Gundhara repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Gundhara repair log #1
May 302015
Got this mint Gundhara PCB, a vertical shooter similar to Ikari Warriors, manifactured  by Banpresto in 1995:
Gundhara_PCB_800
When I powered it up game was fully playable but tilemaps were totally wrong :
wrong_tilemaps
Before you start every troubleshooting, first thing to do is studying the hardware.MAME is a great help for every repairer with its invaluable source of information provided.In this case here is an overview of the hardware (thanks to driver developer Luca Elia):
  • CPU : 68000 + [65C02] (only in the earlier games)
    Custom : X1-001A X1-002A (SDIP64) Sprites
    X1-001
    X1-002
    X1-003
    X1-004 (SDIP52) Inputs
    X1-005 X0-005
    X1-006 X0-006
    X1-007 (SDIP42) Video DAC
    X1-010 (QFP80) Sound: 16 Bit PCM
    X1-011 X1-012 (QFP100) Tilemaps
    X1-014 Sprites?
This information pointed me in the right direction, the part of circuit to be analysed was this:
X1-011_X1-012_800
You can see on the right part of the above picture the two custom ASIC tilemaps generator marked ‘X1-012’ (QFP100 package).When I checked the one @U45 I found some lifted pins:
X1-012@U45_800
A simple reflow of these pins was enough to restore tilemaps:
good_tilemaps
I was declaring this board 100% fixed but while testing it I noticed something wrong in its sound, some PCM samples were played wrongly (like enemy shots) compared to good reference of MAME.Once again our beloved emulator source gave me an help to pinpoint this trouble.There is another custom ASIC which is a 16 bit PCM chip marked ‘X1-010’ (QFP80 package) in the sound circuitry @U57:
X1-010@U57_800
One pin was lifted, a reflow restored correct sound.
Thanks MAME!This repair log is dedicated to you! 🙂
 Posted by at 8:10 pm
Xevious (Namco) PAL dump added
 PAL Updates  Comments Off on Xevious (Namco) PAL dump added
May 292015
Today, while troubleshooting a Xevious PCB (Namco board and not Atari) I dumped and reversed in GAL format the only PAL present.Original device is a not secured PAL10L8, dump has been tested working in a GAL16V8 targeting device.You can download it from our database as usually.
 Posted by at 8:21 pm
May 272015
Konami do always great games and one of them is, indeed, The End.Manifactured by Stern electronics, it was released and licensed by Konami in the far 1977.Game itself is a mixture of Space Invaders, Galaga and Phoenix.I got this board from same previous repaired boards batch and it was really in excellent shape (I could say ‘NOS’ using an Ebay terminology) for a piece of hardware with nearly 40 years on the back:
The_End_PCB
It came with its JAMMA adapter from Konami classic pinout (-5V required), it played fine but there was no sound at all, I could only hear some faint rustles coming out from the speaker.
Digital audio circuit is made of a Z80 CPU and a AY-3-8910 sound generator.Code ROMs were good but when I probed the two 2114 RAMs I found that address line A7 was stuck high on both.Studying a bit the hardware I could figure out that Z80 addresses the two 2114 through four 7408 quadruple AND gates.And I could trace the stuck address line back to PIN6 of the 7408 @IC41 (a Mitsubishi M53208P to be exact).I probed inputs and they were toggling fine while its output was, indeed, stuck high.So, without hesitations, I desoldered and tested it out-of-circuit:
7408@IC41_failed
It failed miserably.Fitted a good one  and I was able to restore the sound to this “aged” board.
 Posted by at 4:36 pm
Lethal Enforcers repair log #3
 PCB Repair Logs, Repair Logs  Comments Off on Lethal Enforcers repair log #3
May 242015
Another repair from the same PCB batch of previous logs (three in a row…), this is a Lethal Enforcers PCB in mint condition:
Lethal_Enforcers_PCB
Once powered up I got this static screen:
watchodog
and a ticking sound sign that board was watchdogging.In these cases first thing to check is the main CPU.Probing pins of the HD63C09E CPU (6809 compatible) I noticed that R/W (PIN32) was completely silent.This is  the control line through which CPU decide if write (active LOW) or read (HIGH) DATA onto the DATA bus.The fact that it’s an output and  it was inactive made me very suspicious.HD63C09E datasheet says that R/W line can be made in high impedance  if BA (PIN6) is HIGH but this was not my case since BA was pulsing LOW.
/WE line of 6264 WORK RAM stuck high.This is generated, indeed, by the /WR signal (PIN32) of main HD63C09E CPU through the BUS master arbitration circuitry.This lead me to desolder the CPU from board and try it in another board.It was really faulty.I socketed it too for easy maintenance:
HD63C09EP
With a good CPU fitted game obviously booted but showed jailbairs over backgorunds:
jailbairs
This a common problem on this Konami hardware which uses graphics custom ASICs in QFP package.Specifically Lethal Enforcers uses sprite and tilemap generators and these work always in pair.My issue was located on backgrounds so I went to inspect the pair marked 054156/054157 and found some lifted pins on the latter @S8:
054157_ASIC
I promptly reflowed them with my hot air rework station and goodbye jailbairs!Game 100% fixed.
jailbairs_fixed
 Posted by at 8:39 pm
May 242015
I use OSH Park quite a lot for various projects.
Recently I received the second version of my JAMMA Supergun back but thats not all.
Inside the packet was a little note
gameon
A nice little touch I thought so here is a shameless plug for OSH Park.
