Mar 192017
Got this X-Men PCB for a repair :
As often happens on Konami boards that use hybrid audio module (the ‘054544’ in this case) audio was horribly scratchy and loud:
Electrolytic capacitors  had already been replaced with same type but this obviously was not enough:
So, I removed the module from PCB and decided to fully service it:
I replaced with new parts the 4558 OP-AMP (I used a compatible LM358) and the AD1868 DAC as well:
At same time I reinforced some poor connections  :
Lastly, as icing on the cake, I varnished with black laquer :
As always I do, I installed on PCB a couple of 1.778mm female round machine-tooled strips.This was the final result:
Time to test :
Job done.
P.S.
For the uninitiated, the ‘054544’ module has been reproduced, you can read more about on these threads:
https://forums.arcade-museum.com/showthread.php?t=386416
https://forums.arcade-museum.com/showthread.php?t=396393
 Posted by at 2:46 pm
