Sunset Riders repair log #2
 PCB Repair Logs  Comments Off on Sunset Riders repair log #2
Sep 262015
Got this Sunset Riders PCB for a repair:
Sunset Riders_PCB
Gameplay and graphics were OK but music was accelerated and distorted:
Music is generated by the YM2151 sound synthesis chip widely used in many arcade systems:
YM2151
For first I checked its clock input pin and measured frequency was fine (3.579 MHz)  :
good_YM2151_clock
When I piggybacked a good chip on it correct music tempo was restored:
Replacing the chip fixed the issue completely.
 Posted by at 8:37 am
Sep 252015
This is one I fixed some time ago but still worth posting here.
Problem 1: The display would exhibit streaks of grey lines mostly around sprites as the pcb warmed up & progressively get worse over the period. Symptoms would sometimes completely disappear after 10-15 minutes.
Note the grey lines around the sprites.
IMG_1387IMG_1424
After inspecting the board there didn’t appear to be any bad connections. I suspected an intermittent component fault.
I didn’t have any freeze spray so I cooled off suspect chips ( I used some ice wrapped up in a sealed plastic bag to avoid any leak )  and found cooling the transistor @ Q4 on the video board would reproduce the above problems. I replaced the faulty 2sc1815 transistor at Q4 on the video board which cleaned up the video sync signal.
Problem 2: Game boots sometimes, other times it does not start and boots to junk.
Probed 6502 address pins, found that all were stuck high whenever the game failed to boot. All other signals looked OK. I tried substituting the main CPU for the sound CPU ( a  6502 as well ) but the symptoms were the same.
I traced the RST signal from the CPU to a 555 timer. There appeared to be a problem with pin 8 from the inverter at 9C to the trigger of the 555. Whenever the game booted to junk pin 8 of the inverter was floating & my logic probe was not registering the normal RST behaviour you would expect. I suspected a bad LS04 at 9C and planned to replace it.
Removed the LS04 at 9C. Pin 7 which is the ground pin was crushed under the IC. In other words it completely missed the plate thru hole ( it was blocked with solder ) during manufacturing and wasn’t making good contact with the ground pad. This game would have been faulty since the day it left the factory & explains the chip’s intermittent behavior.
Re-installed the inverter & re-tested with good results, no more booting to junk!
NANAO MS9-29S chassis repair log
 Monitor Repair Log, Repair Logs  Comments Off on NANAO MS9-29S chassis repair log
Sep 242015
Had this chassis for a long time sat in my loft. Its never worked properly and testing it now it doesn’t do anything.
prework
underside
Taking a good look at the chassis showed that quite a few capacitors had been leaking and testing random ones with the ESR tester revealed plenty more bad ones.
As it was in a poor state and also seeing as it is my first attempt at a monitor repair I opted to replaced pretty much every cap I could and do a clean up along the way.
I removed all the caps and tested each one that came out. Here is a list of the ones I found to be bad:
C958 – 47uF 16v
C956 – 680uF 10v
C457 – 10uF 50v
C459 – 22uF 50v
C561 – 47uF 16v
C451 – 22uF 50v
C222 – 22uF 50v
C201 – 47uF 16v
C203 – 47uF 16v
C955 – 180uF 25v
C953 – 47uF 160v
C513 – 10uF 250v
The electrolytic capacitor on the neck board was also bad.
Also found resister R585 (120k ohm) was damaged.
leaked
I ordered up the caps and cleaned up the PCB.
cleaned
I then turned my attention to the remote board.
remote1
This had two pots missing but had a couple of different ones hacked in their place and the smoothing capacitor was also leaking. I found some 10k Alps potentiometers on eBay so ordered a couple of those too.
The existing pots look in bad shape but they check out OK and operate quite smoothly so ill leave them alone for now.
remote2
A few days later all my stuff had arrived from Mouser and I was ready to put this thing back together.
done
I fitted it back into my spare 29″ tube and fired it up for the first test.
With a bit of tweaking I got the decent picture. The photo doesn’t really do it justice but I’m pleased with the results.
 Posted by at 11:59 am
Sep 232015
24/09/2015
A09 Konami-1 v1.4 update ( enhanced )
This is the final version unless some major bugs are found. I really can’t think of any other features you would want in an assembler.
  • RESET & IRQ vector support via -r & -i command line switches
  • Specifying -r or -i switch automatically pads binary to nearest multiple of 8kb
  • Creates multiple binary files from target for easy deployment to EPROMs ( max 8*8kb files )
The source code within the following archive contains original code which is copyright under the GPL2 & BSD3 licenses.
Please see comments in a09.c & konami1.c for license details.
Version: A09 v1.4
1.4
25/08/2015
A09 Konami-1 v1.1 update ( enhanced )
In this version the following improvements have been made
  • Source lines increased to 256 characters
  • Symbols increased to 32 characters
  • Use of underscored permitted in symbols
  • Symbol table is generated dynamically, previously it was limited to 2048 labels
Source, Windows & OSx64 executable provided in the package which can be downloaded from Programs/Software.
Thanks and credit goes out to Cmonkey for the first 3 improvements.
Version: A09 v1.1
v1.1
12/07/2015
If you’re reading this again at some point in the future then chances are you’ve discovered the following error message and want to fix it.
Sorry, no storage for symbols!!!
The A09 assembler has a maximum limit of 2048 labels hard coded by default which is definitely not enough if you want to re-assemble 6809 source from some of the konami1 games, dis-assembly can easily exceed 2048 labels.
#define NLABELS 2048
Modify the above value of 2048 in the source to your desired value and compile using the following command line. I increased mine to 100,000 as memory is not an issue these days.
gcc -o A09.exe A09.c konami1.c
9/7/2015
To get people who are interested started in home-brew apps on the Konami-1. I’ve included a very basic hello world asm source example which I’ve added to the download package. Produces the following output on a Track & Field PCB in SOCKET1A. The game EPROM A5 must be in SOCKET5A for this to work as the reset vector to the ROM A1 is obtained here.
Normally, your home brew code should be modified to start from 0xe000 and installed in SOCKET5A on the track & field pcb. The binary should be padded out to 8kb and the reset vector can be set to e000 from offset fffe in the produced binary using a hex editor.
7/7/2015
This assembler is based on the original A09 assembler sources written by L.C. Benschop which can be found here at https://koti.mbnet.fi/~atjs/mc6809/
This is a modified version of the above source that encrypts op-codes in order to run code on the Konami-1 CPU. This was the custom 6809 CPU used in games such as Gyruss, Track & Field, Circus Charlie, Roc ‘n Rope..etc.
This will allow for home-brew apps to run on the Konami-1 CPU without the need to encrypt op-codes by hand. The code uses the konami1_decodebyte() as found in the MAME sources, this function handles the op-code encryption for the Konami1.
Version: A09 v1.0
k1
Shadow Warriors repair log
 PCB Repair Logs, Repair Logs  Comments Off on Shadow Warriors repair log
Sep 202015
Just a quick fix for a Shadow Warriors PCB I had since many years but never looked at:
Shadow Warriors_PCB
Gameplay was fine but all the backgrounds GFX were scrambled and messy:
bad_backgrounds
This is the part of circuit which generates the backgrounds, located on video board:
backgrounds_circuitry
Luckily EPROMs and RAMs were socketed so I first tested the latter and found a bad one @3D (a Toshiba T5563 pin to pin compatible to a generic 6264) :
T5563@3D
Replacing the bad chip was enough to clear the issue.
backgrounds_fixed
 Posted by at 11:21 pm
