Today I successfully converted the Operation Thunderbolt PAL dumps to GAL format and tested all of them. This is now a complete set.
Andrew96 also dumped, tested and submitted the PAL dump from the Fluke 9100 SCSI card. Big thanks to Andrew for this.
Received this original Nichibutsu Terra Cresta PCB for a repair:
Board had severe graphical issues, backgounds were all messed up and moving, sprites absent:
The first thing I noticed after my visual inspection was that both boards were fully populated with Fujitsu TTLs therefore I was pretty sure all the faults were due them.To troubleshoot them I used my HP10529A logic comparator for TTLs up 16 pin and a logic probe for 20 pin ones.The backgrounds data are stored in two 27256 EPROMs @15F and 17F on CPU board so I went to probe around and I found a 74LS273 @18E with stuck outputs:
This was confirmed also by a logic analyzing of the device:
Once desoldered the device failed when tested out-of-circuit:
I got improvements, now backgorunds were almost formed but still scrambled and sprites visible although not perfect:
With my HP10529A I found a 74LS157 with floating outputs @17D on CPU board:
Chip failed the out-of-circuit test:
Backgrounds were now 100% restored but sprites missing lines with some garbage on screen :
At this point I focused on video board since all objects circuitry lies there :
Probing around the sprites EPROMs, I found a 74LS367 @1F with bad outputs:
and a 7LS257 @3C (involved in sprites RAM data bus) with stuck outputs, also this failed its test:
Now sprites were perfect but doing some comparison with MAME I realized that characters were totally missing!
Found a 74LS257 @14G with missing input pin 15 (/OE ) in the area of the character ROM:
I traced it back to an output of a 74LS367@20B on CPU board:
Logic analyzing confirmed its outputs were floating and chip failed once tested out-of-circuit:
Characters were back:
I was archiving this repair when, during my test, I experienced some sound issues, sometimes audio was distorted:
This board uses an YM3526 OPL IC paired with an YM3014 DAC although chips are marked with Nichibutsu part name (‘TC 148509’ and ‘TC 1409’) :
Probing pin 2 (the analog output connected to the OP-AMP) of the ‘TC 1409’ revealed a weak signal:
I replaced it with a YM3014 :
This gave good sound back.Board 100% fixed and evil Fujitsu once again defeated.
Some untested PAL dumps added
Today we have some PAL dumps from not working boards (Funworld, Jolly Card and Jolly Joker), hence they are all untested.They have been dumped by Team Europe using an adapter (designed by Charles MacDonald) able to read the PLD as a 27C020 EPROM, therefore they provided binary dumps which I took care to analyze and reverse into GAL16V8.Thanks to Team Europe for their contribution.
New Zero Team PAL dumps added
Today, after repairing the board, I dumped the PLDs (two secured GAL16V8) from a New Zero Team PCB (by Seibu Kaihatsu).Both dumps have been tested working in GAL16V8 targeting device.
Dragon Breed (Irem M81) PAL dump added
‘frsj8112′ ,one of our finest contributors, sent in a PAL dump from a Dragon Breed PCB (Irem M81 hardware).The device is located @IC48 on CPU board and it’s specific to this game.Dump has been successfully tested on a GAL16V8.Thanks again to him.
