Today, while troubleshooting a Xevious PCB (Namco board and not Atari) I dumped and reversed in GAL format the only PAL present.Original device is a not secured PAL10L8, dump has been tested working in a GAL16V8 targeting device.You can download it from our database as usually.
Konami do always great games and one of them is, indeed, The End.Manifactured by Stern electronics, it was released and licensed by Konami in the far 1977.Game itself is a mixture of Space Invaders, Galaga and Phoenix.I got this board from same previous repaired boards batch and it was really in excellent shape (I could say ‘NOS’ using an Ebay terminology) for a piece of hardware with nearly 40 years on the back:
It came with its JAMMA adapter from Konami classic pinout (-5V required), it played fine but there was no sound at all, I could only hear some faint rustles coming out from the speaker.
Digital audio circuit is made of a Z80 CPU and a AY-3-8910 sound generator.Code ROMs were good but when I probed the two 2114 RAMs I found that address line A7 was stuck high on both.Studying a bit the hardware I could figure out that Z80 addresses the two 2114 through four 7408 quadruple AND gates.And I could trace the stuck address line back to PIN6 of the 7408 @IC41 (a Mitsubishi M53208P to be exact).I probed inputs and they were toggling fine while its output was, indeed, stuck high.So, without hesitations, I desoldered and tested it out-of-circuit:
It failed miserably.Fitted a good one and I was able to restore the sound to this “aged” board.
Lethal Enforcers repair log #3
Another repair from the same PCB batch of previous logs (three in a row…), this is a Lethal Enforcers PCB in mint condition:
Once powered up I got this static screen:
and a ticking sound sign that board was watchdogging.In these cases first thing to check is the main CPU.Probing pins of the HD63C09E CPU (6809 compatible) I noticed that R/W (PIN32) was completely silent.This is the control line through which CPU decide if write (active LOW) or read (HIGH) DATA onto the DATA bus.The fact that it’s an output and it was inactive made me very suspicious.HD63C09E datasheet says that R/W line can be made in high impedance if BA (PIN6) is HIGH but this was not my case since BA was pulsing LOW.
/WE line of 6264 WORK RAM stuck high.This is generated, indeed, by the /WR signal (PIN32) of main HD63C09E CPU through the BUS master arbitration circuitry.This lead me to desolder the CPU from board and try it in another board.It was really faulty.I socketed it too for easy maintenance:
With a good CPU fitted game obviously booted but showed jailbairs over backgorunds:
This a common problem on this Konami hardware which uses graphics custom ASICs in QFP package.Specifically Lethal Enforcers uses sprite and tilemap generators and these work always in pair.My issue was located on backgrounds so I went to inspect the pair marked 054156/054157 and found some lifted pins on the latter @S8:
I promptly reflowed them with my hot air rework station and goodbye jailbairs!Game 100% fixed.
I use OSH Park quite a lot for various projects.
Recently I received the second version of my JAMMA Supergun back but thats not all.
Inside the packet was a little note
A nice little touch I thought so here is a shameless plug for OSH Park.
Arabian Magic repair log
Antoher board from the same batch of Sega System18 motherboards.
Ths is the time of a Taito F3 game (PCB version), Arabian Magic to be precise.Hardware is quite powerful as you can see from specifications:
- CPU: Motorola MC68EC020;
- Sound CPU: Motorola MC68000;
- Sound chip: Ensoniq ES5505 and ES5510 (DSP);
- Video resolution: 320×224;
- Board composition: Board and F3 cartridge;
- Hardware features: four scrolling layers, two sprite banks, Alpha blending
Board was in good condition :
It worked fine except for two stuck intupts (P1 and P2 2nd button) as you can see from I/O TEST mode:
In this kind of hardware all I/O (and watchdog, too) are handled by a custom ASIC marked TCO640FIO (120 PIN QFP package) @IC71:
All the inputs from JAMMA connector are connected first to pull-up resistor arrays so I checked them and they were good.Lastly I lifted involved PINs from ASIC but inputs were always stuck.So, at this point, replacing the ASIC, taking it from a donor board, was my last resort.So, time to remove and replace it:
and…success!All the inputs were restored and game fully enjoyable!
