Wardner repair log
 PCB Repair Logs  Comments Off on Wardner repair log
Dec 062015
I got this Wardner PCB for a repair from my friend Zoran:
Wardner_PCB
Gameplay was fine except for some minor sprites glitch in form of some sparkling dots:
sprites_issue_
Studying a bit the hardware, I could figure out where the sprites circuitry lied:
sprite_circuitry
The four EPROMs were dumped good, the six 2148 RAM were fine as well.But when I probe the three 74ALS169 with my BK550 logic comparator I got trouble on pin15 of the ones @B21 an C21:
74ASL169@B21_@_faultyC21
74ASL169@B21_@C21_compare
I desoldered them but they tested fine in all my programmer.I replaced them anyway and this cleared the sprites issue.Job done.
 Posted by at 10:56 pm
Dec 042015
Another Rainbow Islands PCB to repair.
This, like the previous repair (#7) showed a solid white screen, however, if left alone for about 30 seconds I would get the following displayed;
IMAG0151ri
I found a bad object/sprite 2018 (6116) RAM at location IC50, so this was replaced with a fresh 2018 RAM.
The PCB was now working 100%, and put on the shelf.   That was not the end of it though.
The next day, the PCB was dead again, just showing another solid white screen.  Probing around PCB at the logic, eventually I came back to the object RAM and found that another had failed at location IC51.  This was then replaced, and the PCB sprang back to life but now with issues.  Colours were missing or wrong on the display.
You can just see from my blurry picture that the RAINBOW PROJECT screen is all wrong, no blue background and the colours are missing.  Only the first two letters on each row have a colour (green and grey);
RI_20_B
Here, interestingly, the 1UP and 2UP are white, should be green (1UP) and blue (2UP).  Also, the HIGH SCORE and TAITO logo should be red.  The Rainbow Islands logo looks intact, but the colours are solid and not rotating like they should;
RI_17_B
The MAP screen has not escaped either, most of the colours are gone;
RI_18_B
The actual game has suffered too.  It’s hard to tell, but everything is there and perfectly formed, just missing colour so either appears corrupted or simply missing;
RI_19_B
Not even the TEST CARD escaped;
RI_16_B
I have already ruled out the TC0070 RGB SIP module as being the cause as the colours are there, just not in the right places.
While I was probing around the board, things got worse, now the sprites have broken up;
RI_21_B
Eventually, the PCB stopped running again and I got this message on the display;
RI_5_B
Another failed object/sprite 2018 (6116) RAM, this time at location IC50.
RI_7_B
So this was replaced and I now got this display;
RI_4_B
At first glance I thought it was still the same message, OBJECT RAM ERROR, but then noticed this time it was COLOR RAM ERROR.
So, I replaced the bad colour 2018 (6116) RAM at location IC70 and the PCB was running again, with the sprites now intact again.
RI_6_B
At this stage, I was becoming a bit frustrated with the failing RAM, so I bit the bullet and just replaced them all so I can concentrate on the colour problem;
RI_3_B
RI_11_B
It was a good move because now at least the PCB was running stable.
I was starting to get a bit fed up looking for the colour problem, and Caius very kindly offered me some help.  Infact, he was a massive help and told me exactly where to look for the problem.
With help from Caius, eventually I found that pin 15 of the 74LS157 at IC36 was floating (using my logic probe).  This is the IC’s enable line, and it should have been tied to VCC (through the orange disc 104 capacitor).
It was then I notice the burned/damaged trace going to the orange disc 104 capacitor;
RI_2_B
Very odd place to find a damaged trace, certainly not very accessible.  I had no idea how it was damaged until Caius mentioned it has happened to him also.  Like Caius said, I must have accidently fried the trace by short-circuiting it during my in-circuit testing.
I do recall the PC PSU for my Supergun shutting down due to a short when I was probing the PCB.
So, using kynar wire I patched the damaged trace from underneath;
RI_12_B
The game’s display was now 100% restored;
RI_13_B
RI_14_B
RI_9_B
RI_15_B
Massive thanks to Caius, whom without I would not have solved this and just given up.
Dec 032015
I was fortunate enough to obtain an original Taito Rainbow Islands PCB recently, which of course was not working.
I tested the PCB in my Supergun and was presented a solid white screen;
ri_fix_1
Checking the 68K CPU, the clock was fine, and RESET line was held high, there was activity around the CPU which indicated it was trying to execute code.
The work RAM looked good, so I checked the two 62256 SRAMs that the PC080SN custom uses for all backgrounds/tiles.  The outputs looked bad on both.  I also noticed that when I touch the pins on the SRAMs the screen display changed.
RI_12
I removed the SRAMs (IC3 & IC4) and confirmed they were bad in a RAM tester.
ri_10
I installed sockets for easy maintenance and replaced with fresh SRAMs;
ri_7
The PCB was now running, but had some issues with background/tiling;
ri_5
ri_4
ri_3
ri_2
Speaking to my friend Porchy about this fault, he stated that it appeared that Bit 4 (counting from 0) was stuck LO, and that the PC080SN custom was responsible for it (RAM lies at address 0xC00000 – 0xC0FFFF).
I was hopeful it was not a fault within the custom, and eventually after probing found that IC12 (74LS373 Octal Latch) Pin 9 was stuck LO (should have been pulsing LO/HI).
ri_9
I removed the IC, installed socket with fresh 74LS373 and was greeted with a fully restored display;
ri_11
I did notice however that sometimes the display would lose all the BLUE.  So my attention turned to the TC0070 SIP custom that handles RGB.  I found a cracked pin (highlighted with Red arrow), which I resoldered to resolve it;
ri_6
It was now running perfectly, except for the sound which appeared to be absent totally.
I checked the Z80 CPU which handles sound, and it was definitely running code.  So I checked the TL074 op-amp at location IC67 and found it appeared dead (no output, but probing input I could hear the sound!).  So I removed it, installed socket with fresh TL074 to fully restore the sound;
ri_8
Many thanks for Porchy for his help with this repair.
Another Rainbow Islands Log to come very shortly, solved with help from my new friend Caius.
New PAL dumps added
 PAL Updates  Comments Off on New PAL dumps added
Dec 022015
Today I dumped a couple of new PALs.The first comes from a Sega Puyo Puyo board.This PAL should be unique to this game while the other two PALs on board (already dumped and on database) should be shared among all Sega C/C2 boards.Original device was a secured GAL16V8A.
The second dump was obtained from a CK2605 of a Chequered Flag PCB, then I successfully converted the fusemap to a GAL18V10 targeting device (first reading device as PLS153 and reducing its equations to a CK2605 fusemap using the Charles MacDonald PLA utility).You can find both dumps on our database as usual.
 Posted by at 10:00 am
Chequered Flag double repair log
 PCB Repair Logs  Comments Off on Chequered Flag double repair log
Nov 302015
I got a couple of Chequered Flag PCBs for a repair.Here’s the first:
Chequered_Flag#1
The MASK ROM test reported an error on a character ROM at a certain location:
self_test_error
which caused some garbage on screen:
GFX_issue
Launching MAME I could figure out the ROM reported as bad was the one @N16:
0000
Device itself was a non 32 pin non-JEDEC 27C1000 mounted on a custom socket in place of the classic 1Mbit 28 pin MASK ROM.So I read it and it matched the one on MAME sets.Probing it I found that its pin 28 (A13) was silent,I traced it back to the a near custom marked ‘051316’ that addresses the entire character ROM :
051316
A dead address line means that the IC has an internal fault so my only option was to replace it and this is what I did taking it from another dead board:
051316_reworking
With a good custom the MASK ROMs test successfully passed and all GFX issues vanished:
test_good
The second PCB :
Chequered_Flag#2
had slight sprites issue.Here’s a comparison with a MAME snapshot (on the left):
sprites_comparison
A visual inspection of the board revealed some lifted pins of the two ASICs sprites generators:
sprites_generators
A reflow was enough to restore correct sprites:
fixed
End of (double) job.
 Posted by at 11:41 pm
