Over the years there have been people asking if they can submit posts of their own.
Aside from friends of mine I have never really wanted to open up registrations for everyone.
I have now finally got around to enabling a frontend to allow people to submit their own posts.
It can be found under the “Contact/Links” menu and is just a trial right now.
If it doesn’t take off or gets abused in any way then it will be removed and we will go back to business as usual.
Hopefully we will get some more diverse content going on as a result of this
Happy New Year
Happy new year everyone to everyone that visits this place and a big thanks to all that have either contributed or made a donation.
Hope you all have a great 2018
In the past, every time I’ve undertaken a ROM hacking project i have ended up with a cluster of binary files all at varying stages of usefulness. This simple program is how I will now be working with binary file hacking.
The format of the changes is really simple and can all be put together in a text file or in the program itself.
As you can see, comments are supported.
Using this I can comment the changes I make and just ‘Autopatch’ a binary file after I’m finished and if I make a mistake then I can modify the text file and reapply to the original binary.
I understand that the way I approach things is not necessarily the way most other people approach things but it might be of some use to someone else out there.
The software has a simple HEX viewer in it, can byteswap the loaded binary and also supply an offset.
The offset is relatively untested and is intended to be used if you are loading a ROM file that normally starts at, for example, address $1000 in memory space. You can apply the offset and write values to the correct addresses. If in doubt then just avoid this altogether as it will cause problems and cant really do any error checking.
Merry Chistmas
Rolling Thunder repair log #3
Received from Spain this faulty Rolling Thunder PCB for repair:
Board was not booting stuck on a static garbabe screen with some background sound noise (which seems a common issue on this PCB)
After ruled out all the custom ICs, few was left to test.The background sound noise very likely suggested a problem in the digital sound circuit that on this hardware must be working for proper operation of the whole system.Probing this circuit with a logic comparator revealed nothing abnormal until I tested a 74LS257 @7C, I was warned about a problem on its output pin 12:
Also comparing with a scope this ouput with the one of the reference IC gave discrepancies, signal was not properly toggling (good on left of the below picture)
Looking at schematics pin 12 of this 74LS257 outputs the address line ‘A0′ to a 6264 static RAM @3F tied to the custom ’30’ which controls the sound system:
Sure enough I removed the TTL which failed the out-of-circuit exactly in pin 12:
After replaced the TTL the board successfully booted, no further issue were found so 100% fixed.
New dump of KD29B added
Today I’ve added a new dump of the KD29B PAL from King of Dragons on CPS1.
The original dump was taken from a seemingly unlocked device but was dumped as a GAL16V8 instead of a PAL!6L8 which may have caused issues.
Anyway, I’ve recently had the opportunity to study this chip and have what I believe to be a more accurate version.
