Another CPS1 PAL added
 PAL Updates  Comments Off on Another CPS1 PAL added
Mar 202012
Balázs emailed me a dump of his KD29B chip from King of Dragons.
His chip was a GAL replacement but he has tested this dump and confirmed it works.
Thanks to him for sending this.
Looking for the Strider (Japan resale) PAL if anyone has it
 Posted by at 4:19 pm
Missing CPS1 PAL dumps
 PAL Updates  Comments Off on Missing CPS1 PAL dumps
Mar 182012
Don’t know how I missed these 2 as Ive had the chips for ages.
They are S224B from Final Fight and DAM63B from Daimakaimura.
I know these are already in the MAME sets but I may as well add them myself for completeness.
 Posted by at 10:48 am
Some new CPS1 PAL dumps
 PAL Updates  Comments Off on Some new CPS1 PAL dumps
Mar 152012
Got some CPS1 stuff today. There are a couple of populated B boards and a couple of unpopulated B boards.
One of the boards is Quiz Tonosama no Yabou 2 – Zenkoku-ban which I believe is the Japanese version of Quiz and Dragons.
The PAL off this B board is labelled TN2292.
On one of the unpopulated boards was a PAL marked QAD63B which im guessing is from a Quiz and Dragons board. Ive dumped this anyway but it remains untested. I cant even find a reference to it anywhere online.
 Posted by at 7:26 pm
Mar 132012
Stiggy gave me an Atari 2600 he had going spare when he came round.
Ive never owned one before but its always been on my list.
The old 2600 only has RF out which is completely rubbish on modern TV’s so it was off to the internet to see what kind of mods exist.
After a short while of checking different sites I came to the conclusion that there is no decent, definative guide for my version of 2600.
My mainboard seemed to be a little different in layout than what the guides were based on.
Looking at the other guides they show that the video signals all come from one IC which is standard across all the 2600 models so I traced out the SYNC, LUMA0, LUMA1, LUMA2 and COLOUR signals myself and ran some wires from the points and to the outside world.
As you will see, there is a “COLOUR” label with thats crossed out. This is because I originally followed the circuit through the resistor where I should have followed it from the resistor up to and through the capacitor above it. I ended up tapping into a +5v line by making this mistake so ended up with no signal at all.
I made a quick design in EagleCAD and etched a board based on a simple transistor based amplifier running the LUMA signals through various size resistors.
After taking my +5v from the nearby voltage regulator, fixing my mistake that I highlighted earlier and doing a test with a loaned Harmony cartridge I saw a fairly decent image on screen. Its a little dark and this can probably be changed with fine tuning some resistor values but this will be more than acceptable for me.
The pictures don’t look too impressive on the photos but they are a joy compared to RF.
Ive yet to hook the sound up but the wire is there for it, this will be tomorrows job along with properly fitting the phono plugs.
EDIT: Sound is now hooked up and fully working. All phono sockets are fitted. What a nice mod it was.
 Posted by at 8:27 pm
Virtual Boy repair log #2
 Console Repair Logs, Repair Logs  Comments Off on Virtual Boy repair log #2
Mar 112012
As with all VB’s and in my previous repair, one of the screens goes a little strange, in my case it was the left screen.
I initially used the oven fix method which worked well but only for a short amount of time.
I fired it up today and was greeted with the same left screen showing garbage.
Rather than use the oven trick again I decided it was time to try one of the more adventurous methods out there.
Turns out there is a nice video on YouTube of how to fix it using a soldering method.
Instead of dropping a load of solder onto it I used some liquid flux and a small amount of solder. You can see it working quite easily and no braid was needed to mop up the excess.
The whole thing only took a few minutes and worked perfectly when I put it back together.
Time will tell how long this lasts but I don’t see why it should cause issues again.
 Posted by at 4:28 pm
