Super Pang bootleg PALs added
 PAL Updates  Comments Off on Super Pang bootleg PALs added
Dec 012013
caius has dumped and tested 2 PAL chips from a Super Pang bootleg.
He says this bootleg is a bit different to the one normally found so these files may not work for everyone.
Thanks to caius
 Posted by at 5:26 pm
Amstrad 6128
 General  Comments Off on Amstrad 6128
Dec 012013
Meet my new addition to my retro collection, the Amstrad 6128.
Ive never owned an Amstrad computer before and I absolutely love it.
I had to change the drive belt but other than that it works great and came with a few discs too.
 Posted by at 5:14 pm
Amstrad 6128 HAL chip reversing
 General  Comments Off on Amstrad 6128 HAL chip reversing
Dec 012013
Ive made a lot of progress since my plea for help regarding this chip.
To recap, this chip could not be dumped in a programmer as it was security locked and I could not recreate its logic by the usual automated method due to the fact that this chip used latches, something that I had not seen before in a combinatorial device.
Due to the fact that this chip operates in a not often seen way I thought it would be good to write a bit about what Ive found, mainly the latches.
If you look at the schematics for this system you can see the HAL/PAL chip in all its glory.
6128PAL
What I initially found was equations associated with the three X pins (pins 13, 14 and 15) but on the schematic they appear to be disconnected to which I assumed meant unused. You know what they say about assumptions right?
These three pins are where the latches come in. The Amstrad 6128 has 8 different memory selections from C0-C7. With these latches the system will always be in the same memory configuration until it is changed. Makes a lot of sense when you think about it or after every write to a specific memory location it would default back to C0. These configurations are derived from the D# pins but obviously those D# pins are used to send the actual data on too so without these latches the data bus would only be 5 bit.
Using a lot of logic analysis and a huge helping hand from Charles MacDonald I eventually got these latches working. All plain sailing from here I thought. No chance!
I was easily able to implement the A15OUT, A14OUT, CAS0 and CAS1 from truth tables found on CPCtech but this brought up another issue. When one of the CAS lines was LOW it would latch into this state until the NCAS line was toggled.
From my initial inspection of this behavior it seemed like they were switching on a low edge which meant a flip-flop needed to be used. Looking at what I already had I could see there wasn’t going to be enough product terms available to implement this flip-flop.
After sleeping on the problem it occurred to me that it was simply another latch that locked the other CAS line out until the NCAS line reset.
Im pleased to say that all my testing seems to be spot on so far but I could really do with testing some of the other modes to be completely sure. Ive been testing a GAL16V8 replacement out and there are no issues so far.
This thing has taken me a very long time to do and its been very satisfying to now be at (or near) the end.
 Posted by at 2:08 pm
Nov 232013
Its a very rare occasion that I cannot dump a 16L8 device. There has only ever been once in the past where I have failed in this and that was with a Namco chip that uses heavy feedback.
Recently I’ve been trying to dump the HAL16L8 device from an Amstrad 6128 but its just not happening.
The chip seems to have some kind of flip flop implementation that I cannot reliable dump automatically or figure it out in my head.
I’ve tried quite a few different approaches but cannot get this to work. Even with a logic analyser setup its quite elusive.
I’ve been through all the info I can find online and while it all makes sense, it does not help me implement the equations properly.
The devices I’ve tested are locked so cannot be read out with a programmer but if you have anything to offer or can even supply a proper dump then could you please pass it on.
Thank you
 Posted by at 8:48 pm
Mario Bros. bootleg conversion PAL dump
 PAL Updates  Comments Off on Mario Bros. bootleg conversion PAL dump
Nov 222013
Zab has dumped the PAL12L6 chip from a Mario Bros. bootleg. This game is apparently a conversion from a Donkey Kong jr bootleg.
Original or bootleg doesn’t really matter to me as these PAL dumps will still be useful to other people.
Thanks to Zab for his continued support
 Posted by at 2:17 pm
