Sep 202015
I got this Major Title 2 PCB for cheap from ‘Smitdogg’ of MAME team:
Major Title 2_PCBX i
He said me board had some GFX issues.Actually when I powered it up I got no sprites at all:
no_sprites
For first I checked the sprites EPROMs with my logic probe and found no activity on all pins.These four sprites MASK ROMs on video board are addressed by the ASIC “GA22” on CPU board :
NANAO_GA22
I probed it and all its pins were silent too.I tried to reflow it without luck, sprites were still absent.Then, looking at the board, I noticed an open jumper ‘J3’ right hear the GA22 ASIC:
J3_open_jumper
Looking at other M92 CPU boards I could see that this jumper was always closed to position ‘B’ (so with central and right pins shorted together).So I did it on my board too:
J3_closed_jumper
and sprites were magically restored!
Now the technical explanation.The jumper is actually for selecting which clock signal must be delivered to the sprites generator ASIC “GA22”.If closed in ‘B’ position, ASIC will receive a clock signal of 26.6666 Mhz (which is the correct value for most of M92 games) :
26.66666_signal
If closed in ‘W’ postition, the ASIC will get a 18.000MHz signal (no sprites with this configuration) :
18.000MHz_signal
Last issue to fix was some audio background noise:
I quickly traced it to a missing 47uF 16V electrolytic capacitor @C213 in analog sound section:
missing_C213_capacitor
End of job.
 Posted by at 10:17 pm
Slam Masters (US) CPS 1.5 PAL dump added
 PAL Updates  Comments Off on Slam Masters (US) CPS 1.5 PAL dump added
Sep 182015
In the past days ‘coolmod’ dumped the PAL from his Capcom Slam Masters (US version) CPS 1.5 PCB.PLD was an unlocked PAL16L8 so he provided both original and GAL16V8 .jed and successfully tested the latter.Thanks to him.
 Posted by at 6:43 pm
Logic Probe testing
 General  Comments Off on Logic Probe testing
Sep 112015
This is something I’ve wanted to do for a while but never got around to.
The following is a mix of my personal thoughts and findings. I realise others will have the same equipment and the operation of these will likely differ.
This post is in no way a “What to buy” guide. It is meant to show how three different probes work at different voltage levels.
I’ve got three logic probes but only ever use one of them as I really like it but is it giving me the most accurate reading?
Lets take a look
So here are what I’ve got.
IMAG1589
Top one is a Tenma branded one (also seen this under different brand names). This is my probe of choice.
Second one is an unbranded one. Used this once and it feels really cheap in hand but it does have a buzzer in it to accompany the LED’s which is nice.
Lastly is an RS branded one. This is a recent eBay purchase bought mainly for this write-up.
First off, lead length.
There is nothing worse than being restricted but short leads when probing around a board.
Tenma = 58cm
Unbranded = 146cm
RS = 171cm
So my probe of choice has the shortest lead length. I must admit it has hindered me in the past.
To test the logic thresholds I used my programmable PSU and used the outputs that have a common ground.
Here are the ‘official’ threshold levels according to Wikipedia for TTL and CMOS (assumming VCC = +5v).
logic levels
The pictures below show the voltage at which the LOW LED goes OFF and the voltage at which the HIGH LED comes on.
Lets look at the Tenma probe to start with.
This probe only supports TTL logic levels where as the other two can switch between TTL and CMOS.
NOTE: You want to be looking at the smaller voltage settings at the bottom (under ‘Set’). This is the actual voltage settings and was checked for accuracy with a Fluke multimeter.
LOGIC LOW THRESHOLD (TTL)
Tenma Low_on
LOGIC HIGH THRESHOLD (TTL)
Tenma High_on
As you can see the LOW level begins to show around 0.1v below the stated thresholds. Not too bothered about that. Whats more worrying is the HIGH trigger point, its nearly 1v out of spec.
Next up is the unbranded probe
TTL-UB Low_off
TTL-UB High_on
This has similar LOW trigger levels as the Tenma one and the HIGH trigger is around 0.7v lower bringing it nearer to the thresholds stated. Not too bad.
Finally the RS branded probe. The pictures are pretty useless here as the low brightness level of the probe at these voltages make it difficult to capture on camera but its there.
TTL-RS Low_off
TTL-RS High_on
Results are very positive for this probe on the TTL setting.
Next I test the CMOS setting. As the Tenma cannot support CMOS it is obviously excluded from this test.
Unbranded first.
LOGIC LOW THRESHOLD (CMOS)
CMOS-UB Low_off
LOGIC HIGH THRESHOLD (CMOS)
CMOS-UB High_on
The LOW trigger is a bit low here but the HIGH is pretty good.
Now for the RS probe. Once again the pictures are pretty rubbish as the low level of the LED doesnt really show up on the camera but I assure you it is there.
CMOS-RS Low_off
CMOS-RS High_on
The LOW trigger is much the same but the HIGH is a little higher than the unbranded.
So here we have the full results
results
This test wasn’t the greatest and it is only my interpretation of it. For example, should I have taken readings when the LED’s were at full illumination? Different people will prefer different things.
The unbranded probe didn’t seem to have that dimming of the LED’s depending on the voltage. It was clearly either ON or OFF. Whether this is a good or bad thing will depend on user preference. For me its not too good. This probe however is the only one to have the buzzer which is a nice thing to have sometimes.
I think for me the RS probe will now be my probe of choice. It has nice long leads, feels good to hold and use and the results were decent too.
 Posted by at 1:19 pm
Sep 102015
Got this NebulasRay PCB ( converted from another Namco NB-1 game) from my friend Josef for a repair:
NebulasRay_PCB
For the uninitiated the game is a vertical shoot ’em up released by Namco in the 1994.It runs on Namco NB-1 platform.Here are the specs:
  • Main CPU: Motorola 68EC020 32-bit processor @ 12.5 MHz (for the NB-1 games), 24.192 MHz (for the NB-2 games)
  • Secondary CPUs: Namco C329 with C137
  • Custom graphics chips: Namco C123, C145, C156 and C116 (for the graphic effects) with Namco C355, C187 and C347 (for the motion objects)
  • Sound CPU: Namco C351 (utilized for the NB-1 games), Namco C75 (Motorola M37702-based 16-bit) @ 16.128 MHz (utilized for the NB-2 games)
  • PCM sound chip: C352 @ 16.384 MHz that supports 8-bit linear and 8-bit muLaw PCM with four-channel output
  • Control chip: Namco C160
  • Board composition: two boards (NB-1) or single board (NB-2); an additional “gun” interface board was also utilized for Point Blank.
Board actually booted but didn’t pass the disclaimer screen:
disclaimer_stuck_
As said, main CPU is a 68EC020.Probing it, revelead a good activity until it got stuck on the above screen, at this point most of control lines were going to high impedance state terminating the BUS activity.So, there had to be some trouble in the main code execution but, given the hardware complexity and lack of documentation, I was pretty lost.
I started to do some tracing on PCB so I could locate the WORK RAMs ( two Toshiba TC551001 @5C and 6C):
WORK_RAM_C351_
I figured out that they were not addressed directly by main CPU but through the near custom C351 (which is actually the custom sound CPU).I replaced both RAM but without luck.So, I removed the custom C351 and checking traces underneath it I found two breaks which I patched with some tiny wires:
C351_underneath
With this fix the board passed the initial disclaimer screen but went straight into test mode although dipswitches were set to off.I quickly traced this to a missing 74HC253 multiplexer @4F:
missing_74HC253@4F
Finally the board entered in game but all sprites were wrong :
wrong_sprites
Object RAMs are two Mitsubishi M5M5256 @20M and 21M:
object_RAMs
A closer inspection revealed some loose pins that I promptly resoldered.In this way all sprites were restored except for jailbairs on some of them (like game title ):
jailbairs
All sprites ROMs are on the small daughterboard in form of 8 MX29F1610 FLASH devices :
object_PCB
Since  the board was a converted one, they were hand soldered not in professional way (let’s say so..) so I reflowed them.Graphics and sound were perfect now but some inputs were missing or stuck like reported in switch test:
missing_stuck_inputs
The inputs circuitry is so designed on this kind of hardware : JAMMA connector pin is connected to some EMI filter arrays , then to some custom CUS93 resistor arrays, then to some 74HC253 which combine inputs into outputs that go to the ASIC C160 (which is the I/O chip):
inputs_circuitry
After some tracing I could pinpoint the faults in two bad CUS93 resistor arrays @2L and 1F:
CUS93
Besides, there was intermittent contact between some pins of JAMMA connector and EMI network filter array @1K:
EMI_filter_array_2
Board 100% fixed.End of (long..) job.
 Posted by at 11:30 pm
