Got a mates MTX512 here and noticed it has a PAL so would have been rude not to dump it.
There is the PLD listing for this PAL available somewhere on the net but not an actual JEDEC file for it.
GAL has been tested and confirmed working
New PALs added
Today I added 4 new PAL dumps.
The first 3 are from a CPS2 motherboard and are labelled as follows:
BGS-A2
BGS-A3
BGS-A4
These were taken from a non working motherboard and dumped using the ABI. They are untested at this point as Im not removing the pals from a known good motherboard to test so if you use these please let me know if they work or not.
The next one is something Ive been working on for a while and have put quite a lot of effort into.
It from a Sega ST-V motherboard and is labelled 315-5833.
Again, I am marking this as untested. I have tested it successfully with my 3 games which are Die Hard Arcade, Winter Heat and VF Kids. It also works with the Modbios.
Please test this one out as much as you can and let me know how it works.
Im pretty sure that it wont work with any add-on hardware but im also sure that all of that stuff came with a replacement GAL.
Pier Solar
Today my reprint copy of Pier Solar finally arrived.
Ive been waiting a long time for this ever since missing out on the original run a while ago.
The games is a brand new RPG title for the classic Sega Megadrive/Genesis and comes on a technically impressive 64Mb cartridge.
Ive quickly fired it up and it looks great but I cant find my AV cable for the Megadrive and I refuse to play this over RF so ill wait until I get another AV lead, hopefully RCM will have one I can swipe next weekend.
Received this Plus/4 today from eBay. Sold as untested with no PSU and fully expected this to be broken.
The power supply connector is a 4 pin affair that looks similar to the C128 and Amiga but it is not. All is not lost however as if you remove the original connector it can be directly replaced with one from a C64, and that’s just what I did.
The swap was a very quick operation and to my surprise the system fired up with no issues other than some keys on the keyboard need a little more force than others.
I think the SD2IEC is also compatible but I will need an external power supply for it as mine normally plugs into the cassette port of a C64/128 for its power needs.
Virtual Boy repair log #1
Got a Virtual Boy the other day with the Flash Boy Plus cartridge.
The unit worked fine with the Red Alarm game that was already on the cart but when I changed the game to Bound High I was greeted with a solid red screen. The music played and I could run the game blind but that was no use.
I reflashed with Red Alarm and after a couple of screen artifacts in the left screen the game played fine.
After a quick Google around it turns out that this can and will happen to every Virtual Boy made and occurs when the glue holding the FCC ribbon deteriorates so that connections become unreliable.
There are a couple of different fixes for this. One is to strip the plastic back and solder the very fine connections directly onto the board which is a permanent fix, the other is to but the little module into the oven at about 80 degrees C for a couple of minutes then apply pressure to the cable afterwards in the hope that the glue will reset making a nicer connection. This is not a permanent fix but will get you away. The later method is what i opted to do as I’m pretty lazy and dont have the chemicals needed to dissolve the plastic.
The first hurdle is actually getting into the unit as Nintendo kept with the same gamebit screws they used for other devices but they also stuck them down a deep hole so standard gamebit drivers cannot normally reach as they are too fat.
The solution is to make your own from a flat blade driver. I used my milling machine to cut it down and cut a groove in the end. Its certainly not pretty but worked perfectly.
On opening the ribbon cables are on either side of the unit and is held in at the board by 2 little crosshead screws. DO NOT try removing the 2 bigger screws near by, they control alignment.
The top of the cable just pulls out (carefully!).
Get a bit of tin foil, sit the offending article onto said foil, preheat the oven to around 80 degrees C and bake for around 1.5 – 2 minutes.
After its done remove it (its not hot) and rub or apply pressure onto the connection side until its sufficiently cooled and the glue will have reset.
After this, take some sticky tape and apply it to the area wrapping it round so that it applies a little pressure onto the connection.
Refit and test.
This worked perfect for me and many other people have said the same thing.
Time to waste my weekend playing some headache inducing goodness
