Oct 042014
muddymusic dumped the PAL from his U.S Navy CPS1 board and has tested it. It is marked as CA22B.
Ive also got a Jumping board from muddymusic’s which I am currently working on. There is a PAL20L8 chip that does the address decoding for the CPU which is now dumped. At this point Ive not tested it as the board set is in bits but I will test as soon as I can. The device is also unlocked so im pretty confident the dump will be OK.
