Today I dumped the PALs (three secured PAL16L8) from a Sky Wolf PCB (bootleg of Airwolf).Devices are located on CPU board.Dumps have been successfully tested on GAL16V8 targeting devices.
Kaneko Super Nova ROM board PAL dumps added
Found two ATF16V8 PLD’s in a Super Nova ROM cartridge. Both were unlocked but have not been verified as my PCB has a fault. The equations look good.
The ROM board is marked ROM-2.
Bullet (317-0041) checksums fixed
I noticed that Bullet checksums were wrong in the available set. I did a bit of reverse engineering and you can download the fixed version now.
Cheers !
Alpha Denshi Co. (Equites and Splendor Blast) double repair log
I got two rare boards manufactured by Alpha Denshi for repair : Equites and Splendor Blast
Here’s Equites :
Board played fine except for jailbars on some sprites (look at explosions and first enemies on the ground in the below video):
All the GFX generation circuitry lies on bottom board:
A lor of TTLs were from Fujitsu (especially multiplexers 74LS157 and 74LS153) so I went to check them with my logic comparator.All passed the test except for the 74LS153 @8C:
I desoldered it:
The chip failed when tested out-of-circuit:
I added a socket and a good chip:
No more glitched sprites and board 100% fixed:
Here’s Splendor Blast:
This was a little tricky.When I first powered the board up, watchdog was active, the self-test was failing in all program ROMs and in the ‘ALPHA-8303’ MCU RAM:
Doing a visual inspection of PCB I noticed that one of the two custom SIL marked ‘ALPHA-INPUT84’ was wonky :
It came off in my hands when I touched it:
I powered the board without this component and board successfully passed the self-test so I resoldered it (most likely it was corrupting the main 68000 CPU data bus since some lines are shared with it) :
As I said, the board entered in game but some sprites showed jailbars:
The three sprites ROMs are in bottom board:
I dumped them and they were good.With my multimeter I figured out that address bus was shared among the three EPROMs while data bus was in common only among ROM 5 and 7.But I could not measure continuity between pin 15 (D3) of these two.I removed the devices from sockets and found a severed trace underneath:
Patched it and board 100% fixed.End of job.
EspGaluda and Dream Soccer ’94 PAL dumps added
Today we have some new PLD dumps.
‘robotype’ dumped the third PLD on an EspGaluda PCB, it’s marked ‘0315’ at location U33.He also confirmed that the EspGaluda dumps of the devices @U31 and U32 work also on DoDonPachi Dai Ou Jou (both ‘vanilla’ and ‘black’ version) providing the correct labelling too.
‘frsj8112 sent in dumps from a Dream Soccer ’94 PCB (on Irem M107 hardware).
All dumps have been tested as working in a GAL16V8 targeting device.Thanks to them for the contribution.
Lastly, we found that Street Smart and Prisoners of War (P.O.W.) share the same PLDs, they are in same location since hardware is identical.
