Street Fighter II CE repair log
 PCB Repair Logs, Repair Logs  Comments Off on Street Fighter II CE repair log
Sep 282015
I picked up an original Street Fighter II CE PCB off eBay with minor video issues. The seller also claimed that the sound didn’t work but this turned out to be the volume pot turned all the way down.
Screen was full of jail bars and graphics corruption. Tested all mask roms and confirmed two bad ones ( s92-1M & s92-2M ). These chips appeared to have some liquid spilled on them ( coffee or some other warm drink ) at some point. Several pins on both mask roms were corroded badly. I replaced the bad mask roms & burned the correct data on two EPROMS ( 27c400s ). This cleared up the jail bars however graphics corruption was still present, see the following screen shots below.
IMG_2243
IMG_2245
After two or three minutes of playing corruption almost completely disappeared. The problem could only be reproduced by turning the unit off for a few minutes and back on again. I replaced three mask rom IC sockets which were also damaged from exposure to the moisture but there was no change in symptoms, this left me scratching my head.
I flexed the B board between at the mask rom area using some pressure from my index finger and the graphics came up better than before as I applied pressure. I knew I was dealing with a break somewhere on the component side of the PCB underneath the sockets. I put the game in test mode & probed the each pin on the mask roms. Eventually I reached pin 31 ( ByteVPP ) on s92-2M, as my probe made contact to it, the sprites transitioned/flickered between looking correct & then glitchy.
I turned the game off & set my DMM to continuity mode. I measured nothing between s92-1M & s92-2M on pin 31, an obvious break here. I patched the break with some AWG wire & hooked it up on the solder side. This fixed the video issue somewhat but I also detected another break on the solder side between s92-1M & s92-3M ( on pin 10 ) which I patched as well. This fixed the game and my graphics came back 100% complete.
IMG_0358
Cowboys of Moo Mesa PAL dump added
 PAL Updates  Comments Off on Cowboys of Moo Mesa PAL dump added
Sep 272015
I dumped and added the PAL20L10 device (055373) from a Cowboy Moo Mesa PCB today.
The board doesn’t work so it is marked as untested and would appreciate any feedback on this one.
 Posted by at 6:26 pm
Splatterhouse repair log #3
 PCB Repair Logs  Comments Off on Splatterhouse repair log #3
Sep 262015
Another great game on the bench, it’s the turn of Splatterhouse.
Splatterhouse_PCB
It was told me that PCB didn’t boot at all giving only a black screen.First thing I do before powering up a faulty board is to check for shorts with a multimeter.Indeed, this PCB showed a dead short between VCC and GND.Since boardset is made of a CPU and ROM board, I separate them and could locate the short on the ROM board while CPU one was succesfully tested.
I removed all the EPROMs and MASK ROM but short was still here.Usually components prone to go shorted are ceramic capacitors and seminconductors like diodes, transistors.Inspecting the board I noticed a diode on the right of the JAMMA connector @D1.According the schematics it’s a 6.2 zener diode (type 1Z6.2 from Toshiba).Its datasheet says that it’s used as transient suppressor so to protect devices from voltage spikes:
https://www.jammarcade.net/files/Datasheets/1Z6.2.pdf
Obviously, since cathode of diode was tied to VCC and anode to GND (a zener diode must be polarized inversely in order to do its job) I read it in circuit  as shorted.But, when I lifted one lead, the short on PCB was cleared :
short_cleared_
So this diode was the culprit :
diode@D1_shorted
Once removed the short, the PCB booted stuck on this screen:
EEPROM_ERROR
SInce I experienced similar issue on other Namco System 1 boards, I could quickly trace this to a bad custom ’64A1′ @M4:
bad_64A1@M4
Replacing it with a properly programmed HD63701 MCU (see article on our guide section) fixed the board:
fixed
 Posted by at 10:19 am
Sunset Riders repair log #2
 PCB Repair Logs  Comments Off on Sunset Riders repair log #2
Sep 262015
Got this Sunset Riders PCB for a repair:
Sunset Riders_PCB
Gameplay and graphics were OK but music was accelerated and distorted:
Music is generated by the YM2151 sound synthesis chip widely used in many arcade systems:
YM2151
For first I checked its clock input pin and measured frequency was fine (3.579 MHz)  :
good_YM2151_clock
When I piggybacked a good chip on it correct music tempo was restored:
Replacing the chip fixed the issue completely.
 Posted by at 8:37 am
Sep 252015
This is one I fixed some time ago but still worth posting here.
Problem 1: The display would exhibit streaks of grey lines mostly around sprites as the pcb warmed up & progressively get worse over the period. Symptoms would sometimes completely disappear after 10-15 minutes.
Note the grey lines around the sprites.
IMG_1387IMG_1424
After inspecting the board there didn’t appear to be any bad connections. I suspected an intermittent component fault.
I didn’t have any freeze spray so I cooled off suspect chips ( I used some ice wrapped up in a sealed plastic bag to avoid any leak )  and found cooling the transistor @ Q4 on the video board would reproduce the above problems. I replaced the faulty 2sc1815 transistor at Q4 on the video board which cleaned up the video sync signal.
Problem 2: Game boots sometimes, other times it does not start and boots to junk.
Probed 6502 address pins, found that all were stuck high whenever the game failed to boot. All other signals looked OK. I tried substituting the main CPU for the sound CPU ( a  6502 as well ) but the symptoms were the same.
I traced the RST signal from the CPU to a 555 timer. There appeared to be a problem with pin 8 from the inverter at 9C to the trigger of the 555. Whenever the game booted to junk pin 8 of the inverter was floating & my logic probe was not registering the normal RST behaviour you would expect. I suspected a bad LS04 at 9C and planned to replace it.
Removed the LS04 at 9C. Pin 7 which is the ground pin was crushed under the IC. In other words it completely missed the plate thru hole ( it was blocked with solder ) during manufacturing and wasn’t making good contact with the ground pad. This game would have been faulty since the day it left the factory & explains the chip’s intermittent behavior.
Re-installed the inverter & re-tested with good results, no more booting to junk!
