Nova 2001 repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Nova 2001 repair log #1
Jan 312015
I got this pcb in December 2014 from Smitdogg of Mameworld as not working:
Foto 10-01-15 20 05 02
It was in good condition but it had already some TTLs replaced (socketed)
After firing it up I got a static coloured screen.
The Z80 was socketed so I first tried to replace it and to my surprise the game started apparently without any major faults with correct colours.
It was too good to be true and infact when the demo play started I got a very peculiar fault:
The background colours changed alternating between correct and not only during horizontal scrolling. During vertical scrolling the colour of the background was fixed in the last state (being good or bad).
I started the test of the pcb and everything looked good except the color check.
The “Back”  had some strange colours which didn’t look correct
pcb
I decided to start Mame and see the same screen on the emulated game and I got this:
0000
it seemed that there were some fixed bits on the background colours but that didn’t explain the alternating colours.
I looked for Nova 2001 schematics which luckily were available.
This game has plenty of 4116 drams which are prone to fault normally but they weren’t related to the fault I had.
I probed also the 3x  6116 SMD rams responsible for the background colors and the related 74LS273 buffers and they were all good.
At this point I had no clue where to probe, the schematics were really bad scanned and difficult to read.
I asked an advice to Charles MacDonald which pointed me to look on the AY8910 sound chips whose I/O are responsible for the  horizontal and vertical scrolling.
Cattura2
The first 3 bits BH0, BH1 and BH2 of AY8910@1,2A are negated and sent to a series of 74LS151 @12U, @11U, @10U and @9U.
All the signals going to these 74LS151 were good.
Cattura
I probed the outputs of all the 74LS151 and noticed that the TTL @12U was oscillating in sync with the alternating  background colors.
After checking the inputs of this chip, I noticed 3 stuck signals which were back traced to the 74LS164@12T whose inputs CLK and CLR were correct.
Changing this TTL restored the correct colour of the background during scrolling.
Pitfall II repair log #2
 PCB Repair Logs, Repair Logs  Comments Off on Pitfall II repair log #2
Jan 302015
The ‘F’ curse strikes again!
This could be a perfect title for this repair log but let’s start from the beginning
Got this faulty PCB from a friend:
Pitfall II_PCB
It had sever issues, only most parts of graphics were missing  and colors were clearly wrong while sprites barely visible
Pitfall_issue_
After studying the hardware I could identify the tile RAM in two MB8128 (2018/6161 compatible) chips @IC73 and @84.Probing them revealed irregular actitvity on some address lines.Piggybacking them with a good chip didn’t change anything.I could trace these address line back to the outputs of some 74LS157 multiplexers.Testing them with my HP10529A logic comparator gave me faults on three of them which I promptly desoldered and tested out-of-circuit having confirm they were all bad:
74LS157_out-of-circuit_testing
This improved graphics so that I could clearly also see the results of the ROM/RAM test:
improvement
IC73 and IC84 (tile/backgrounds RAMs) were riported still bad as well as the color RAM @IC85 so was time to investigate deeper.
Data bus of the color RAM (a 2016) was connected to a couple of 74LS175.Piggybacking the one @IC108 restored colors while piggybacking three 74LS245 @IC104, @IC105, @IC106 (involved in tile RAM data bus) restored most all  the  graphics and also the RAM/ROM test passed succesfully:
issue_fixed
But there was another issue (see picture below):
last_issue
To cut the story short I found another faulty 74LS157, one of them that I previously tested as good has gone bad while I was troubleshooting the board!Replaced it fixed completely the PCB.
fixed
Ah, I forgot…all faulty TTL ( nine in total : four 7LS157, one 74LS283 -not reported in this log-, one 74LS175 and three 74LS245) were manifactured by Fujitsu! Of course, the curse stroke again but I pushed it back! 🙂
 Posted by at 10:40 pm
Adventure Quiz Capcom World 2 (Japan 920611) PAL dump added
 PAL Updates  Comments Off on Adventure Quiz Capcom World 2 (Japan 920611) PAL dump added
Jan 302015
Today Bonky sent in a GAL16V8 replacement for the undumped ‘q522b’ @1A PAL from an Adventure Quiz Capcom World 2 (Japan 920611) CPS1 B-BOARD.Replacement was created by Neocps1 and tested by Bonky.Archive contains the .jed, .pld and .xml files.Thanks to both for their work.
 Posted by at 9:10 pm
Jan 252015
Got this faulty Violent Storm PCB from Ebay (well, actually seller sold me as Metamorphic Force one…)
ViolentStorm_PCB
When I turned it on all I got was a solid black screen but  this time watchdog circuit was not active.As many other Konami boards RESET signal is generated by PIN10 of  the SIL custom ‘051550’.In this case signal was correct (first LOW then HIGH) but not on main CPU (an MC68H000GFN16 in PLCC package) where it was stuck LOW.So was time to investigate.I could trace RESET signal from PIN10 of the ‘051550’ custom to PIN7 of a custom marked ‘053252’ (44PIN in QFP package) while , from other side, RESET (PIN18) of the main 68000 CPU was tied to PIN12 of this ‘053252’ IC through some inverter gates (74F04).This was confirmed also by Metamorphic Force schematics (which runs on same indentical hardware) I could find at a later time:
RESET_circuit
As I said RESET signal was correctly generated by ‘051550’ custom, routed to ‘053252’ ASIC but then coming out from it stuck LOW.So with this assumption I had no other way than try to replace the ‘053252’ ASIC (in MAME source it’s indicated as CRT and interrupt control unit):
053252__ASIC
And I was right since board successfully booted and all was properly working:
V_S_fixed
I was closing the case and declaring the board 100% fixed but the curse of the Konami hybrid sound module struck again!Infact while I was testing the board, the sound suddenly faded.But this time it was not only matter to replace all the SMT caps with tantalum ones but also the LA4705 audio amplifier broken due high ESR of the old caps and we all know that capacitors have the role to stabilize amplifier preventing its oscillation and failure:
audio_reworking
That’s all for today, I hope you enjoyed this repair log!
 Posted by at 9:33 pm
Zola-Puc Gal PAL dump added
 PAL Updates  Comments Off on Zola-Puc Gal PAL dump added
Jan 242015
Today Porchy dumped a PAL from a Zola-Puc Gal PCB.For the uninitiated, this game is a Pac-Man clone with some minor differences.Dump was obtained from a registered device so it’s an important achievement.It has been tested as working by Asure.Thanks to both.
 Posted by at 8:32 pm
