Merged M92 PAL entry
 PAL Updates  Comments Off on Merged M92 PAL entry
Apr 022016
We had two separate files for M92-b-2l.
One was just labelled for M92 hardware and the other was for Ninja Baseball Batman.
I deleted the entry for M92 as the Ninja Baseball Batman dump was from an actual unlocked PAL chip.
End user will not notice any difference, this update is to keep a record of what has been done and when.
 Posted by at 4:46 pm
Reading Irem MASKROM’s
 General, Technical Info  Comments Off on Reading Irem MASKROM’s
Apr 022016
I got an M92 PCB here that uses MASKROM’s from SHARP.
These MASK’s in particular are pin compatible for either 27C020, 27C040 or 27C080 EPROM’s.
It is possible to determine which to dump these as from the markings on the chip. They all begin with the ID LH53#, where # is the identifier of the size.
“LH532” = 27C020 dump
020
“LH534” = 27C040 dump
040
“LH538” = 27C080 dump
080
The remaining letters/numbers of the markings are unique to the game and location on the PCB.
 Posted by at 10:55 am
Mar 292016
Sometimes it is very annoying when you have placed your arcade monitor vertically and certain games are shown upside down and  even worse they have no option to flip the screen.
It happens very often with older games but sometimes even with newer games from the 90s.
In these cases you have 2 options: reverse phisically your monitor or reverse the yoke  on the pcb of the monitor (not very safe).
Now I show you a new option available only when the games were also prepared for cocktail tables (that means they have already the circuit to flip the screen for the second player)
In this first “flip screen” hack I will take Zaxxon / Future Spy hardware as an example
Future Spy_2
These games have no flip screen option but they have the preparation for cocktail tables play.
The board is very big but luckily schematics are available and they are very clear to understand.
The hack is very simple: input nr.4 of 74ls367@U64  is normally LOW for first player game and HI for second player game.
We have only to force pin 4 to HI (+5V) using a wire so that the screen is always flipped as it was playing the second player even in upright mode.
Zaxxo_flip screen hack
FS
Very simple and effective!
Mar 292016
Got a very clean Megazone pcb for a repair.  The board was in near mint conditions but it didn’t boot and also the Sync was missing.
Looking at the schematics available online, I noticed that the quartz responsibile for the CPU clock and sync was the one placed on the bottom board.
Tested with my frequency meter and it was dead.
It is a very rare 18.432mhz OSC which to my knowledge is used only by early 80s Konami boards.
megazone
Luckily I had a Double Dribble which I used for spare parts which had the very same OSC.
After changing it, the game booted perfectly.
megazone3
megazone4
For you information, if you try to install the more common 20Mhz OSC, the colours are off and the scrolling is jumping often, so unfortunately it’s not a good replacement.
The board had no sound but I immediately noticed that there was no noise coming out of the speaker which is the evidence of a faulty amplifier.
The amplifier is infact the very unrielable LA4460N, so after confirming the the music could be hear on input pin 2 , I exchanging it and fixed completely the game.
megazone2
