caius has now dumped the PAL chip from a PGM motherboard.
I know some people in the past were looking for this so hopefully it will help a few fix their board.
Thanks very much to caius again
caius has dumped a PAL chip from Bucky O’Hare.
As usual with submissions from caius it is tested and already in GAL16V8 format.
Great game this one and thanks very much to caius for dumping this chip.
caius has sent in this dump. It is in GAL16V8 format and is tested.
There is a note attached too:
PIN 15 is cut and pads of the PIN 14 and 15 are joined on solder side of the PCB, probably this is a factory fix.
Thanks again to caius
Today Ive released the file I created as a replacement for the HAL16L8 from an Amstrad 6128.
Its taken me quite a while and have had help along the way but now its here and tested as much as I can.
Hope this helps some people out.
Thanks to arnoldemu for his truth tables and to Charles MacDonald for once again showing me what the hell was going on when I couldn’t.
caius is back with a couple more PAL dumps. This time from the Japan version of Strikers 1945.
They are in GAL16V8 format already and are tested.
