I have started a collection of PAL dumps for various games
https://www.jammarcade.net/pal-dumps/
If you have any I can add please let me know.
Got a box of broken boards from a guy on the Jamma+ forums.
Included are:
Rastan Saga – white screen
Hot Shots Tennis – constantly resets
Mortal Kombat – messed up controls
Seibu Soccer (Seibu) – no sound, very low
Karate Champ – non jamma pinout, looks clean though
Taito F3 Motherboard – no game to test it
X-Men Vs Streetfighter – Working
Sega STV Titan Motherboard + Die Hard Arcade – games dont load
Two Crude – all the ROMs are missing
Street Fighter 2 – bootleg – intermittently working
Another Street Fighter 2 bootleg – Dead, all roms and rams are dead, not worth fixing
The X-Men vs Streetfighter board is fully working and even has a working battery.
The SF2 bootleg is intermittently working, looks like the M5 bootleg.
All the other boards have the fault the guy stated.
Im pretty pleased with this lot.
The Naomi has a 0.1F super capacitor on board labelled C29, in between the button cell battery and the 8 pin DIP labelled 315-6188. This capacitor is a usual suspect on a broken board as it is prone to leaking and damaging the traces to the serial EEPROM. If you own a Naomi board (not sure if it applies to the Naomi 2) you should check the condition of this cap and replace it.
The capacitors can be ordered from the link below:
Mouser
After reading a simple guide by 1200xl over on the RCM forum, I decided to give this retrobrighting thing a go.
Retrobrighting is a process of removing the yellowing that tends to occur on old plastics. I’ll not go into the science behind it cause i don’t really know it.
As a test subject I used the casing of one of my Fluke 9010a pods.
I ordered some peroxide online and this Saturday was the ideal day to try as to make this work, sunlight is required.
Apply a nice thick coating of the peroxide to the washed down plastic and wrap it in clingfilm, then place it in the sun for a few hours turning it every so often to get all sides.
Probably should mention that rubber gloves are a must for this job as the peroxide doesn’t feel good on bare skin!
After its been roasted, remove the clingfilm and wash off the peroxide and let the plastic dry.
Pleased with the results for a first attempt and have since don’t the body of the Fluke with better results.
I was advised to apply a UV treatment after this as the yellowing will return but at this point I haven’t got any. I’ll get some ordered though.
Will no doubt have more stuff to do in the future.
Just a note to anyone attempting to burn ROMs that are available online.
This mainly concerns the ROMs for 16bit systems such as the Amiga, Atari ST, Megadrive etc.
The ROMs available for use with emulators, like the Kickstart ROMs for use in WinUAE, have all been byteswapped. If you are going to burn these into an EPROM then they needs to be byteswapped. This can be done using many different tools. I use my own drag and drop program to do this quickly but I know Hex Workshop (and probably most other hex editors) can do this too.
