Channelmaniac kindly sent me some tech info he made up recently for the 054539 custom found on some Konami boards.
Here we have the pinout for the chip and also the circuit conenctions
Thanks to Channelmaniac for sharing these
Got an original Passing Shot PCB for repair, as you may know it’s a tennis game released for System 16B hardware by Sega in 1988.
Board had its ‘FD1094’ battery-backed custom CPU module which was still alive since the board booted but sound was missing at all:
These are the times when an audio probe really comes in handy in diagnosing the fault helping you to figure out the nature of the lack of sound (if digital or analog).So I fired up this tool and started to listem to various points of the audio circuit :
For first I probed the outputs of the YM3812 DAC and I got sound from them, this meant the fault was in the analog circuit.Looking at schematics I followed the path, the sound was still present on the input of the volume potentiometer :
But then it was silent on the output which gives the signal to the Fujitsu MB3733 amplifier :
Schematics shows there is nothing between the output of the potentiometer and the input of the amplifier (apart from a 10uF electrolytic capacitor that was tested as good)
Metering the amplifier I found that pin 1 ( the input which takes the signal from the potentiometer) was almost shorted to pin 11 (+12V supply), there was only 12.4 Ohm of resistance :
The amplifier was likely bad so I removed it :
And replaced it putting also some thermal silicon grease for a better heat dissipation :
I powered the board up again and the sound was back.No other issue found hence I could declare this board 100% fixed and working.
Over the last few months I’ve had tons of messages from readers of this blog asking about the lack of updates and all sorts of nice words so I think its time to address this officially here.
My interest in arcade repairs has pretty much dwindled down to nothing over the last 12 months or so and I have found myself finding a love for other hobbies which I am throwing myself into and loving them more and more.
That doesn’t really leave me with much free time for repairs and it certainly doesn’t leave me with any time to write up a detailed blog post about it either.
Right now, my official status on this is I wont be doing anymore repairs logs.
With that said I do put a lot of time and effort into dealing with PAL’s and will still be maintaining the WIKI and the blog will still stay with that too.
If the time comes that I wont be continuing with the site then it will either all be handed over to someone else that is willing to keep the information going or it will be saved and made available via other methods. I’m not going to let the last 10 years of work from myself and other contributors disappear.
Any of the other contributors can still post here if they wish and if anyone else wants to contribute then I will create an account for them too
I hope that puts a few minds at ease
Philmur has sent me his Pacman diagnostic ROM.
Pacman test ROM – philmurr 05/20
Fits at location 6E
Tests programme, colour, video and sprite RAM 1 (note sprite RAM 2 is write-only)
Displays sprites dropping from screen to show sprite select and addressing is working (tries to show all 8 but most boards only have 6)
Shows real-time status of inputs and DIPsColour RAM – 4P, 4L
Prog RAM – 4R, 4M
Video RAM – 4N, 4KSprite RAM 1 – part of 4R,4M but may make it clearer to people when testing
File can be downloaded in the “Downloads/ROM files/Diagnostic” menu
Thanks to Philmur for his hard work and for sharing this
Yet another Operation Wolf repair and this one gave me trouble.
First test we had watchdogging. All ROM’s checked out fine in the programmer and seeing nothing else obvious I removed the work RAM both of which failed.
Now on boot up I got a screen seemingly running game but all the screen was garbage.
Probing the data lines of the screen RAM show pretty much all of them across two RAM chips were dead. I desoldered and replaced them both.
Now I got a running game but the colours were messed up
There are two 74LS245’s attached to the data lines of the colour RAM at location IC78 & IC90. Probing these revealed stuck bits on IC78. Replacing this gave me perfect results on the colour test screen in test mode but dull colours in game. Other issues in-game showed me all the sprites were missing and the screen doesn’t scroll when entering a game.
Stupidly I chose to ignore the colour issue and concentrate on the other two (I will get back to this later).
The sprite and scrolling issue worried me because these areas are related to the PC080SN and PC0900J custom chips.
Paulcan69 sent me a scrapper PCB so I could rob the customs off it if needed so I started out by replacing the PC0900J.
Replacing this brought my sprites back but the scrolling issue was still present.
I didn’t enjoy replacing that IC so I started checking around to see if the scrolling issue could lie somewhere else.
I found nothing wrong so removed the PC080SN custom and replaced it with the spare but it made absolutely no difference. A lot of work time and effort for nothing.
I spent time over the course of the next few days looking into this but found nothing.
Eventually I got sick of looking at the washed out colours on screen and replaced IC90 to fix the last of the colour issues.
I couldn’t really believe it when this fixed my scrolling issue as well.
I still don’t understand why this chip caused the scrolling issue but I’m really glad it did.
All issue are now fixed on this board.
Onto the sound PCB.
The original sound PCB that came with this board was a complete write off. Every chip I pulled from this board was broken and both amps were also burning hot.
Among all the other boards that Paulcan69 had sent me he also kindly sent me a spare sound PCB for Muddymusic to have.
There was a sticker on this board saying “No Sound”.
On first test I found that the music played but the volume was really low. Turning the volume up to the maximum made the sound audible but not nearly enough.
I checked the resistance of the volume pot and found that if you move the pot off maximum setting then it read megaohms. I tried cleaning it but it didn’t work so I replaced it.
This made the sounds much better but like with most of the others I’ve repaired some of the samples were scrambled and didn’t stop playing when they should.
I quickly found another 74LS688 that was dead. Replacing this made the sounds stop when they should but the samples on channel A were scrambled.
Looking at the schematics shows where the sample data goes.
Using an audio probe I checked the output at pin 10 of the 5205. The sound was the same. This ruled out issues caused by bad caps and things like that.
Next I checked the 574 at IC33. Both the input and output looked good so moved onto the 74LS157 at IC 44.
Probing all the outputs with a logic probe showed pin 9 was stuck HIGH
Replacing this fixed all the samples.
That’s the last one fixed
Big thanks to Paulcan69 for the spares board. Without it this board would be scrap too.
