Nitro Ball repair log
 PCB Repair Logs, Repair Logs  Comments Off on Nitro Ball repair log
Jun 212015
Got this Nitro Ball PCB from my friend Corrado as not working:
Nitro_Ball_PCB_
When I first fired it up I was greeted by a solid black screen.Hardware uses, like other DATA EAST games, a custom 68000 CPU in QFP package marked “59” whose pinout is unkown since no schematics are available and  nobody has yet figured it out.My first intention was to probe the RESET line on main CPU, this is the first thing I usually do when I got a totally dead board (along with CLOCK pin) but since I couldn’t I started with my visual inspection and I found this:
4.6uF_50V_lifted_pin
A 4.7uF 50V capacitor @C43 with anode terminal desoldered from its pad.This may seem a minor thing a but not in this case since this capacitor was part of the RESET circuitry along with a voltage monitor transistor (silkscreening suggests a  PST518A IC but a generic BC547 transistor was used instead in order to detect a voltage and generate a RESET signal) :
RESET_circuitry
Once replaced this capacitor board properly booted but all screen was red:
red_screen
A dominant red color means that blue and green ones were missing so I traced them back to three transistors:
BC547_colors_transistors
As you can see from picture above manifacturer/assembler used three compatible BC547 transistors compared to original silkscreened part adapting their different pinout by rotating them and twisting the base and collector legs.This caused a short circuit between the base and collector of the blue and green (TR2 and TR3 on picture) transistor.After clearing the short colors came back to normality.
colors_restored
No  further issues were found on PCB so I could declare this one 100% fixed.
 Posted by at 8:29 am
Hi-Lo EPP-01A EPROM Programmer PAL’s added
 PAL Updates  Comments Off on Hi-Lo EPP-01A EPROM Programmer PAL’s added
Jun 192015
Recently I was given a bunch of old programmers and things from a friend that was doing a clear out.
Among them was an old Hi-Lo System EPP-01A programmer which happened to have 3 x PALCE16V8 devices in it. All of them were locked and I don’t have the relevant ISA card to test the actual programmer out so these are untested. They don’t look too complicated though so im sure they will work just fine.
 Posted by at 6:45 pm
Nitro Ball PAL dumps added
 PAL Updates  Comments Off on Nitro Ball PAL dumps added
Jun 182015
Today, after repaired it, I dumped the five PAL16L8 on a DATA EAST Nitro Ball PCB (released in Japan as “Gun Ball”).They all match the ones from Dark Seal 2/Wizard Fire PCB except for the one located @K5 (no labels were on all PALs).Dumps have been tested as working in GAL16V8 targeting devices.I also reorganized these shared Data East PALs renaming them generically (like we  already done for Konami and Taito PLDs).
 Posted by at 10:05 pm
Pang repair log #2
 PCB Repair Logs, Repair Logs  Comments Off on Pang repair log #2
Jun 162015
Got a friends Pang PCB here for repair.
He had carried out the ROM swap (made by ArcadeHacker) to desuicide it but he had no output although we could hear it playing blind.
The board is very clean and a visual check revealed nothing.
On powering the board up I got this screen
IMAG1355
I could also hear the board did play blind so that’s a good sign.
I like to make little schematics for boards when I’m working on them and they don’t have any available and I quickly came up with this.
pang
I started probing back from the RED pin on the JAMMA edge connector and soon came to a RAM chip at location 8C. Probing this chip and its counterpart gave me some odd looking signals which I got suspicious about.
These chips are CXK5814 SRAM chips and they seem the be the most unreliable RAM by comparison.
One of the RAM’s had all its data lines stuck LOW while the other chips data lines were all dead despite all the enable lines working as they should and the address lines active.
At this point I was certain they were dead but one last test was to ‘piggyback’ a known good RAM chip on top of the suspected bad one. I chose the one with the dead data lines to avoid potential contention and I got a partial image on screen.
I desoldered both the RAM chips and replaced them. I didnt have any spares in my RAM bin but found a couple of skinny 6116 RAM’s on a scrap bootleg board.
IMAG1353
IMAG1359
Fitting these I now got this wonderful sight.
IMAG1356
IMAG1358
Job done.
Olivetti Prodest PC1-HD (HDD version) PAL dump added
 PAL Updates  Comments Off on Olivetti Prodest PC1-HD (HDD version) PAL dump added
Jun 132015
As announced some days ago, we have another (and  last) dump from Olivetti Prodest PC1-HD (the hard disk version).Binary dump of original PAL16L8 device was provided by José G. (JP-Retro ,JOSÉ GONÇALVES E PAULO SOUSA Group) and we took care of reversing its equations into a GAL16V8 replacement.Dump has been tested as working by José G, thanks to him and all other guys of Olivetti Prodest group.
 Posted by at 3:23 pm
