Sharp SF-1 (SNES TV) repair log #2
 Console Repair Logs, Repair Logs  Comments Off on Sharp SF-1 (SNES TV) repair log #2
May 222016
The 14″ TV is up now.
This one was a lot more involved.
Before starting on this one I had tested the previous PCB with this TV so I knew for sure the TV part was operating fully.
sf1-repair
When powering this up I got no audio or video, just a black screen. Using the external A/V output also gave me nothing.
I couldn’t find anything obvious visually on the PCB itself.
Ive read a lot in the past about SNES repairs and the CPU’s seem to be a weak point. I started prodding around the CPU with the scope and even though all the voltages and clocks looked good I could see any activity.
I had a known working spare SNES which I opted to sacrifice for parts.
sf1-pcbmark
I replaced the CPU and once again checked for signals. This time I had life but it gave up after a few seconds and still didn’t give me any output. This cycle was repeatable on resetting the machine.
I next opted to replace the ‘S-WRAM’ (work RAM) positioned next to the CPU.
Replacing this gave me audio but no video so at least I knew the game was running which was great to hear.
At this point I tried the external A/V connector again and got a good picture.
Probing the ‘S-Enc’ chip yielded no outputs at all despite all inputs being as expected. I replaced this and everything came up good. Time to reassemble and reclaim some bench space.
Thats both of these rare units fixed up.
sf1-pair
 Posted by at 10:21 am
May 212016
A couple of friends were looking to get their SF-1 SNES TV’s repaired. Not one for letting such gems go to ruin I offered to try and help out.
There were two units in need of repair, a 14″ and a 21″.
sf1-top
This log will focus on the 21″ version first.
On power up with a game fitted I got audio and a very faint greyed out picture.
I had been given an RGB scart cable with these so as they have the standard A/V output port on them I thought I’d give that a go.
I got this
sf1-sync
As you can see the sync signal is off but I could see a nice colour picture. This gave me initial hope that the PPU’s were not to blame for the grey faint picture.
Taking this unit apart was a bit of a pain with the SNES part being sandwiched in at the top but I got it out and looked for anything obvious.
sf1-pcb
(Note that this PCB image is actually from the 14″ version. The 21″ version has a very similar PCB with only the connector location being located differently. I forgot to take a picture of that one.)
There was nothing obvious so start looking at the missing sync signal first.
The answer was fairly straight forward. The RGB cable I have here uses the composite signal for its sync. The SF-1 does not seem to output a composite signal at all instead it uses the combined HV sync signal on pin 3. Hooking this up instead gave me a nice picture on my test monitor which confirmed the SNES was working great.
So whats happened to my picture on the actual TV unit?
It turns out the SNES outputs separate Luma and Chroma signals to the TV for its picture and not RGB like we initially thought.
sf1-connectors
The connector marked ‘VD’ is the video signals. The black wires are all grounds and the white wires are signal. One of the wires however is the audio output. So there is Luma, Chroma and mono audio on this connector.
Now I know the signal isn’t RGB I can pretty much assume that the ‘S-ENC’ (BA6952F) is used to generate the signals i’m missing.
Using the scope I couldn’t find any valid signals coming from the chip. In my haste I was about to write the chip off but as the output signals were really weird I traced all of the pins. I found the GND on pin 2 wasn’t connected at all and it should have been. I tried reflowing the pin but still no connected so I added a jumper wire to the GND point next to it.
20160518_205235
I was a little nervous about patching it as if the original track (that ran under the chip) had burnt out then what had happened to do that? It could have been a manufacturing defect, Ive seen a couple of those in my time but ground connections are generally quite big compared to signal traces. I didn’t want to remove the whole chip just to check for a burnt trace so I just check resistance between GND and VCC. It looked fine so I powered up to test.
21picture
An absolutely perfect picture! Seriously this picture is really good quality.
I tested all the controls and they seem to work fine too so time to box this up.
 Posted by at 8:18 pm
New PAL dumps added
 PAL Updates  Comments Off on New PAL dumps added
May 192016
Andrew Ivanov sent in dumps from Mortal Kombat and Mortal Kombat II  Midway T-Unit boards.Dump from Mortal Kombat  is proven to be working also on NBA Jam board.Thanks to him for this contribution.
I dumped the PAL from an original Elevator Action PCB.Device (a PAL16L8) is marked ‘WW15’  and located @IC24 and should be present on all games that run on Taito SJ system (Jungle Hunt, Alpine Ski, Front Line to name few)
 Posted by at 10:24 pm
May 192016
Last year after a lot of research I succeded to buy at a good price an original board of Psychic 5 , one of my favourite game of all time, which was really in mint conditions.
psychic5
Some days ago I picked it up for a play and after some minutes the game developed this problem during attract mode:
psy5
psy3
psy2
After some more time the game was total yellowish:
psy4
Game hasn’t any schematics available and there are not any games known to me which have similar hardware and schematics available.
I could only go blind and try to find the reason of the fault.
So I started to short some signals of srams looking for palette changings and I found a couple of them at pos.6N and 6M, 16kbits.
The one at pos.6N had the first 4 data pins low and I was pretty sure either it was faulty or the 74ls245 connected to the data bits.
After desoldering, the sram 2018 was tested good in the programmer. That meant that the programmers didn’t use all data pins of the palette rams. The 74ls245 was good because it could drive correctly the signals without the ram installed.
I tested some TTLs nearby looking for strange signals but found nothing.
Decided to go brute force using my logic comparator and testing everything on the video board but starting with FUJITSU parts which are known to be very unreliable.
The logic comparator found a 74ls08 with all the outputs faulty
psy6
I double checked the outputs with a logic probe and they were all in the grey area (no good logic signal).
After changing it I fix the problem 100%
psy8
psy1
So FUJITSU brand proves once again to be really unreliable!
Burnin’ Rubber and Final Fight (Japanese revisions) PAL dumps added
 PAL Updates  Comments Off on Burnin’ Rubber and Final Fight (Japanese revisions) PAL dumps added
May 152016
Ace’ sent it dump of the PAL from a Data East Burnin’ Rubber PCB.Device was a PAL10L8CN reversed using an ABI Boardmaster 4000.Thanks to him.
We have also dump of the PAL @1A from the Japanese revisions of Final Fight.This actually comes from MAME and was uploaded some time ago on Dumping Union list(there are also other PAL dumps on this list which I will progressively insert into our database)
Both dumps have been successfully tested on GAL16V8 targeting device.
 Posted by at 10:42 pm
