A while back I dumped the PAL from my 68000 POD. The chip was unprotected and the pod works fine so assume the chip is good.
Its in its original PAL format so will need converting if you want to use a GAL as replacement.
Fluke 9010 signature calculator update
Due to a request to add directory support, here is an update.
You can now either drag a single file or a whole directory to the window. If a directory is dropped into it then all files in the directory will be processed. Sub directories are not processed.
Being a Windows user and sometimes favoring GUI’s over command line stuff I decided to make my own program to calculate the signatures for the fluke 9010.
This program is a simple drag and drop affair and processes 1 file at a time. Directory scanning is not present in this program.
Various untested PAL’s added
These are from a large archive that ive had for ages.
These are completely untested and still in whatever format the original device was. I have looked at them to make sure they are not dumps of locked devices but nothing else.
The games are:
Badlands
Birdie King 2
Dragon Saber
Darwin 4078
Double Dribble
Elevator Action Returns
EspGaluda
Express Raider
Hot Shots Tennis
Puzzle Bobble 2X
Sly Spy
Space Invaders 95
Space Invaders DX
The Legend of Kage
Thunder Fox
As always, all feedback on the operation of these files is welcome and credit will be given to testers.
It has recently been found out that on B boards 93646B-3 and 93646B-4 there is a suspected routing error for one of the pins from PAL 3.
This means that if you are doing a game conversion using on of these B boards, you cannot natively use the BGSB3G PAL chip, you will have to either lift pin 9 of the PAL and solder a wire to C13 of connector CN3 or use PAL BGSB3F, lift pin 7 and solder a wire to C13 of connector CN3.
