Aug 272014
Game was dead on power up.
Pressing down on the crystal brought clocks back. Resoldering the crystal didn’t help so there must have been a break internal to the unit. I ordered a spare 18.432MHz crystal oscillator and waited for it to arrive.
The new crystal arrived and fitting it brought the main clock back however my monitor screamed at me.
Checking the output from the 082 custom chip on the scope revealed that the SYNC signal was around 24kHz.
wrongkhz
I originally thought the 082 was at fault as id seen so many of them go wrong before but after sleeping on it I started to think this unlikely. At this point I asked for a bit of help from forum user cmonkey. He knows a lot about Konami hardware and has provided a lot of insight to me in the past.
He very generously took some measurements off his Gyruss PCB and it confirmed that the clock input going to the 082 was too high on my board. It should be 6.14MHz into pin 13 and I was getting around 9.14MHz.
wrongkhz2
At this point I thought I would do a bit of circuit simulation and drew out the clock generation circuit in PSpice.
cc-sim1
This is how the circuit should be.
ccharlie-clock
As you can see from the simulation I have around 6MHz.
Probing around this PCB however revealed that pin 1 of the 74LS107 was dead. Removing this line from the simulation revealed this:
cc-sim2
Exactly what I was wanting to see.
I removed the LS107 and tested it. It failed as expected.
cc-107fail
I found one on a scrap board. This brought everything back to life.
ls107
Powering the board up initially gave me a static screen of 0’s. This is what you normally see during the start of the POST. Ill get back to this issue later.
Powering down and back up again gave me this:
rightclock
Using MAME I confirmed the Video RAM area was to blame.
Checking the address lines on the 8128 RAM at location 3E revealed 4 dead lines. I traced these back to 74LS157 at location 5E. Replacing this brought back the graphics.
almost
There is still a small graphics issue at this point which I struggled to find and also the intermittent power up problem I mentioned earlier so thought I would move on to the other issue of the controls not working.
Neither of the coin inputs work.
Back to the schematics, I can see where the signal comes in and taking some measurements shows there is something wrong as I’m getting around 1v at pin 6 of the chip at 3F.
There is very little to this part of the circuit and the resistor array looked good so I desoldered the 74LS253 and it failed all tests. Replacing this brought the controls back.
So back to my remaining problems.
First, the graphics issue. Its hard to describe but on the parts of the screen where the coloured dots cycle round this also affected half of the 8×8 tile above it.
IMAG0820
As it only affected half the tile I eventually came to the conclusion it was a timing issue. This led me right back to the beginning where the reset circuit lies.
The power on reset is generated by a 555 timer which goes through a bit of logic and eventually out to the rest of the board as a /RES signal.
cc-reset
This signal comes out on pin 8 of a 74LS08 AND gate. Working back I found I had no output on pin 11 at all. I desoldered this chip and replaced it.
IMAG0816
It fixed the reset problem but also fixed the graphics problems too
IMAG0821
I guess it could have been caused by a timing issue after all?
This board looked is VERY good condition and, looking at the edge connector, it cant have been powered up more than a handful of times so its interesting to see that all these problems were present.
Very pleased I got this fixed.
Hellfire repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Hellfire repair log #1
Aug 232014
As usually I got this Hellfire PCB from ebay quite cheap.The game itself is an old school horizontal shoot ’em up manifactured from Toaplan.At first sight the PCB was clean except for some corrosion in the bottom right corner.
Hellfire_PCB
Once powered it on I was greeted by this screen:
Hellfire_error
Looking at MAME memory map I found no trace of this specific offset which is at end of 68000 addressable memory (this CPU can address up to 16 MBytes).So I decide to start over again and  give a deeper look at the PCB, in particular to the mentioned corroded area.I found that some pins of the ASIC marked “FCU BG1” were lifted.According to MAME source this chip handle the tiles generation and this would (partially, since device is not mapped in this memory region) explains the RAM error.
I tried a reflow but pins were so much corroded that I could not get a good soldering so I opted for a transplant with another same ASIC from a scrap Hellfire PCB but before doing this I cleaned the area from oxide and corrosion exposing the ASIC pads very well.This was the result:
FCU_BG1
Confident I powered the board on and :
Hellfire_fixed
100%  fixed!
 Posted by at 9:49 am
Bonze Adventure PAL set completed
 PAL Updates  Comments Off on Bonze Adventure PAL set completed
Aug 222014
Today I dumped the last PAL from an original Bonze Adventure PCB.With this now we have the complete set of PLD dumps since the other two were already done.It was obtained from a secured PAL20L8 and reversed by Porchy into a GAL22V10 targeting device.Dump has been tested as working.
 Posted by at 11:15 pm
Reality Tennis PAL dump added
 PAL Updates  Comments Off on Reality Tennis PAL dump added
Aug 202014
Smitdogg, the founder of MAME Dumping Union, sent me a Reality Tennis PCB (a tennis game with digitized graphics manifactured by TCH, a spanish company) for a repair in order to complete emulation.So I took the opportunity to dump the only PAL present ( a secured GAL22V10).Dump was reversed by Porchy in a GAL22V10 targeting device and it’s tested working.
 Posted by at 9:09 pm
Spectral vs Generation sheet
 General  Comments Off on Spectral vs Generation sheet
Aug 202014
I was recently asked if I could scan in the manual (its not much of a manual, just a bit of paper) from my SvG.
Anyway here it is for anyone thats interested.
DOWNLOAD HERE
svgthumb
 Posted by at 4:26 pm
