PAL UpdatesComments Off on Super Burger Time PAL dumps converted and tested.Pang 3 and Knight of Valour Super Heroes PAL dumps added
Nov012017
Another PALs update today.
I have converted to GAL16V8 fuse map the Super Burger Time PAL dumps we had from Luiskiko time ago, they all works fine when tested.
‘cpsystem3’ sent in dump (successfully tested by himself) of the PLD present on a Knight of Valour Super Heroes PGM cartridge, thanks to him.
Lastly, I dumped the PLD @1F from what appears to be a well made reproduction of Pang 3 B-BOARD
Equations of PAL are different from original board since bootleg use eight 4Mbit GFX ROMs instead of the two 16Mbit ones of genuine boardl.All other PALs are identical to original.Dump is untested for now since board is not working.
Today we have a massive update.Dumps came from the following PCBs:
Athena bootleg
Porchy dumped the PALs from a copy board and successfully tested dumps back on board.Corrado Tomaselli confirmed dumps are working also on the original PCB.Devices were all unsecured (two PAL16L8 and one PAL20L8) and they have been reversed into GAL devices (for the 24 pin one both GAL20V8 and GAL22V10 replacement available).Thanks again to both them.
Cyberball (prototype with serial #0002)
Dumps were provided by ‘coolmod’ on Dumping Union list from an early revision/protoype of board.Devices were all unsecured PAL16L8.We mark them as “assumed working” since we have no means of testing GAL replacements.Thanks to him.
Locked ‘n Loaded
256KB binary PAL dumps provided by Smitdogg on Dumping Union from a faulty board.I reversed them into GAL fuse map which we mark as ‘untested’ until testing on a working PCB will be done.Thanks to him.
Gokidetor (a mechanical wack a mole type game by Taito)
Dumps provided by Smitdogg on Dumping Union, devices were all unsecured.We mark them as “assumed working” for now.Thanks to him.
Bobble Bobble (bootleg of Bubble Bobble)
I dumped and reversed into GALs the three PALs from this one layer bootleg.All dumps matches the two layer version (dumped by Porchy some time ago) except for one which has slightly different equations.
Tecmo World Cup ’94
Board has six PALs but I was able to dump and reverse into GAL only the one @U64.
Pipe Dream
I dumped the PLDs from a dead board.Out of four devices present one was registered so not dumpable.Dumps are untested for now until we can test them on a working board.
Received this faulty Capcom CPS1 A-BOARD, actually the ‘DASH’ revision with a 12MHz oscillator in place of 10MHz one:
Board played with good graphics but sound samples were completely wrong and randomly played, here’s a video made with a Captain Commando B-BOARD/C-BOARD:
PCM samples are played by an OKI ‘MSM6295’ IC which addresses two 1Mbit devices (located on B-BOARD) and reads back their data.Judging from flux residuals the IC was previously reworked on this board as well as other components of audio circuit:
For first I tested all traces to/from it, all was OK.So, most likely, the IC was bad, no wonder since it’s a prone to failure part.I removed it:
Cleaned the PCB from flux and installed the spare:
Got this original Taito (licensed to Romstar) Arkanoid PCB for repair:
Board uses the Taito Classic pinout (used on other games like Bubble Bobble, Elevator Action, Jungle King) so I had to build a proper JAMMA adapter:
On power up I was greeted by this static screen:
The string “WOVO VEM EVVOV” reminded me “WORK RAM ERROR”.I had confirm of it opening one of the program code ROM with an HEX editor:
The WORK RAM is located @IC15 in form of a 2K x 8-bit device but piggybacking it had no changes.There are other two 2016 static RAMs @IC57 and IC58 :
When I went to probe the one @IC58 I found the data bit 2 (pin 11) stuck high:
This is tied to pin 9 of a 74LS245 @IC42 for exchanging data with the other one @IC57 which, according to MAME memory map, is the VIDEO RAM shared with Z80 main CPU:
