Got my hands on this thing today
There are no EPROM’s in it yet but will knock some together when I get time and test it out.
It has a battery backed RAM and a bank of DIP’s that I have no clue yet as to what they do.
There is a CK2605 PLD at IC10 marked up as 315-5341.
I cannot find any programmer that will actually support these chips but it is known that they can be dumped as a PLS153 and Charles MacDonald has a utility that can trim the overdumped .JED and convert it to a functional PLS153 fusemap. I have uploaded this converted fuse map.
I have also decompiled the .JED into equations and converted it for a GAL22V10 which I will be able to use my converter board for. It is untested, obviously, as I haven’t had the thing up and running yet but will hopefully sort this soon.
2 Responses to “SEGA Megadrive EPROM PCB”
Interesting bit of kit you’ve got there, look forward to seeing what you can do with it.
StiGGy
Not really sure what ill do with it. Its like a very poor mans Everdrive!
I only really got it to dump that PLD
