SEGA System 32 GAL dumps
 PAL Updates  Comments Off on SEGA System 32 GAL dumps
Jun 262013
Today I received a couple of System 32 games, Golden Axe 2 and Arabian Fight.
The GAL chip was missing from the sub board of Arabian Fight but the seller told me he could swap it from the GA2 board and it would work.
The chip was locked so I ran it through the PAL dumped and recreated it. Its number is 315-5536
There are 2 other GAL chips across these boards. I have also dumped then
They are 315-5552 found on the ROM board and 315-5441 found on the main board.
All have been tested and seem to work just fine. They may also work with other System 32 games but I haven’t confirmed this
 Posted by at 11:36 am
Super Pang bootleg PEEL
 PAL Updates  Comments Off on Super Pang bootleg PEEL
Jun 252013
caius sent me a dump from a Super Pang bootleg today. The device in question was a PEEL18CV8.
Using the fuse map layout in the datasheet I reversed it back into equations and programmed up a GAL16V8 device to replace it.
caius has tested it and says it works fine.
Turns out JEDUTIL can reverse these too so that will save me heaps of time in the future.
 Posted by at 9:57 pm
My Hero PAL added
 PAL Updates  Comments Off on My Hero PAL added
Jun 182013
Andreas submitted a PAL16R4 dump for the SEGA game My Hero. This PAL also works in a bootleg version of the game.
Thanks to Andreas
 Posted by at 7:44 pm
Espgaluda GALs tested
 PAL Updates  Comments Off on Espgaluda GALs tested
Jun 162013
Henrik has tested the previously untested archive for Espgaluda.
There were 3 dumps within the archive and were from an unknown source.
Henrik says files U31 and U32 were working but U33 was not. Both these working ones are now added and the non working one is removed (although I will still keep it just in case).
Thanks the Henrik for testing
 Posted by at 5:40 pm
SEGA Power Base Converter / Mega Adapter PLD
 PAL Updates  Comments Off on SEGA Power Base Converter / Mega Adapter PLD
Jun 122013
This chip is found in the Power Base Converter / Mega Adapter for the SEGA Megadrive.
Its a CK2605 but was dumped as a PLS153. I will get around to converting this to true PLS153 soon.
 Posted by at 7:35 pm
