Amiga A1200 video repair – part 1
 Computer Repair Logs, Repair Logs  Comments Off on Amiga A1200 video repair – part 1
Jun 162021
Whilst installing and carelessly adjusting my CF card in my A1200 with it switched on, I managed to short out some component on the motherboard via the shield which caused the machine to reboot and then come up with the following screen.
You can clearly see that blue is completely missing.
A healthy kickstart screen should look like this
I wasted no time getting to work after cursing myself for 30 minutes or so and feeling bad all night.
1st step was to figure out where the fault actually was, so I consulted the schematics to understand the design and get an idea of where to start.
I have clearly marked the important parts of the drawing by marking each of the 3 RGB colours over the signals. First of all, we have an AGA ( Advanced Graphics Architecture ) custom chip called LISA which generates the colour information internally amongst other things, this must be converted to analog via the video DAC which accepts 24 bits of colour information from LISA and then passes those analog signals directly to the 23pin D-SUB connector on the back of the A1200.
The same 3 RGB signals generated by the video DAC are passed to the Sony Encoder chip for composite signal and also RF out to a TV.
The issue was also reproduced on the composite out, this would confirm the encoder just gets its RGB signals from the DAC and to look elsewhere. Unlike the Amiga 600 design which uses no DAC but uses the same encoder to pass RGB to the 23pin D-SUB, the A600 video output design is similar to the video hybrid method used in the A500 for generating RGB.
Thankfully we have a similar problem here from RetroGameModz that I used as a reference which describes the troubleshooting process. I really liked his use of Protracker to trouble shoot the colour, this proved very useful.
In Protracker, I turned Red and Green signals to the absolute minimum and adjusted the slider for Blue and see no change at all.  So with my scope I verify the signals coming out of pins 25,26 and 26 of the video DAC.  These are labelled IOR,IOG and IOB respectively. I could see valid waveforms on both on IOG and IOR but a flat line ( low ) on IOB no matter where I positioned the blue slider in Protracker via setup from the main menu. This explains the lack of blue.
So either, the 8 bits for blue were stuck on the output of LISA or I had a bad video DAC.
I then attached my logic probe to 5v somewhere inside the machine and adjusted the slider in Protracker whilst probing R,G and B signals. To my relief my logic probe responded to each and every single one of the 24 bits coming out of LISA. So LISA was spitting out colour information but the DAC was obviously not going to deal with blue. I repeated the same measurement on IOB output of the video DAC this time with the logic probe which shows its held low regardless of the position of the slider, further confirming the lack of waveform there with the scope.
I wasted no time ordering some replacements.  3 x VP101-3BA manufactured by GPS/MITEL and some 44pin PLCC sockets.
So currently waiting for these to arrive from China, delivery time is 2 months.
And in preparation I couldn’t wait to remove the faulty component from the A1200.  First step was using a liberal amount of polyimide tape ( this stuff is expensive but will save you from grief ) to protect surrounding components from heat exposure, I applied some flux and then heat the chip to around 200 for 1 or 2 minutes, then raised it temp to 350 to finish off.
I had this cleaned up nicely. Now just waiting for the spare parts to arrive for a part 2.
References: Amiga 1200 Schematics.
https://www.amigawiki.org/dnl/schematics/A1200_R1.pdf
See here for part 2
Amiga A1200 video repair – part 2
Mar 132021
Lately I’ve gone through all the faulty/untested PCBs I never looked at (tons of them…) to check if there was something that was worth a repair.I found this Sega System 16B motherboard :
I plugged in a Golden Axe (conversion) ROM board and powered up the set.Board booted up, game was playable with good graphics but sound was missing :
The audio hardware is made of Z80 CPU plus a Yamaha YM2151 for music (and a NEC uPD7759 for speeches) :
Looking at schematics the serial data from the YM2151 (pin 21) is sent to the YM3102 DAC (pin 4) which then routes the analog signal to the TL084 OP-AMP :
Probing with the oscilloscope revealed the YM2151 serial data were present on the input of the YM3012 (pin 4) but  the output (pin 11) tied to the OP-AMP was silent :
The DAC was likely fault so I replaced it :
This brought the sound back but it was faint and corrupted (except the speeches that was fine) :
The TL084 OP-AMP is the only part between the DAC and the final sound output :
It’s a well known prone to failure part so I went straight to replace it :
The sound was completely restored and board 100% working.End of job.
 Posted by at 4:10 pm
PLD Archive domain update
 General  Comments Off on PLD Archive domain update
Feb 232021
As of yesterday the PLD Archive wiki was locked for editing and it has been moved to the new domain of https://wiki.pldarchive.co.uk/ .
The link on this site has been updated but if you have bookmarks saved or whatever then these will need updated too.
As usual there will likely be broken links and errors so if you happen to find any then please do let me know. There is an email link on the main page of the new wiki. Likewise, if anyone has any PLD dumps or recreations, PCB pictures or IC pictures to contribute please also use that new email address to send them in.
Thank you
 Posted by at 5:41 pm
Taito PC080 & PC090 info
 Technical Info  Comments Off on Taito PC080 & PC090 info
Dec 302020
Channelmaniac has put together a couple of drawings to show the pinouts for the Taito PC080 and PC090 customs
Thanks again to Channelmaniac
 Posted by at 4:16 pm
Konami 054539 info
 Technical Info  Comments Off on Konami 054539 info
Dec 062020
Channelmaniac kindly sent me some tech info he made up recently for the 054539 custom found on some Konami boards.
Here we have the pinout for the chip and also the circuit conenctions
Thanks to Channelmaniac for sharing these
 Posted by at 6:43 am
