stored in a 2Mbit MASK ROM @D5 (which is not checked by the self-test) and its data are processed by a custom marked ‘007232’ which is a PCM controller:
007232&MASK_ROM
Probing the 2Mbit MASK ROM revealed no activity on data and address bus, all pins were stuck high so I removed it:
MASK_ROM@D5_removedJPG
and replaced it with a 27C400 (with doubled content since no 2Mbit MASK ROM replacement exists).This restored all sound samples.End of job.
 Posted by at 9:12 pm
Dec 262015
Yes, yet another Rainbow Islands on the bench!
Rainbow_Islands_PCB
Once powered up the board, I was greeted by this static screen:
no_boot
The watchdog was active sign that there were troubles in main code execution.For first I dumped the program ROMs and they were good (although they were from the Extra version so board was actually an hybird since C-CHIP was the one from the normal version).Then I passed to analyze the WORK RAMs (two Toshiba TMM2063) and I found weak signals on data lines of both:
weak_data_lines
This lead me to remove them, they both failed when tested in my programmer:
WORK_RAMs
With good WORK RAMs the board successfully booted but sound was missing at all:
Fitted a missing 1000uF 16V capacitor @C84 in the sound section was not enough to restore sound:
Missing_1000uF16V@C84_
I noticed that the RAM of the Z80 audio CPU was another TMM2063 which seems to be very unreliable part (like Fujitsu TTLs, I’d say..) so I went to piggyback the one @IC44 and sound was restored.The chip failed the out-of-circuit testing:
6264@IC44
Yes, yet another Rainbow Islands PCB saved from scrap pile!
 Posted by at 7:31 pm
CPS1 A-BOARD (old revision) repair log
 PCB Repair Logs  Comments Off on CPS1 A-BOARD (old revision) repair log
Dec 252015
I got this CAPCOM CPS1 A-BOARD (the old hardware revision) from my friend Joachim for a repair:
A-BOARD_OLD_PCB
He said me that board had some input problems.This was confirmed once I powered it up since most of player 1 and 2 controls were irresponsive but, after few times I cycled power, suddenly the board lost the red color:
missing_red
I started to troubleshoot first the input issue.As usual I inspected visuallly the board and found some corrosion near the JAMMA edge, some of the traces from the involved input pins to custom resistor/capacitor arrays and 74LS245 were eaten:
traces_corrosion
This was confimed also using my multimeter in continuity test.With some patching work and jumper wires I restored the connections and after this all controls were correctly working:
patching
As for the red color issue, schematics for this hardware are available so I went to look at the involved circuit:
palette_circuit
I found weak data signals on the two CXK5814 SRAMs (compatible with the TMM2018 suggested by schematics and PCB silkscreening) @4D and 5D (good on left, bad on right) :
data_signal_comparison
Since the data bus is shared between these two chips I could not know which was exactly the bad chip affecting the other so I piggybacked both them and when I did it on the one @5D, the red color was restored.So I desoldered the chip and it failed the test in my programmer:
CXK5814P-45L@5D
Fitted a new SRAM chip fixed the board completely.
 Posted by at 7:43 pm
Capcom CPS1 PAL update
 PAL Updates  Comments Off on Capcom CPS1 PAL update
Dec 232015
In the past days Smitdogg posted on DU mailing list dumps from a bootleg of SF2CE where most of the program was splitted into the smaller size roms with the use of a custom PAL16V8H @11D to copyprotect it.He provided also the binary dump of this PAL so I took care to reverse it into a GAL16V8 device.The .JED was successfully tested on board by Smitdogg himself.Thanks to him for this contribution.
 Posted by at 11:35 pm
Blood Warrior repair log
 PCB Repair Logs  Comments Off on Blood Warrior repair log
Dec 192015
Another board from my friend Marco and another quick fix.Got from him this original Kaneko Blood Warrior PCB:
Blood_Warrior_PCB
On power up the board showed the “RAM CHECK OK” message but instead of going into game it was resetting in a endless loop:
missing_boot
Boardset is made of a CPU board and ROM board.Having a Great 1000 Mile Rally which runs on same hardware I could verify that the CPU board was good so the fault was located on the ROM board:
ROM_board
So, I wen to dump the program ROMs and compare them against MAME files.When I tried to read the one @U124 (a 27C010), my programmer reported a bad contact on PIN32 (VCC) and gave me an empty dump:
27C010@U124__
Device was internally damaged so I reprogrammed another one.Once fitted it, the board successfully booted into game without any further issues and I could declare also this board 100% fixed.
fixed
 Posted by at 11:27 pm
