Got sent a Commando board for repair a while back and have finally got around to giving it a test.
I spent a little time going over the board doing the visual inspection prior to booting up. On the bottom board a 74LS245 had been removed and was just sitting in the board loose but most of the traces going to the IC had also been lifted, I suspect during a bodged removal.
I refitted the IC (after testing it), cut the lifted tracks off the board and ran some kynar to the relevant points.
After spending a bit of time making another adapter up to run the game I saw the graphics fault.
All the sprites were barely visible and sometimes were gone completely.
There was also some corruption on one of the screens.
The manual for this game is online and in the back of this are the schematics for the game. Nice. Also, as its CAPCOM, the schematics are nicely split and labelled up in sections.
After seeing the fault I was convinced that RAM was to blame. I scoped a section of 4 x 2114 RAM chips on the lower board. All had good looking address lines but the data lines looked very odd like they were struggling to drive the lines low. I interrupted a couple of pins and graphics started to come back so I pulled it and testing it, FAIL. One replacing the RAM only half the sprites came back with jail-bars running through them. I ended up pulling 3 in total which was quite lucky as I ran out of RAM replacements.
All graphics are now returned to normal.
As for the corruption on the screen. Thanks to MAME I was able to determine this to be an unused part of the screen that my RGB to VGA converter decided to throw in there to confuse me. In a cabinet the screen would be adjusted to remove these borders.
