Knuckle Bash repair log #1
 PCB Repair Logs, Repair Logs  Comments Off on Knuckle Bash repair log #1
Aug 212015
Got this faulty Knuckle Bash PCB in a trade with my friend Ifog:
Kuckle Bash_PCB
For the uninitiated, it’s a side-scrolling beat ’em up developed and published by Toaplan in Japan in the 1993.
As expected, on the power up I was greeted by this scenario:
issue
Game was playing almost blind, all graphics were totally wrong replaced by colored blocks.All the GFX DATA are stored in four 42 PIN 16Mbit MASK ROMs:
GFX_MASK_ROMs
These devices are addressed by the near custom ASIC ‘GP9001’ @U13 which is the graphics processor unit of the system:
GFX_custom
Also schematics confirmed this:
GFX_MASK_ROMs_addressing
When I went to probe address lines of the MASK EPROMs, I found that most of them were silent.A closer inspection revealed the many pins were lifted.Pressing the custom chip with a clamp (a rude method perhaps but always effective) restored all the GFX :
fixed_with_clamp
So, I did a reflow of the custom chip passing the iron tip on its pins (with the clamp still in place) and this fix GFX stably.
Last thing to do was replacing some leaking 10mF axial electrolytic capacitors in the audio section (luckily corrosion didn’t involve any traces ) :
leaking_capacitors
Another great game preserved to eternity (well, hopefully…)!
P.S.
This board turned to be an undumped Korean revision.I sent dumps to MAME developers.
 Posted by at 7:25 pm
Aug 192015
Another Data East board on the bench today, it’s the time for an Heavy Barrel one from my collection :
Heavy_Barrel_CPU_board
As you can see from picture above, CPU board was in bad state, very dirty and dusty (besides it missed a couple of RAMs) so I decided to clean it washing with soap, toothbrush and warm water :
board_cleaning
Since drying the board under the sun would take some days and given that I have two Robocop PCBs which share the same CPU board of Heavy Barrel, I decided to troubleshoot at least its ROM board:
ROM_board
The first visual inspection revealed a broken IC @18F:
Boken_74LS08@18H
Thanks to schematics (but after removing its pieces I found also  the silkscreening under it) I could identify it in a 74LS08:
74LS08@18H
So was time to power it up for the first time getting this result:
tiles_issue_
Game was fully playable but with wrong backgrounds graphics.MAME source reports two set of tiles ROMs for each layer so I went to dump the first one to do a compare.When I tried to read the ROM ’24’ @17F, my programmer gave me a warning:
24@17F_warning
I pulled the 27512 EPROM device off the programmer and some pins started to fall off in my hands:
27512@17F_broken_pins
I burned a new device and this fixed the backgrounds issue:
backgrounds_fixed
I was thinking board was 100% fixed but while I was testing it, an horrible sound came from speaker:
Sound FXs was barely audible replaced  by the noises above.PCM samples are played by the usual OKI MSM6295 located on the ROM board.Diverting the OKI analog output (pin 36) to an external amplfier I could hear clear all the sound FXs but then the signal was lost along the way before it hit pin3 of 1458 OP-AMP and then be carried to CPU board to be mixed with the music (I circled in red the exact point) :
sound_mixing_
In this small part of circuit there are few discret components so I went to test them with my multimeter set for continuity test.When I put probes on the 100nF mylar capacitor @C3 the multimeter buzzed:
100nF_mylar_capacitor@C3JPG
I desoldered it and had confirm it was really shorted:
100nF_mylar_capacitor_shorted@C3JPG
Fitted a good capacitor restored full sound.End of job.
 Posted by at 11:11 pm
Robocop repair log #2
 PCB Repair Logs, Repair Logs  Comments Off on Robocop repair log #2
Aug 172015
Got this original Data East Rocobop for cheap:
Robocop_PCB
Board was marked as not working but when I fired it up all was fine except for sound what was completely missing.Swapping boards with another working set I had , I could pinpoint fault in the top CPU board.Analog section was fine so fault was of digital nature.Sound system is made of a main 6502 CPU, a YM3812 and YM2203 sound synthesis chips:
digital_sound_section
Probing the 6502 CPU I found that it was undergone an hardware interrupt since its NMI line (pin 6) was low.Technically speaking an interrupt is an asynchronous signal generated to CPU from external peripherals indicating an event that needs immediate attention.
This lead me to think that the YM3812 or the YM2203 were bad (the IRQ line – pin 4-  of the 6502 is connected to both these devices) so I desoldered them.But I was wrong since they were good.Analyzyng with a logic probe  the TMM2015 SRAM @2F connected to the 6502 CPU revealed nothing abnormal but this didn’t convince me so I used my analog oscilloscope and found weak signal on some data lines compared to healthy ones:
DATA_lines_comparing_TMM2015@2F
I piggybacked the RAM and sound was fully restored.Time to desoder and test the IC out of circuit in where it failed:
TMM2015_RAM_2F
Fitted a new RAM and archivied also this board as fixed.
 Posted by at 10:27 am
X Multiply repair log #4
 PCB Repair Logs, Repair Logs  Comments Off on X Multiply repair log #4
Aug 162015
Got this Irem X-Multiply PCB (actually a conversion from an Hammerin’ Harry M81 board) from my friend Josef for a repair:
X-Multiply_PCB
It showed a graphical issue where some sprites (like enemy shots) were blocky during gameplay and backgrounds missing during attract mode:
issues
Sprites and tiles data are stored respectively in eight 1Mbit EPROMs on video board for a total of sixteen devices.
sprites_tiles_EPROMs
Original devices were 1Mbit 28 pin MASK ROM:
https://pdf.datasheetarchive.com/datasheetsmain/Datasheets-X2/DSA62700099.pdf
while who made this conversion used ST M27C1000 :
https://pdf.datasheetarchive.com/indexerfiles/Scans-065/DSA2IH00172244.pdf
Video board has some jumpers which must be closed according to the type of adopted devices :
jumper
In this case the jumper configuration was set to  ‘EP’ so not suitable for 27C1000 but required the use of JEDEC devices like 27C1001 or 27C010 (while the ‘MASK’ setting can work straight only with the original 28 pin 1Mbit MASK ROMs and not with 27C1000 which, although the similar pinout, have some extra pins to deal with, so some modifications are needed)
Reprogramming all the data for sprites and tiles into 27C010 1Mbit JEDEC EPROMs fixed graphics completely.
fixed_
 Posted by at 1:16 pm
Namco NB-1 PAL dump added
 PAL Updates  Comments Off on Namco NB-1 PAL dump added
Aug 152015
Today I dumped a PAL from a Point Blank PCB (Namco NB-1 hardware).There was another one (a PALCE16V8H) but device is set as registered so not dumpable.Dump is untested for now since board is faulty but we mark it as assumed working anyway.
 Posted by at 9:07 pm
