Quartet repair log
 PCB Repair Logs, Repair Logs  Comments Off on Quartet repair log
Mar 042016
Here is a recently repaired Quartet running on Sega pre-system 16 hardware.
quartet1
The 3 replaced chips are highlighted in red. I will explain every step of the repair process below.
1) The game was booting to a garbled screen:
quartet2
The 74LS04 located at 1H (an inverter, manufactured by Fujitsu) had good clock signals on entry pins 11 and 13 but had floating signals on outputs pins 10 and 12. Replacing the chip changed the result on boot…
2) I then got a screen with garbled graphics but with a countdown appearing at the center.
quartet3
This is normal on pre-system 16 games. Normally, after reaching 0, the game is booting. Here, I got a black screen after the countdown.
I noticed that the reset pin on the 68000 had a square looking wave signal, which was pretty weird (it should be a linear signal at +5V). The chip that generates the reset signal is a MB3771 located at 1G (again, manufactured by Fujitsu). Probing its pins made the game sometimes booting. I replaced it by a new 3771 chip and the game was now starting normally.
quartet4
3) The game was working and playing fine except for the FM sound that was inoperative (only the voices could be hear). It was due to the YM3012 located at 1B (a DAC). It had good looking signals on its inputs but nothing seemed to get out of its outputs. After replacing it I got the FM sound back.
Now the game is fully working.
Fluke 90 QuickTools 2.0 update
 General  Comments Off on Fluke 90 QuickTools 2.0 update
Feb 282016
I’ve uploaded the updated version of QuickTools 2.0 (formerly Fluke 90 Controller).
There are quite a few differences. The main ones are its quicker, has some status indicators for the Trace functions and has preliminary script support (which doesn’t work too well right now).
qt2
If anyone has the Z80 version of the Fluke 90 for sale then I would be interested in buying it if the price is right.
 Posted by at 4:30 pm
Fighting Fantasy PAL dumps added
 PAL Updates  Comments Off on Fighting Fantasy PAL dumps added
Feb 272016
Today I’ve dumped the only PAL from a Fighting Fantasy PCB, a weapon based fighting game from Data East released in 1989 (the game is also known as Hippodrome outside Japan).Dump has been successfully tested in a GAL16V8 targeting device.
 Posted by at 11:24 am
Feb 252016
Another Rainbow Islands PCB to repair.
This one had issues with the sprites which were broken up and seemed to be repeating, looked very much like a stuck bit on the sprite addressing;
IMG_20160224_112137583
IMG_20160224_112142174
All tiles and background graphics were fine, so I knew it was something to do with the sprite circuit.
The first thing I did was to look at the area where the sprite data is read from the two eproms.  The two 74LS244 buffers checked out fine, but one of the 74LS373 Octal Latches had an output pin stuck HI (pin 9);
IMG_20160224_112155598_HDR
So I desoldered it;
IMG_20160224_113645345
I confirmed the Octal Latch was bad in an IC Tester.  So I soldered in a socket and replaced with a fresh Octal Latch;
IMG_20160224_114050662
PCB sprites now restored;
ri_pcb_2
ri_pcb_3
Cabal and D.D. Crew (bootleg) PAL dumps added
 PAL Updates  Comments Off on Cabal and D.D. Crew (bootleg) PAL dumps added
Feb 242016
We have some new PAL dumps.In the last days Porchy dumped PALs from an unemulated D.D. Crew bootleg board (it will be included in next MAME release), devices were two unsecured GAL16V8.Thanks to him.
Today I’ve dumped the PAL from an original Cabal (TAD Corporation) and successfully tested it on a GAL16V8 targeting device.
 Posted by at 10:45 pm
