Jan 012013
Andreas is back again with more dumps from his Data East Phycho-Nics Oscar board.
Chip located at F18 is a CK2605 chip which is quite uncommon and has been dumped as a PLS153 chip. This is fine and the dump can be converted to true PLS153 format by using Charles MacDonalds PLAD.EXE tool. I have already done this.
Chip located at F20 is a PAL16L8. This will need converted to a GAL first if you are going to be using such a device.
Thanks once again to Andreas
 Posted by at 9:49 pm
