Grand Striker 2 human HUM-0003-(A) PLD dumps added
 PAL Updates  Comments Off on Grand Striker 2 human HUM-0003-(A) PLD dumps added
Nov 212014
Luizwt (BRASIL) has sent in 3 PLD dumps from Grand Striker 2.
They are straight dumps from PEEL18CV8 devices so unless you convert them you will need to located these devices in order to use them.
Thanks to Luizwt (BRASIL) for these.
 Posted by at 10:00 am
Crime City repair log
 PCB Repair Logs, Repair Logs  Comments Off on Crime City repair log
Nov 172014
Another board donated from my arcade operators friends.It’s time for Crime City.
Crime_City_PCB
For the uninitiated, Crime City is a beat ’em up developed by TAITO that can be played by one or two players simultaneous.Here are the technical specs of the hardware:
  • Hardware – Taito System B Hardware
  • Board Number – K1100470A
  • Main CPU – 68000 (@ 12 Mhz), Z80 (@ 4 Mhz)
  • Sound – YM2610 (@ 8 Mhz)
  • Screen Orientation – Horizontal
  • Resolution – 320 x 224
  • Refresh Rate – 60 Hz
  • Palette Colors- 4096
  • Players – 2
  • Buttons – 2
  • Joystick – 8 way
The board booted fine but I immediately noticed that there was no sound at all except for some scratching noises.Besides, some colours were wrong and some characters tended to pink compared to the correct ones from MAME (see wheels of car in the picture below, MAME screenshot is on the right) :
colour_comparison_1
As usual I started my troubleshooting with a visual inspection of the PCB and found a broken track on the solderside which I promptly patched with some AWG30 wire:
broken_track_fixed
This fix restored correct colours (the broken track was actually connected to the TAITO ASIC TC0260DAR which is a custom pallette generator and this explained the reason of the fault)
As I said board was silent, no sound at all except for some noise sign that the main MB3735 amplifier was working fine.Digital audio section is made by a Z80 CPU which commands a sound synthesis YM2610 chip.With my logic probe I could verify that all was working fine there so fault was elsewhere.So I started to suspect the YM3016F sound DAC:
Y3016_F
Connecting its analog output to an external amplifier produced no sound (while digital input was present).This convinced me to replace it and so sound was fully restored .
 Posted by at 8:43 am
Nov 152014
First of all I want to thank JROK for providing me all the technical info and allowing its public release, without his help I would not have ever made.Let’s start with the story.
Some time ago a  friend of mine sent me his Splatterhouse PCB bought as working saying it got stuck upon boot  on ‘ROM TEST START!! PLEASE WAIT..’ message displayed upside down on a screen filled with red zero.So I started to investigate on the net and found that usually this kind of issues are caused by a faulty custom chip marked ’64A1′ @M4 on ROM board.This was confirmed by swapping this IC in another CPU board of Galaga88 with this missing component , in this case I got an ‘EEPROM ERROR’ message which is a further proof of the fault.
Thanks always to JROK we know that this ’64A1′ custom IC is nothing else than a HD63701 MCU with the exception of two custom opcodes not present in original part.You can go deeper into technical reading here:
https://www.jrok.com/hardware/cus60/cus60_an_owners_guide.html
In the specific you have to change three bytes in the ROM  “VOICE0” at a specific offset.For example :  in Splatterhouse the offset is $FA8B and the new HEX values are “20 01 56”.
The string to search for in HEX is  “B7 C0 00 6E 00” and the first 3 bytes must be changed to  “20 01 56”
The patch seems to be needed at offset $FA8B for most games, but not all. Here’s a reference table :
Tank Force – $FA29
Blazer – $FA8B
Dragon Spirit – $FA8B
Galaga 88 – $FA8B
Marchen Maze – $FA8B
Splatterhouse -$ FA8B
Rompers – $FA8B
Blast Off – $FA8B
World Court – $FA8B
Beraboh Man – $FA4E
Dangerous Seed – $FA8B
Face Off – $FA29
Puzzle Club – no voice ROM !
Quester – $FA1B
HD63701VOC
So, it was only matter to program one of these MCU with MAME dump using my Hi-Lo Systems ALL-11C EPROM programmer and, at the same time, replace the ROM ‘VOICE0’ with the properly patched one.Once done, I had confirmation of what the good JROK said about. Operation  ‘NAMCO custom 64A1 replacement’ accomplished.
 Posted by at 7:14 pm
Rainbow Islands repair log #3
 PCB Repair Logs, Repair Logs  Comments Off on Rainbow Islands repair log #3
Nov 122014
First of all I wanna thank the people who donated me this (and other) PCB : “mille grazie” to Mr. Giuseppe (a long-standing arcade operator of my town) and his nice daughters Elena and Antonella!
Now, let’s begin with the log.
When I got  this PCB in my hands, I immediately tought it was a Rainbow Islands one:
Rainbow_Islands_Extra
But I was wrong, it actually was the Extra version (different ROMs and C-Chip).Before start the troubleshooting, I resoldered a wonky TC0070RGB module:
TC0070RGB_resoldered
Once powered on, I got a solid white screen with a clicking sound indicating that the watchdog circuit was active:
Rainbow_no_boot
There was clearly some trouble in main code execution so I started to test with my logic probe the two WORK RAMs  and I found some data lines stuck HIGH on the 6264 SRAM @IC25.I desoldered the chip and out-of-circuit test confirmed it as bad:
6264_testing
With a new RAM the board succesfully booted but graphics (tiles and sprites) were all blocky:
rainbow_blocky_GFX
This board (and other Taito ones on similar hardware ) uses two custom chips  in PGA package which generates sprites (the one marked ‘PC0900J’) and tiles (the ‘PC080SN’).They respectively address GFX ROMs through a couple of  74LS373 latches.Probing the 74LS373 @IC29 I found that all the outputs were absent.So I piggybacked a good one and tiles were restored but sprites were always blocky:
fixed_tiles
So, I went through the 74LS373 @IC18 and found it had output PIN19 stucked LOW while its input was toggling.Piggybacked this and also sprites were restored.Desoldered the two 74LS373 and they were indeed bad:
74LS373_testing
Replacing them both back this game to its former glory!
 Posted by at 9:09 pm
