May 312014
The pin toggle PCB I made finally came and im quite pleased with it. I had to make a couple of changes in software to accommodate an error I made but that’s the beauty of having full control via software.
It works well but I wish I had added a reset switch on top and also wish I had given access to a couple of the other IO pins across the top because right now I have to add a link you switch between 20/24 pin devices.
Maybe ill make a revision 2 sometime but I have no real need to do so.
