Commodore 1541 Floppy Drive
 General  Comments Off on Commodore 1541 Floppy Drive
Oct 202013
Picked one of these up for a reasonable price recently.
Its in very good condition and it works too.
Time to open it up and see whats inside.
This thing is a computer in itself with a processor, ROM and RAM. You can install JiffyDOS into this as well but im going to leave it alone as my SD2IEC will be the thing getting the most use, this item is just a nice to have.
 Posted by at 1:00 pm
Growl prototype PAL dumps
 PAL Updates  Comments Off on Growl prototype PAL dumps
Oct 182013
Like with the BB2 proto, these will be of no use to anyone really. What makes them even more useless is the fact that one of the PALs is missing so we cannot even get the game up and running.
A massive shame that 1 little chip can essentially destroy this unique item but this is exactly the reason why I started the PAL dumping mission.
 Posted by at 5:30 pm
Oct 182013
Brought a few of muddymusic’s PCB’s back with me from the recent Play:Expo. One of them was an original Willow PCB set.
The original fault was some lines through all the graphics but when I got it home there was nothing at all. I found with a little flexing of the B board then the game would run so I set about replacing the sockets that I know are quite unreliable in their old age. This didn’t make any difference.
I started checking the connectors that connect the B board to the A board and found 2 pins on CN2 that had no continuity through. These corresponded to A0 and A1 for the program ROM’s so that would explain why it wasn’t booting. Luckily Ive amassed a lot of CPS1 boards over the years and desoldered a 32 pin connector from the donor board and the Willow board.
This is what I got
The jailbars are back.
Luckily, I was expecting the C board to be broken before I got the game so I had modified the program code to use a B_21 C board instead.
This seems to now work fine but more testing will need to be done. This will most likely do until such time a new Willow C board can be found.
 Posted by at 1:16 pm
Pang 3 PAL added
 PAL Updates  Comments Off on Pang 3 PAL added
Oct 182013
Zabanitu has dumped a CP1B9KA PAL from his Pang 3 PCB.
It looks to be slightly different from the CP1B9K one in MAME.
Thanks to Zab for this
 Posted by at 8:24 am
Taito Growl PALs
 PAL Updates  Comments Off on Taito Growl PALs
Oct 152013
Today I dumped and added the 2 PAL chips from Taito’s Growl.
Both PALs were unlocked and I have converted them to GAL and tested them.
Both sets are added.
Thanks to muddymusic for loaning me the PCB
 Posted by at 10:07 am
