Today I received a job lot of 20 x PLS100 chips that I got from eBay recently.
For those that aren’t aware, these are what was used as a PLA in the older breadbin Commodore 64’s and are probably the most common failure in the machine as they tend to run hot.
Ive got the JEDEC fuse map from a genuine C64 PLA and have tested with no problems. These should keep mine and RCM’s Commodore’s going for a while longer now
Pocket Gal bootleg PAL added
Dumped a PAL16L8 from the Pocket Gal bootleg board I got.
The PAL was unprotected and I have converted it for use on a GAL16V8.
This has been tested working.
UPDATE: When I get an idea in my head the tendency is to get it done or ill think about it constantly so the second and final PAL on the board is now dumped and converted to GAL. The original device is a PAL16R6 and this was also unprotected.
Pocket Gal bootleg repair log
Another decent fella from a forum was giving this board away for the price of postage.
Its been a bit quiet lately on the repair front so thought id give myself something to do. Ended up being a really quick and easy fix.
The game booted up and all the sound appeared to be there, it would even coin up but the game could not be started.
Checked pin 17 at the edge connector (Start button) and this was HIGH and it toggled LOW when the start button was pressed. Traced this through to a nearby 74LS245.
The direction pin (1) was held low connected to ground and because the ENABLE pin was pulsing it was pretty difficult to see if the inputs on the B side of the Bus were making any difference to the A side outputs. I piggybacked a new 245 onto it and the game could now be played. I desoldered it and replaced the chip, all is now working. Shame the game is utter crap!
I also took the opportunity to dump the unprotected PAL16L8. I’ve converted it to GAL and tested it. There is a PAL16R6 on there too which ill get around to doing sometime but the board is of typical bootleg quality and a bit of a pain.
Fluke 9010 repair log
A kind bloke over on the UK-VAC forums was selling off a couple of Fluke 9010’s last week for a very decent price. He stated one had no beep and the other doesn’t communicate with pods.
Received these heavy buggers today and tested them. Both are cosmetically in very great condition.
Turns out the one with no beep is also the one that doesn’t communicate with the pods and both problems are caused by the same thing, the 6520 PIA is shot. I confirmed this swapping the chip over.
Ordered some replacements and fixed the fault.
It also worth mentioning that both of these units have the clock module fitted, although I do not have the necessary components to make use of this feature its pretty interesting to me as my other one doesn’t have it.
